Fibre glass coolbox--Help
- Town: Marble Hall
- Vehicle: Hilux xtra Cab 2014,Isuzu 250 dtec 2011 ,Fortuner d4d 4x4
- Real Name: Elvy
Hi all,
Is there somebody out there that can help me,plans materials etc.
Of is ek besig om my tyd te mors en ek moet iets anders kry om my na ure besig te hou.
Thanx,
Elvy
Thanx,
Elvy
2011 Hilux D4D 4x4 s/c
2008 Fortuner 4x4
1993 Hilux d/c sfa
2008 Fortuner 4x4
1993 Hilux d/c sfa
Re: Fibre glass coolbox--Help
Elvy hoe groot moet hy wees? 1 of 2 deure? Dis nie moeilik om te bou nie, veral as jy al bietjie met F/G gewerk het..
- Town: Marble Hall
- Real Name: Elvy
Thys,
Omtrent die groote van die ou steelbelt Colemans.Kan ek egter met polystyrene werk met resin,gaan die hom nie vreet nie?Het fg ondervinding met bote(ook nie te veel nie.)
Thanx
Elvy
Thanx
Elvy
2008 Fortuner 4x4
1993 Hilux d/c sfa
2008 Fortuner 4x4
1993 Hilux d/c sfa
- Gertc
- Vehicle: 3.0L Fortuner
- Real Name: Gert Combrink
- Club VHF Licence: Xray05
Jy sal eers die polystrene moet bedek met iets al gedink `n water basis verf of hout gom dalk. Ek het egter eers die boks gebou en na die tyd foam ingespuit.
viewtopic.php?f=8&t=5367" onclick="window.open(this.href);return false;
Sterkte
Sterkte
Gert is jou man, hy ken van yskassies bou. Jy's reg, die resin vreet die polistireen.
- Town: Marble Hall
- Real Name: Elvy
Dankie Gert ,Thys sal so bietjie oefen tot ek die resep het.
Elvy
Elvy
2008 Fortuner 4x4
1993 Hilux d/c sfa
2008 Fortuner 4x4
1993 Hilux d/c sfa
Elvy,
Bel vir Peet op Voda 390 7544, alles en nog meer wat jy wil weet oor die glasvesel en foam sal hy jou raad kan gee.
- AM Racing
- Real Name: Dylan
How to make quick moulds.
Find two boxes that fit into each other that leave about a 30mm gap between the sides and the bottom.
Use the big box for your outer skin. Mould your glass fibre in the inside of the box. You can get gel coat and a releasing agent from your hardware store.
Use the small box for the inner lining. Mould your glass fibre on the outside of the box that will give a clean finish in the inside.
You can use polystyrene between the layers for insulation.
Make the lid out of a piece of marine ply +- 10mm thick. make an internal frame that sits in the inner skin for a better seal.
You can put a piece of polystyrene in this lid for insulation.
Alot of pt though. Cooler boxes are quite cheap.
- yotaman
- Real Name: Shane
Try & google it for info/tipsVis wrote:Hi all,
Thanx,
Elvy
Albert Einstein
Albert Einstein
- Town: Marble Hall
- Real Name: Elvy
Tanx Thabo,Dylan and Shane.
Evy
Evy
2008 Fortuner 4x4
1993 Hilux d/c sfa
2008 Fortuner 4x4
1993 Hilux d/c sfa
