Solar Panel - 2x Batteries - National Luna Fridge
george
Town: Velddrif
Vehicle: Triton 3.5l V6
Club VHF Licence: HC107
Re: Solar Panel - 2x Batteries - National Luna Fridge
Post by george »
SuidWes wrote:Something is wrong....
I only run a 60 watt panel and when connected, and panel is in the sun, I can clearly see it on the NL bat monitor as it will show a voltage increase of about 3 led's.
I'll also run some tests and share the results...
jis Jaco
What happens when the panel is in the shade?Does it produce less power or no power
Royco
Town: Stellenbosch
Real Name: Roy
Club VHF Licence: X88
Post by Royco »
I think the problem is the position of the panel.
Quoted from various websites:
The output of any panel will be reduced or cut off if shaded.
The mono-crystalline solar panels are somewhat more shade tolerant than poly-crystalline solar panels because each cell cuts out only when totally shaded. (emphasis added)
Check out this site: http://www.renewableenergyworld.com/rea ... pens-54551" onclick="window.open(this.href);return false;
I don't quite get this table, as the more shade the more voltage output !?!?
But it does show that a small amount of shade can reduce the output by around 50%.
SuidWes wrote: I'll also run some tests and share the results...
It would be great to see your tests, Jaco.
Image Image Image Image
SuidWes
Town: Durbanville
Vehicle: Prado 120 VX
Real Name: Jaco
Club VHF Licence: B35
Post by SuidWes »
Shade is a problem even if you cover only one cell.....
Will do some tests on that as well :thumbup:
SuidWes
Town: Durbanville
Real Name: Jaco
Post by SuidWes »
OK, so as promised I've started testing.
Quite a mission to remove everything from the SFA :alvarin: Anyway, decided to place the panel on the balcony where it can get about 8 hours of direct sun per day. Note pro stand :cooldude:
Setup Detail:
102 ah Exide High Cycle battery (2yrs old)
Steca Solsum 6.6c controller
55 Watt (3.1Amp) Tenesol Panel (1yr old)
40 Engel (5yrs old)
For the first test I also left the freezer empty and I set it to setting 2 which keep the inside temp between -3 and -5 degrees according to the Engel temp display.
Results:
Date Time Bat Voltage Temp Weather
23/02 19:30 12.81 -4 N/A
24/02 06:00 12.50 -5 Sunny
24/02 19:30 12.61 -5 N/A
25/02 06:00 12.41 -4 Rain to 10:00 AM; Sunny for the rest
25/02 19:30 12.55 -5 N/A
26/02 06:00 12.32 -4 Cloudy
26/02 19:30 12.47 -4 N/A
27/02 06:00 12.23 -5 Cloudy for most
27/02 19:30 12.27 -4 N/A
I’ll keep going till the battery gets to 12.2 Volt (50% SoC) Then charge it again for test 2 :thumbup:
SuidWes
Town: Durbanville
Real Name: Jaco
Post by SuidWes »
Now the Shade Question:
I quickly removed the freezer for this test.
Panel covered after 5 mins = 12.35V
No cover after 2 mins = 12.78V
1/2 cover after 2 mins = 12.46V
1/4 cover after 2 mins = 12.56V
So direct sun with no shade is extremely important.
jis Jaco
George, less power much less
SuidWes
Town: Durbanville
Real Name: Jaco
Post by SuidWes »
OK, on day 4 and think we might make it to the end of Day 5..... :thumbup:
See attached graph showing the results so far for test 1.
I will fill the freezer for test 2, open it twice a day and cool some beers daily as well :cool: Should be interesting :arrow:
Solar Test.xls
(20 KiB) Downloaded 105 times
SuidWes
Town: Durbanville
Real Name: Jaco
Post by SuidWes »
Due to cloudy weather we did not make day 5 :| Latest results attached.
I'm now going to recharge the battery and put the fridge on 220... Will start with the 2nd test on Tuesday :thumbup:
Solar Test.xls
(20 KiB) Downloaded 98 times
george
Town: Velddrif
Post by george »
Nice one Jaco. :thumbup: Good to get some real life data.
it would be nice if to see how a 90 watt will operate on the same conditions
SuidWes
Town: Durbanville
Real Name: Jaco
Post by SuidWes »
Think a 90 watt would have topped up the battery every day... :arrow:
