1G-R 4.0L V6 into a SFA
Gollum
Vehicle: Ford Bantam
Real Name: Jaco
Post by Gollum »
Has anyone done this before? I know it will be expensive but it will also be interresting and keep things in the T family.
Castos
Town: Nelspruit
Vehicle: Ry die vyand
Real Name: Reynard
Club VHF Licence: B01
Re: 1G-R 4.0L V6 into a SFA
Post by Castos »
Had a look into it. motor will be nothing under R40k alone. Go Lexus, they come with a T badge on the manifold.
Elands4x4
PERS KERS
Vehicle: HILUX,CRUISER,FORTUNER
Real Name: ALEX
Post by PERS KERS »
Ja do it, yes it will be expensive but then you not playing with 20 year old enjins, parts are easy to get ect. You can't go wrong, the 1Uzfe has 358 nm and the auto V6 has 373nm. Why use 20 year old enjin? If you can affort it ,go for it.
Spartan
Town: Vanderbijlpark
Real Name: Jaco
Post by Spartan »
Dit behoort n nice conversion te wees, ek het al gekyk na die 4GR wat die 2.5 V6 is met duel VVTi maar hy is dik duur. Ek het hier in Saudi gekyk na die engine, het n foto of twee geneem sal soek en opsit, en hulle wou R28K gehad het vir hom, dan het hy n flex plate op geen plugs vir die drade nie, skoon, en ek het gedink hulle kan hom druk waar die son nie skyn nie. Mooi engine maak geen fout maar ek dink nog die 2JZ N/A is n baie beter roep.
MOBILITATE VINCERE
Spartan
Spartan
Real Name: Jaco
Post by Spartan »
OK hier is die 4GR
4GR FSE - Copy.jpg (28.42 KiB) Viewed 1601 times
4GR FSE Rear - Copy.jpg (33.75 KiB) Viewed 1601 times
MOBILITATE VINCERE
Spartan
