Vigo Body lifts
- Town: Springs
- Real Name: Heinrich
- Club VHF Licence: X81
Vigo Body lifts
Who in Gauteng will be able to do a job like this??
http://www.vehiclemods.net.au/forum/vie ... ?f=26&t=34" onclick="window.open(this.href);return false;
I'll need to off course consider lifting the bumper in front? Will leave rock sliders where they are, they have to still protect the body.
Know what you don't know.
- FUDGES
- Vehicle: D4D 3.0l
- Real Name: A.J.
Re: Vigo Body lifts
I don't get it what is the purpose of a body lift other than looks? The chassis still stay at the same level so no height increase.
For me its just to riscky you increase you c.o.c considerbly and then your stuck can't go and do heavy 4x4ing.
Or am I missing something here?
- Town: Springs
Re: Vigo Body lifts
If you lift the body, you can fit larger tyres. Larger tyres can increase your distance from the ground from centre hub resulting in more ground clearance.
All these SFA's with their 35's have had some sort of lift, and they go very extreme.
You do not increase COG that much with a 40mm lift. The heaviest part of your vehicle still remains at the same level.
- ToyX4
- Town: Ottosdal
- Vehicle: Rocky's
- Real Name: Riaan
Re: Vigo Body lifts
Heinrich, there's a guy in Potch who can do it, but I heard last week he want R6000 to do a lift. That is crazy. Why not ask Louis 4x4MW?
If you have a body lift, you also increase your vehicles approach and departure angles, A.J.
- Town: Springs
Re: Vigo Body lifts
Heeltemal korrek Riaan, ongelukkig verander die breakover nie. (totdat jy die groter bande opsit.....)
Ek kan by hom uitvind, dankie vir die rigting, ek soek net 'n 40mm lift.
- FUDGES
- Vehicle: D4D 3.0l
- Real Name: A.J.
Re: Vigo Body lifts
Ok good nout ek ook iets geleer Heinrich bel Reghard hy doen dit ook 0734378215
Re: Vigo Body lifts
Heinrich, ek weet nie so lekker oor die 33 / 35's? Die 2.5 gaan dit nie lekker hanteer nie....
- ToyX4
- Town: Ottosdal
- Vehicle: Rocky's
- Real Name: Riaan
Re: Vigo Body lifts
Ek wou dieselfde se, Mark. My 2.5 SC ry op 215 85 15's, en hy is sleg stadig. Het noudie dag 31's opgehad en dit was n straf om met hom te ry.
- Town: Springs
Re: Vigo Body lifts
Dan moet mens maar kyk hoe kry Nissan soveel krag uit die 2.5 Navara
- ToyX4
- Town: Ottosdal
- Vehicle: Rocky's
- Real Name: Riaan
Re: Vigo Body lifts
Ek is seker daarvan daar is nie een van daai high output nissan 2.5's wat so lank sal hou soos n Toyota 2.5 nie. Daai knaap is bietjie overstressed as jy my vra, of teminste baie naby, nader as enige Toy engine, al is hy sleg gechip
Re: Vigo Body lifts
Jy weet mos Toy's is underspecked, dis hoekom hulle langer en beter hou
- Town: Springs
Re: Vigo Body lifts
Ek sit more uiteindelik die Chip in wat al maande in die kluis is. Volgende stap sal intercooler wees (soos wat Mark gedoen het).
Soos wat ek bestuur, sal ek tevrede wees as ek dieselfde performance kan kry na so 'n projek met die engine upgrade, as voor die tyd sonder die engine upgrade.
Ek wil nie groter as 33"s opsit nie.
Jy is reg Mark. Hulle werk omtrent 25% binne hulle design spec.
- ToyX4
- Town: Ottosdal
- Vehicle: Rocky's
- Real Name: Riaan
Re: Vigo Body lifts
Met die chip en cooler sal hy seker werk. As 33's agter op pas, hoekom sit jy nie agter 33's op en voel hoe ry jou bakkie nie, dan sal jy mos weet of jy wil of nie.
Maar ek dink met 33's op sal jy nie eers n 5 voet venter wil sleep nie...
- FUDGES
- Vehicle: D4D 3.0l
- Real Name: A.J.
Re: Vigo Body lifts
Ek het baie krag verloor op my 3l nadat ek 32" op gesit het nous hy gechip bietjie beter maar nogsteeds nie waar hy was nie.
- FUDGES
- Vehicle: D4D 3.0l
- Real Name: A.J.
Re: Vigo Body lifts
Ek glo so ek sal net moet gaan kyk, ons is eers oor n week by die huis.
- 00LA
- Town: Rustenburg
- Vehicle: Hilux 3.0D4D
Re: Vigo Body lifts
HI guys I did the body lift on my 3.0 Myself over a week end it realy is not such a big job and yes you do loose a bit of power with the 33" tyres but it is worth it But I agree with Mark i dont think its going to be a plesure on the 2.5 I have also fitted larger tyres on my 2.5 single cab and it is battling
- AM Racing
- Real Name: Dylan
Re: Vigo Body lifts
I have the 32" on and it is dead so to speak. Has anybody changed turbo's or increased boost on the 2.5? Not sure what the long term implications would be...
Re: Vigo Body lifts
I have not increased boost on the turbo, but very easy :!:
Chip dastek and fitted a 2.5 Mzda inter cooler, now 99kw
- Town: Springs
Re: Vigo Body lifts
I want to fit an intercooler.
I've now had 265/75's on for about 3 weeks, and I do feel the affect at highway speeds, but below 100km/h the impact is almost not noticeable.
- Vehicle: 2008 D4-d Fortuner
- Real Name: Uys
Re: Vigo Body lifts
Heinric.
EK gaan met die nuwe bumper probeer om dit so te maak dat jy hom net kan losmaak en opskuif na 'n 40mm body lift.
Doen daai body lift self - dis 'n Saterdag se werk.
Uys
Uys
- AM Racing
- Real Name: Dylan
Re: Vigo Body lifts
Mmmm. Maybe time for that intercooler and boost from 0.75 to 0.9 bar. I will be doing that soon. Will let you know the outcome. Gonna have to monitor egt though otherwise Chernobyl in my engine!!!
- BlumTRD
- Town: South Africa
- Real Name: David
Re: Vigo Body lifts
R6000 - R6500
for a body lift
Geeze
And i did 4 Lifts in total .. Fully installed
(Blocks bolts etc)and lifted the bumper for R1100 each
it aint that hard
- Town: Springs
Re: Vigo Body lifts
Uys, dit lyk nie of dit so erge job is nie. Dis 1 ding om gate te boor, dit ander ding om te probeer om hom gelig te kry..... :wth:Uys wrote:Heinric.
Uys
