'87 Hilux DC Re-build
Members' DIY projects
pampoen
Town: Gordons Bay
Real Name: Luke
Re: '87 Hilux DC Re-build
Post by pampoen »
Well Knupple even though your journey is not over yet. Thanks for sharing with us. It made the loss of my Hilux a little easier to deal with. Keep up the pics! :thumbup: :thumbup: :thumbup: :thumbup:
TheoM
Vehicle: UZJ 42 LX
Real Name: Theo
Post by TheoM »
Only found this thread now ..... well done Marius !
Knuppel
Town: Somewhere in Africa
Vehicle: '87 SFA HILUX D/CAB
Real Name: Marius
Post by Knuppel »
Dankie Theo, you still happy with your conversion?
Image Link Broken
TheoM
Vehicle: UZJ 42 LX
Real Name: Theo
Post by TheoM »
Very much so Marius.
We just replaced the thermostat, which got stuck in a slightly open position just outside of Calvinia coming back from Kgalagadi in 45 deg temps towing my Metalian Midi.Olive now has 48 000 kms on the clock since the restoration.
Knuppel
Real Name: Marius
Post by Knuppel »
I have also just replaced the thermostat. Had some very strange behaviour but is now sitting at 93 deg running temp no matter what in throw at it. So happy i decided to run a set of VDO temp gauges instead of believing the OEM one. That's the reason I lost the 2uz some years ago.
Great stuff on Olive doing well!
Image Link Broken
Bosfebok
Town: Roodekrans
Vehicle: 1995 Hilux Raider 2.2
Real Name: Otto
Club VHF Licence: X248
Post by Bosfebok »
Kannie wag om die eind produk te sien nie. Gaan een van die mooistes daar buite wees!
Otto X248
1995 Hilux Raider 2.2 EFI Turbo DC
Alucab Canopy with Kitchen and Recovery sections
National Luna Split Charge system and Dual Battery
80W solar panel and MPPT controller
20.5" LED BAR
5ton tow bar with recovery points
Nudge-M front bumper
80l Long Range Fuel Tank
90l Water Tank
Slide Drawer System
Safari Snorkel
Double Lockers - Toyota Electric selectable
Diff breathers
The worst anti hi-jack alarm system ever, SANJI!!
A bad day out is still better than a good day in!!
Knuppel
Real Name: Marius
Post by Knuppel »
Sal nog bietjie moet wag!
Have a small problem at the moment with one of the panels in the load bin.
The PO had a suitcase on the back, he chucked his stompie out the window and it landed on said suitcase on the back. It caught fire and burnt the rubberising off that panel. Do you think we can get paint to stick to that panel without lifting peeling or doing all sorts but look decent :aggresive:
Have had it to bare metal several times now but after each attempt it's a failure.
Image Link Broken
zepplin
Vehicle: Crooza VX 80 EFI
Real Name: Steve
Club VHF Licence: HC 127
Post by zepplin »
Try lining it with toilet paper Marius.................. most $h1t sticks to that........ :mocking:
TheoM
Vehicle: UZJ 42 LX
Real Name: Theo
Post by TheoM »
First clean with Xylene and then use a good quality self etch primer ...
TheoM wrote:First clean with Xylene and then use a good quality self etch primer ...
Either that or sand-blast the exposed area, etch prime and have the rubberising re-done. :think:
Knuppel
Real Name: Marius
Post by Knuppel »
Mud Dog wrote:............................... and have the rubberising re-done. :think:
:shock2: you r :crazy2: :taunt:
Theo :thumbup: Will try
Image Link Broken
I take it that you don't like rubberising. :D:
Knuppel
Real Name: Marius
Post by Knuppel »
Andy, ruberising on a work vehicle is a must, otherwise the load body gets destroyed within 2 to 3 years.
On my pride and joy that took a hell of an effort to get the bin sort of presentable again I think that ruberising it is not the way to go. Those load bodies are scarce and don't think it would make another round of rust creeping around under the rubber.
I am still contemplating on how to protect it, strongly thinking of putting in some marine ply that is fast to remove.
Image Link Broken
TheoM
Vehicle: UZJ 42 LX
Real Name: Theo
Post by TheoM »
It is not the rubberising itself that causes rust but rather the procedure followed during - most companies just grind of the oem paint to roughen up the area and then go at it and so any moisture that gets in will cause rust as the metal underneath is totally unprotected.I chose a urethane based product but after sandblasting the area I firsts sprayed it with Rust Bullet which is also urethane based.The combo of the rough metal and urethane compatabillity made it the perfect solution for inside Olive's tub. Like always do your homework first ...
