Rev counter - Sorted
- Bushwacker
- Town: Vryheid Natal
- Real Name: Piet
How do I get the rev counter to work on my KZ - lexus conversion, any ideas
- kfxnando
- Town: Germiston
- Real Name: Fernando
Re: Rev counter
speedometer services in Germistom/Primrose does that!!
they quoted me R600
dont have the contact details on me right now!!
they used to advertise in the old car magazines
if you have an electronic back round sure you could have a go at it, we going to have a go at it, not so much the money, more to say we did it!! hehehe!!!!
however it will be time consuming!! and we have all the right tools at work!!
did a google search
here you go
http://www.brabys.co.za/search-InfoKey. ... 20Services" onclick="window.open(this.href);return false;
they quoted me R600
did a google search
here you go
- Town: Heidelberg
- Vehicle: Hilux 2.5 D4D
- Real Name: Koos
Re: Rev counter
Pick-up the rev sensor from anyone of the coils, then you're measuring only 4 cylinders and your rev counter should work. Don't go pay R600, it's a minor wiring job.
Good luck
Good luck
- ZIETS
- Town: Roodepoort
- Vehicle: 1997 Hilux SFA Lexus V8 fitted with Mickey Thompson 33x12.5R15
- Real Name: Riaan
Re: Rev counter
Just like Koos said did it about a month back took out the cluster nothing difficult at the back you will see a black and yellow wire can’t remember witch one (only one wire) this goes to the coil I used the small one not the coil at the water bridge there is only 1 wire follow to harness and join neatly. Back to the cluster and start motor see witch one reg on the counter. I’ll take a photo if need be let me know. Makes a big difference to see the refs just so much cooler.
- Town: Heidelberg
- Real Name: Koos
Re: Rev counter
Riaan, watse radiator het jy in jou bakkie en sleep jy met hom?
- ZIETS
- Town: Roodepoort
- Real Name: Riaan
Re: Rev counter
Koos ek het al so gesukkel met overheating probleme maar ja BMW RadiatorOu vale1 wrote:Riaan, watse radiator het jy in jou bakkie en sleep jy met hom?
2 x electric fans. Nog nie gesleep met hom nie. Probleem met verkoeling is dat hy net warm word "under load" gas toets gedoen en head gasket het gegaan so wag nou vir fondse om import motor te gaan koop en in te sit behoorlik...
- Bushwacker
- Real Name: Piet
Re: Rev counter
Lexus op KZTE RatkasSpartan wrote:Watse Lexus conversion het jy gedoen?
- Spartan
- Town: Vanderbijlpark
Re: Rev counter
V8 of L6?Bushwacker wrote:Lexus op KZTE RatkasSpartan wrote:Watse Lexus conversion het jy gedoen?
MOBILITATE VINCERE
Spartan
Spartan
- Bushwacker
- Real Name: Piet
Re: Rev counter
Dis die V8, sorry man.
- Bushwacker
- Real Name: Piet
Re: Rev counter
Die revcounter werk danksy Wim
