I drive a 2003 2.7 Hilux 4X2 Recently the oil seal between the box and the propshaft leaked. I had it repaired approximately 5000 km`s ago. What started now is a difficult gearshift on 2nd and 4th. I drained the box oil and found that it was SAE 90 instead of SAE 80 and the level was 500ml too low. I replaced the oil with SAE EPK 75-90. Could the low oil level and the incorrect grade of oil have caused damage?
Andre
082 396 0585
W56 Gearbox
- Town: Germiston
- Vehicle: Toyota Hilux 2.7i 4X2 double cab Raider 2003
- Real Name: Andre
W56 Gearbox
Andre J van Rensburg
2.7i Raider D/C
Conqueror Companion
2.7i Raider D/C
Conqueror Companion
- Spartan
- Town: Vanderbijlpark
Re: W56 Gearbox
Wat maak hy nou nadat jy die olie geruil het en op die regte level het
MOBILITATE VINCERE
Spartan
Spartan
Re: W56 Gearbox
Ek dink nie jy behoort enige skade op te getel het in daai afstand nie. As hy normaal gebruik is en die gearbox het nie hard gewerk nie (iets gesleep of in duk sand gery het) behoort jy fine te wees
- HiluxJunkie
- Town: Middelburg MP
- Vehicle: 2001 Hilux DC 4x4 2.7i Raider
- Real Name: Simon
- Club VHF Licence: N15
Re: W56 Gearbox
Hoe het jy gesien dis 90 ipv 80 ?Ruger wrote:I drive a 2003 2.7 Hilux 4X2 Recently the oil seal between the box and the propshaft leaked. I had it repaired approximately 5000 km`s ago. What started now is a difficult gearshift on 2nd and 4th. I drained the box oil and found that it was SAE 90 instead of SAE 80 and the level was 500ml too low. I replaced the oil with SAE EPK 75-90. Could the low oil level and the incorrect grade of oil have caused damage?
Andre
082 396 0585
- Town: Germiston
- Real Name: Andre
Re: W56 Gearbox
Die ratkas voel nou gladder nadat ek `n paar kilo`s gery het en dit lyk darem nie of ek `n probleem het nie. Ek het die olie laat toets - laboratorium by die plek waar ek werk.
Dankie!
Dankie!
2.7i Raider D/C
Conqueror Companion
2.7i Raider D/C
Conqueror Companion
