4Y EFI STEP BY STEP
COREFLY
Town: BLOEMFONTEIN
Vehicle: 2200 4X4 DC
Real Name: MITCH HENDRY
Club VHF Licence: X 59
4Y EFI STEP BY STEP
Post by COREFLY »
I have started cleaning all my parts
Dadz Toy BFI
Re: 4Y EFI STEP BY STEP
Post by Dadz Toy BFI »
Looking good Mitch :thumbup:
Well worth the elbow grease :!:
My plenum and stuff still looks as good as the day it was fitted. :razz:
Paul Grobler
Town: KOEDOESKOP
Vehicle: '12 79 Land Cruiser Pick up 4.2 D
Real Name: Paul
Post by Paul Grobler »
Lyk baie goed watse efi manifold gebruik jy en wat het dit jou gekos ?
5de Rat brights
COREFLY
Town: BLOEMFONTEIN
Post by COREFLY »
The intake I used is from a 3Y imported engin
R200 BUCKS
Paul Grobler
Town: KOEDOESKOP
Real Name: Paul
Can you get more of them
5de Rat brights
BenHur
Vehicle: '96 D/C Raider
Real Name: Bennie
Post by BenHur »
Mitch
Some advice, a wire brush cup on a baby angle grinder requires less elbow grease then the one on a drill and makes the end product more shiny too. ;) But the throttle body is normally make of much softer Aluminium and will damage with the brush but acid based GP cleaner like the ones used to remove cement and grout will work nice to clean the throttle body, but strip it down so the rubber parts of the throttle damper is not damaged
The extra holes like the one there next to the throttle positioning switch and the one at the back where you now have the blank off plate can be closed up neatly by using welsh plugs obtainable from most spare shops.
swartvark
Town: Gordons Bay
Real Name: Tiaan
Post by swartvark »
Good job!! I'm also interested in going the EFi way. So I'll be checking out your progress.
Thanks. :thumbup:
MUD........GLORIOUS MUD!!!!!
NEED A CAR?
talk2tiaan@gmail.com
0829294028
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Post by Mr_B »
More' Mitch!
Looking good! I think I need to take the trouble and remove mine and give it a good clean!
Hope you didn't damage the coffee table!
Mr B
Hi-Hilux
Town: Tsumeb
Real Name: Trevor
Post by Hi-Hilux »
looking good, keep going!
Vla-Wa
Town: Tzaneen
Vehicle: Hilux 4x4 1990
Real Name: Wikus
Post by Vla-Wa »
:thumbup: Dit lyk netjies, teen daai prys kan mens dit oorweeg, ek glo as mens al die stap vir stap fotos kyk van BenHur en Mitch kan n mens dit self doen.
COREFLY
Town: BLOEMFONTEIN
Post by COREFLY »
I think the grinder should work better,I can feel in my arm today
I reakon doing most off the work myself will be much cheaper
Its gonna take much longer to do,but thats the fun part
Waiting for my goodies to arrive and can then also start cleaning up .... will also have to source an ECU somewhere. :wink:
COREFLY
Town: BLOEMFONTEIN
Post by COREFLY »
Got my ECU today
What? How much? Where?
COREFLY
Town: BLOEMFONTEIN
Post by COREFLY »
4 FREE a mate off mine had a Dictator fitted to his ARTI CAT,he took it off when he sold it,he said i can have it,only prob its set for one piston or something ,wil figure it out...
Dadz Toy BFI
COREFLY wrote:4 FREE a mate off mine had a Dictator fitted to his ARTI CAT,he took it off when he sold it,he said i can have it,only prob its set for one piston or something ,wil figure it out...
Not a prob, just change the Setup. :ugeek:
When you're ready to run, one of us will e-mail you a start-up map that'll see you till you take yours to a Dyno :P
Just saved yourself R2.5k there Mitch :thumbup:
lekker! ... hope you can sort it out.
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Post by Mr_B »
More' Mitch...
Is the whole wiring loom still in tact(not cut)??... if it is, then I would suggest you order a new universal wiring loom from Dicktator, else you may well run into trouble with wires that are cut too short, and the last thing you want is multiple solder joints/joins on the same wire... the less joins the better... less chance of elec faults!
Oh and you still need an igniter box... Dicktator makes a very nice looking one, for about R500...
Read more about it here: http://www.dicktator.co.za/ignitermodules.html
It's not a must that you buy a Dicktator one, there are many others on the market that will work 100%, a generic TP100 will cost around about R250... but the Dickie one just looks the part...
Mr B
Dadz Toy BFI
I paid R450 for my new Dicktator Ignitor in CPT :wink:
LouisZ
Post by LouisZ »
Just be carefull with the surfaces where the gaskets go, i.e between the two halfs of the manifolds, trottle body to top intake half and bottom intake half to head.