2c
Marius, it might not mean much, but my experience over the years with different efforts to protect the load bins included stone chip, rubber matting, heavy duty carpeting, those clip together type hard rubber mats and rubberising.
The stone chip or any other coating is only as good as the ability of the coating to resist abrasion and chipping (the quality of all prep work is an obvious given). The loose rubber matting sweated underneath and dust / dirt / fine grit used to get in under there and not only retained moisture but caused abrasion of the paint and subsequently rust spots. The carpet was worse - although no sweating or moisture retension, it trapped dirt having the effect of becoming a scourer - again, paint abrasion. The clip together stuff also scuffed it's way through the paint in places where heavier items were normally loaded. Rough or gravel roads didn't help either.
Rubberising was the most effective - it eliminated the tiresome need to regularly remove matting / carpet and clean underneath and of course stood up to more than a fair amount of abuse.
As Theo said, proper prepping of surfaces is the key. If you were to do all the prep yourself to your standard and satisfaction with a couple coats of rust inhibiting etch primer before sending for rubberising, you already have a matt finish as a 'key' for the rubberising to grip - no need for them to roughen it up and expose metal.
That said, with rubberising you have to occasionally check the edges that it's not lifting / separating (this will normally only happen at points of 'heavy traffic' or if application was done to dirty / oily surfaces.
You might want to reconsider. :winkx:
Knuppel
Real Name: Marius
Post by Knuppel »
Ok, so here are some pics.
I still have the ceiling and the carpets to do, all when time allows and I will update as I go.
My panel beater used vinegar to clean the panel that would not take paint, all hunky dory now :shh:
This build is not the effort of just one person but many people have either worked on it or given moral support during trying times or provide info or spare parts. I want to in particular thank my panel beater for the effort and pride he has put into helping me build this fantastic vehicle. Then also my Boss for allowing me to build it at his work premises. Last but not least..........you guys on the forum and the forum platform for having this thread. This forum and its people has provided me with invaluable information, without it I would still be paying school fees.
Image Link Broken
For now the engine and body outside is done.
Image Link Broken
Image Link Broken
Image Link Broken
Image Link Broken
Image Link Broken
Image Link Broken
Image Link Broken
Image Link Broken
Image Link Broken
Image Link Broken
Image Link Broken
Image Link Broken
Image Link Broken
And the last picture has a rare glimps of the owener I see :wave:
Image Link Broken
Froll
Town: Vioolsdrift
Real Name: Roger
Club VHF Licence: N/A
Post by Froll »
Looking very good Marius, you can be very proud of this masterpiece. :thumbup: :thumbup: :thumbup:
The Legend
Real Name: Dawie
Club VHF Licence: X93-
Post by The Legend »
Baie baie netjiese werk daardie Marius.Jy kan jouself op die skouer klop. Ek hou van daardie rollbar van jou.Van watter bakkie kom hy af - of moes jy een modify om te pas?
Town: inniedorp
Vehicle: Toy
Post by ChrisF »
WOW !!
netjies werk !
Knuppel
Real Name: Marius
Post by Knuppel »
Dawie, ek het die bakkie gekoop met daai roll bar op. Ek het hom net 2duim korter gesny sodat hy nie bo die dak uit steek nie.
Image Link Broken
Image Link Broken
The Legend
Real Name: Dawie
Marius wat is die rede dat jy nie die voorste nommer plaat op bumper vas maak nie? Beter lugvloei vir die Lexus engine ?
Post by Family_Dog »
Looks brand new, very nicely done, Marius!
Knuppel
Real Name: Marius
Post by Knuppel »
Dawie, ja, jy sal ook sien daar is n extra gat in die bumper :D:
Ek ry elke dag werk toe met die bakkie. My roete klim 400m en daar is n paar taai bulte. As ek by die werk stop dan kan ek nog aan die onderste radiator tank vat met my hand.
In my jong dae het ek seker meer as n miljoen killos in SFA hiluxe gery. Dit was meestal 80 % off road en off tar en het altyd gesien dat die oomblik as jy bullbar en extras voor op die voertuig sit dan begin die oorverhittings probleeme. Die temperatuur van die radiator gaan sommer 5 grade op agv n nudgebar.
Het op n stadium duur skoolgeld betaal met n 2.8d wat ek ge-turbo het. Die oomblik dat die bullbar op gaan dan klim die engine se temperatuur. Jy sien dit sommer binne die eerste 40km
Die ventilasie op daai SFA is ontwerp vir rondom 70kw, nou sit daar rondom 200kw in, die hitte opwekking is aansienlik meer.
