HZ 4.2L engine on a hilux
Pingui
Town: LUANDA
Vehicle: HILUX 2008 D4D
Real Name: Bruno
Post by Pingui »
good day,
I try to gt some information about put 1 engine HZ 6 Cyl on my hilux 2008, because my turbo is broken andsome part need to be replace.
Have you some think for me ?
Hilux 2008 D4D
Good day.....Guys...
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Re: HZ 4.2L engine on a hilux
Post by Mr_B »
Bruno, welcome... please tell us where you are from...
Will the 2008 Hilux be able to handle the weight of the HZ engine??
Mr B
Pingui
Town: LUANDA
Real Name: Bruno
Post by Pingui »
Thanks, I come from France but i live in Angola.
For the weigth, I don't know, for the space it's short but it's enouth...
Hilux 2008 D4D
Thabogrobler
Club VHF Licence: x223
Post by Thabogrobler »
You will have more trouble than you would want to have!
Think gearbox, cooling, weight, reliability, etc.
Rather tell us what happened to your truck and someone might be able to help with advice.
JohanM
Town: Meyerton
Vehicle: Prado 120 4.0 V6
Club VHF Licence: HC126
Post by JohanM »
A 1HZ 4.2D Cruiser engine complete with all the fittings will be weighing around 200 - 250 kg's. I really don't think that the Vigo Hilux suspension will be able to cope with that and still be high enough and firm enough to do offroading with.
I will not advise to go that route at all as it is going to be a lot more complitcated that initially thought.
The 1HZ engien uses mechanic pump and basic wiring. If you have to modify the Hilux wiring in order to start the vehicle most of your functions like Central locking ect will not work anymore as it is one unit managing everything.
Also the cooling will be way less that sufficient.
Rather fix the turbo as it will be cheaper than contemplating doing a 4cylinder to 6 cylinder conversion. Also the power and torque of the 1HZ compared to the D4D engine is way different and the gearing is accordingly not suitable.
