Wheel bearing replacement
- Vehicle: 2700i SRX Hilux
- Real Name: Malcolm
When do you know when a wheel bearing needs replacement ? There is a noise coming from the front left wheel, not sure if it is the hub or bearing.
Re: Wheel bearing replacement
Jack the car up so that the wheel is in the air. now spin the wheel with your hand. If the bearing is due for replacement you will hear a slight grinding noise. Also try to wedge the wheel a little, there shouldn't be play on the bearing. if there is, replace...