Op die stadium kan ek met full open throttle ry vir 30 km sonder dat ek n probleem kry.
Ek het my off road toets so 40 % voltooi en sover geen issues. Moet nog bietjie gaan vas sit en bietjie lowrange werk doen om 100 seker te wees dat die fans hulle werk kan doen.
Image Link Broken
Koppelaar
Vehicle: 87 2.2 SC
Post by Koppelaar »
Marius, if you ever consider selling please keep me in mind!
She is an absolute stunner! :drool:
My 87 SC has one of those woven rubber mats in it, the original bak (& paint) is still in beautiful condition - nil rust. Just needs regular removal and cleaning.
Knuppel
Real Name: Marius
Post by Knuppel »
Thanks for all the compliments Guys, I feel honored . I pride my self in doing a job to the highest stardard I can get to. But its still a long way off a Chip Foose job, maybe I make a good aprentice :cooldude:
Image Link Broken
Knuppel
Real Name: Marius
Post by Knuppel »
Louis, thanks :thumbup:
Good to hear a rubber mat works. I really dont mind cleaning on a regular basis and should it get damaged then I have enough spare paint to fix. But still thinking and considering the options.
Image Link Broken
Stunning! Well done! :thumbup:
Jaws
Town: Sharonlea
Vehicle: 2009 D4D 4x4
Real Name: Herman
Post by Jaws »
One of the best SFA Hilux builds I have ever seen.
:thumbup:
Thomo82
Town: London
Vehicle: FZJ80 / LJ70
Real Name: Ryan
Post by Thomo82 »
That looks awesome. You need to post a video or two so that we can hear the motor. :thumbup:
Knuppel
Real Name: Marius
Post by Knuppel »
Ryan, will try but need to find a willing camera man first. :P
Image Link Broken
TheoM
Vehicle: UZJ 42 LX
Real Name: Theo
Post by TheoM »
Very very nice Marius, congrats !
Knuppel
Real Name: Marius
Post by Knuppel »
Thanks Theo!
Image Link Broken
Knuppel
Real Name: Marius
Post by Knuppel »
As you know i put an in tank pump for the Lexus motor
When it was built I chucked a magnet in the tank at the same time.
I developed a very small leak on the tank and this morning I removed it to close the leak.
After 6000Km this is what I found on the magnet.
My tank was rinsed a couple of times before it was assembled the first time so there would not have been many shavings left after working on it. I can't say nothing was left but NOT the amount you see in the picture.
This demonstrates the value of an in-tank magnet, whichever way you want to argue, own metal shavings or metal shavings from outside, it stops right there
After close inspection of the shavings it is clear that some magnetic stuff comes out of a fuel tank (Underground) that has rust in.
Image Link Broken
Image Link Broken
Image Link Broken
Image Link Broken
zepplin
Real Name: Steve
Post by zepplin »
Clean outside but filthy inside...tsk tsk.
Go play in some mud man!!
TheoM
Vehicle: UZJ 42 LX
Real Name: Theo
Post by TheoM »
Nice Marius.
This is exactly why I fit inline filters at both of Olive's tanks prior to the surge tank ... costs nothing and I change them out every 5K kms.If I ever decide to go internal pump on the main tank I will also fit a magnet.
Agteros
Vehicle: Toyota FJ Cruiser
Real Name: Hugo
Post by Agteros »
Al wat ek kan se is hierdie is 'n "beaut".
2020 FJ Cruiser
Reinart21
Town: Secunda
Real Name: Reinart
Post by Reinart21 »
Marius, help gou as jy kan asb.
Ek wil baie graag my outjie opstart, maar ek benodig radiator pyp, en n mens sukkel jou dood om te kry wat gaan werk tussen die kzte rad en die lexus masjien.
Hoe gemaak? Let wel Secunda is aan die gat kant van MP en hier lyk nie na mense met hulpsame vaardighede wat dit aanbetref nie.
Ek hoor graag.
Knuppel
Real Name: Marius
Post by Knuppel »
Reinart, ek het 70% van my bestaande pype gebruik. My bakkie het n WL conversion gehad en die pype was nog nuut Die ander het ek staal tussenin gesit en ek is in die bevooregte posisie om n stoor vol allerhande pype te he.
Miskien moet jy stuk draat vat en dit buig soos benodig en draf jy scrap yard toe en gaan krap daar. Onthou nuwe voertuie val ook om. Kyk by die toyota's, hulle pype is min of meer almal dieselfde size.
Die pype wat van my KZ radiator afkom was die selfde size as die pype wat nog op die lexus was toe ek hom gekoop het.