The cleaning is the hard part, the rest will get easier as you install, try to get the Ecu harness through the firewall before you start bolting on the the intake manifold. The "1 piston thing" you describe is just the programming of the Ecu, here you find plenty solutions for that.
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Post by Mr_B »
4x4megaworldpta wrote:The "1 piston thing" you describe is just the programming of the Ecu, here you find plenty solutions for that.
It's as simple as selecting the right cylinders on the software, when doing the initial setup...
Mr B
BenHur
Real Name: Bennie
Post by BenHur »
If you load a map from Bretton or Rich it will have the correct settings for all parameters allready i.e 4 cyl, ignition devide by 2 etc.
COREFLY
Town: BLOEMFONTEIN
Post by COREFLY »
Is it posible to copy a map exactly,cause the dyno okes in bloem dont work with dictator
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Post by Mr_B »
Mitch, yes u can... to get the engine up and running, but you will have to dyno it... sooner rather than later... altitude alone will mean that Rich and my map won't be 100% for your engine, you could always ask one of the Joburg based guys for a copy of there map, like Big D or maybe Cassie(actually I think he has a 22R), well one of them... will be closer than a Cape Town based map! Street dyno'ing will never be as accurate as a dyno, I managed to get 84kw by street dyno'ing, a proper dyno brought that to 93kw!
COREFLY
Town: BLOEMFONTEIN
Post by COREFLY »
So what will happen if i dyno in bloemfontein and i drive down to the Cape will all still work !!!!
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Post by Mr_B »
Yes, it will be fine! If you intended move to CT permanently, then I would consider a re-dyno at sea level, but if u only coming down to the coast on holiday, then it will be fine!
franco
Town: Middelburg mp
Vehicle: 88 Hilux
Real Name: John
fuel injection for 4y
Post by franco »
Hi
ons het probleem gehad met nog n hilux friend se bakkie wat altyd gesukkel het met inclines.
het by spitronics n kit gekry waar 38weber gebruik vir trottle body met twee injectors,dit werk soos n bom.
het nog nie regtig brandstof verbruik getoets nie maar dit blyk dieselfde as voorheen.
Skakel gerus die mense by spittrinics hul was baie behulp saam.
Jul kan ook die kit op hul web werf sien.
COREFLY
Town: BLOEMFONTEIN
Post by COREFLY »
Sorry already got my Dictator,and because the other okes are using the same it makes it easier to
find problems,
Im just waiting for Mr B to send me that 4y,then i will carry on,Iv got everything,just dont want to EFI my current engine not realy knowing the condition its in,its got 200000km on the clock so I will rebuild the other engin to MR B spec and it should pop out more than 100 kw or maybe 132kw Then I know im running a new EFI 4Y engin
Mr B said something about dropping bmw's
Lets see!!!!!
swartvark
Town: Gordons Bay
Real Name: Tiaan
Post by swartvark »
That kind of power from a 4Y???
My van has 484 000kms on the clock and is struggeling to turn the 33s. Do you guys think I should get an import 4Y with EFI rather than taking on a 7MGE convertion?
I can't wait to see your more, Mitch!
NEED A CAR?
0829294028
Jaco Versfeld
Town: Western Cape
Vehicle: Moms Taxi, 2001 Prado (The Barbie Cruiser)) Sold - Mufasa: '86 Hilux DC 4Y EFI
Real Name: Jaco
Club VHF Licence: X69
Post by Jaco Versfeld »
Difficult one.
I have a Fong Kong 4y + EFI setup + 5.29:1 Diff ratios and 31" tyres. The bakkie pulls amazing. (Ja, I know, I will have to grow up and drive "normal" again sometime.) But I don't know if standard diffs (4.88:1) and EFI will be able to turn the 33" tyres that effectively.
My reasons for staying with the 4y were due to reliability and availability of parts - main focus overlanding. EFI was done in an attempt to try and better the fuel consumption.
swartvark wrote:That kind of power from a 4Y???
franco
Town: Middelburg mp
Vehicle: 88 Hilux
Real Name: John
Post by franco »
Where can i get a intake manifold?
Toybox
Vehicle: Hilex
Real Name: Jonathan
Club VHF Licence: X100
Post by Toybox »
John, the engine importers will usually pull one off an 3y for you. Your closest place is probably Boston japtech in Springs.
franco
Town: Middelburg mp
Vehicle: 88 Hilux
Real Name: John
Post by franco »
Thanks,the guys want the maping for efi i have one for efi system the complete cd,other than yhat you can down load it from the net.
franco
Town: Middelburg mp
Vehicle: 88 Hilux
Real Name: John
Post by franco »
Thanks again phoned around got one for r450 picking it up next week.
