leaf over shackle mod
- Town: Gordons Bay
- Real Name: Luke
Has anyone seen this done,despite the probs with needing longer shocks and maybe modifying the yoke on drive shaft and fiddling with the steering,has anyone done anything like this?
- blom
- Town: Landrovia
- Vehicle: xj jeep & SERIES 3 & Isuzu KB 300 Dtec DC
- Real Name: Blom
Re: leaf over shackle mod
It is called a "buggy spring"
worst mod ever
lotsa axle wrap (LOTS)
clunking sound all the time as spring tutches the chassis
tendency to crack the chassis where attached to the buggy spring (mettal fetique)
spring must be short enough to limit axlewrap, then it's to short to ariculate
been there done that not worth it
Better option is to use revolving shackles (they also have more disadvantages than advantages)
worst mod ever
Grensvegter van LANDROVIA
- Town: Gordons Bay
- Real Name: Luke
ok stupid question but whats axle wrap?and how do revolver shackles work?
- Vehicle: '96 D/C Raider
- Real Name: Bennie
I saw at a a museum the other day that a 18something model "Bokwa" had a similar suspension set up I wondered if they also suffered from axle wrap
- blom
- Town: Landrovia
- Real Name: Blom
Benna van daai donkies was op steroids en het allerande inheemse "grasse" gekou ne
Axle wrap "google is your friend" dis 'n lang storie.
- Real Name: Bennie
Ja vannie donkies het mos op terpentyn geloop. Hulle reken as hy steeks raak dan maak jy 'n terpentyn lappie op 'n lang stok vas en vryf so bietjie aan sy kzaus (so onner die donkie se stert) dan fire hy weer op allie silinders en brand mooi wit. Dan het jy sommer disselboom wrap ook gekry dink ek.
- Town: Gordons Bay
- Real Name: Luke
Right thanks for the sound advice in english
- Vehicle: Hilux 4x4
- Real Name: Driko
Sorry to burst your bubbles guys
the one pic in there is from my truck which i build and drove hard for years
also called a 3/4 elliptic system
when properly designed and coupled with a proper trackbar you have no and i mean no axle wrap , also had some teflon pads on the chassis for it to rest on so i had no clanking noises and i reinforced the chassis - hte truck was built in 2001 and is still running the system
The older the Hilux the more fun it is!!
- blom
- Town: Landrovia
- Real Name: Blom
Nope
It might have worked for you Dirko (and a lot off other okes)
BUT for me personally, NOPE
- Town: Gordons Bay
- Real Name: Luke
Driko could you impart some pearls of wisdom :ugeek: about what you used as the top spring?do have any other pics perhaps of those arms and the pads?also how did you keep the spring from shifting?and how did you reinforce your chassis?
- Real Name: Driko
Dis cool Blom ons het almal ons eie smaak en voorkeure
As for pearls of wisdom ? i dont have the photos anymore of the trackbar but if needed i can draw up a copy if interested PM me and i can get it done for you