Image Link Broken
Knuppel
Real Name: Marius
Post by Knuppel »
Ok some feedback:
I have travelled 10 000 km now since first startup.......according to the odometer I have done 110 000km :twisted:
Evidence that someone had his fingers in there at some time to facilitate a haircut, but i knew that when i bought the vehicle. No ways a 29 year old SFA with the amount of use only has 250 000km on.
So far i have only had one breakdown when a fuel hose clamp poped, It was a wurth clamp and did not expect that.
5min later i was up and running again.
We have removed the tank about 9 times due to a fuel leak. eventually figured that the fuel was creeping along the threads of the bolts that hold the fuel pump canister onto the tank. Braised the heads so that the bolts now became studs and problem solved.
Now came the suspension upgrade.
What a mission, in out in out in out...... change blades, change shocks, change blades again, new u-bolts, new blades and so it continued.
Too hard too soft, bump steer, wandering on the road, you name it we did it and changed it 20 times. Eventually we got to a point where it became acceptable. Problem with these old SFA hiluxes is that if you make it soft then the vehicle needs stabilizer/sway bars which all modern vehicle have that have a nice soft ride. So we made the ride harder until the point we had good a balance between ride comfort and sway.
Somewhere in between the bakkie also got a Gearmax Diff with gearlock that was bought from Claud here on the forum. :cooldude:
Next on the list was the rear propshaft. Had some strange vibrations although it was a newly built propshaft.
had the prop shaft rebuilt and rebalanced 4 times at the same place. Eventually I went to two other propshaft rebuilders and one guy stood out and promised to work with me to fix the prop shaft.
Two days later I had a vibration free shaft. I also made a solid shaft but the competence of the first rebuilder went into making that so it vibrates. Will send it to the good guy when I have some time.
Other than the above and a few rattles that have been sorted out the vehicle is my daily ride and I am a happy camper. I get 7.5km / lt if driving sensibly. Will change the diff ratios as time allows and the right deal comes past.
Image Link Broken
TertiusK
Town: Oudtshoorn
Vehicle: 1990 Hilux 2.4D 4x4 DC Full MIKEM Suspension front and back + 2007 Kia Sportage 2.0 CRDI 4WD
Real Name: Tertius
Post by TertiusK »
Hier is darem blerrie harde werk in die bakkie.
Regtig n mooi voertuig waarop jy met reg kan trots wees. Kleur pas hom 100% hy staan sommer uit!
Well done Marius.
Knuppel
Real Name: Marius
Post by Knuppel »
Dankie Tertius!
Image Link Broken
Yep, a real beaut. Drive it with well deserved pride! :thumbup:
Town: inniedorp
Vehicle: Toy
Post by ChrisF »
Marius GELUK met n puik voertuig !!
petri oosthuizen
Town: bethlehem
Vehicle: 98 Nissan Patrol GRX, 1996 Hilux 2,4 D S/Cab SFA, 2007 Merc CL 500
Real Name: petri
Post by petri oosthuizen »
Marius - nice bakkie die!!
Daai body work is net AWESOME, man, al die panels line 120% op - jy moet daai panel beater toesluit, ons gaan hom kom haal!!!
" Fear?? Looking over at Joe Louis' Corner, and knowing Joe wants to go home early tonight"...….Max Baer
Marius, how many GTiIs have given you "the look" when you left them standing at a robot after it turned green? Priceless!! :)
Knuppel
Real Name: Marius
Post by Knuppel »
Dankie Petri!
Eric, daars niks lekkerder as om die manne op hulle neus te laat kyk............maar die agter tyres raak nou al bietjie klaar van al die pak uit deel :P
Image Link Broken
Doesn't matter - it's FUN!!! :yahoo: :yahoo: :yahoo:
spyker1975
Vehicle: Toyota Hilux 4x4 d/cab 7GME6 & Marlin Crawler
Real Name: Craig
Post by spyker1975 »
Hi Knuppel,
Het jy die body en die bak gelift of net die body?
Laat my my weet asseblief.
Dankie,
Soutie
dd6
Vehicle: 1995 SFA
Real Name: Jaco
Post by dd6 »
Craig, dit lyk of Marius 27 Jan 2020 laas op die forum was.
Ek vermoed jy sal dieselfde spacers op die bak moet gebruik as onder die body.
Knuppel
Real Name: Marius
Post by Knuppel »
Marius loer nog so nou en dan, en hy kry nog boodskappe as daar vrae is. :D:
Craig, bak en body gelig, anders pas die lyne nie so lekker oormekaar.
50mm voor en agter gelig.
Image Link Broken
Return to “Build your own:”
