Hi Guys
I see many of you are getting into the solar thing and would like to pick you brains.
I want to get a 10W or 15W smallish panel and use this in conjuction with a regulator to charge my 12V 7AH batteries.
I also have a AA battery charger which has a 12V input for charging in the vehicle, ideal would be to also use the same solar setup to charge penlight batteries via this battery charger.
Would the above be possible with a solar panel and regulator (say a 3A or 10A)?
Solar charging 12v 7Ah battery
- Town: Potchefstroom
- Vehicle: SRX 2.5 4x4 D/C
- Real Name: James
Re: Solar charging 12v 7Ah battery
Yes. No problem. However, you will find the 15W too light if the battery goes somewhat flat for whatever reason.
We prefer using a 30W and 5a charge controller. Keeps it nice and full at 14.2V
James Cameron
0834431879
0834431879
- Town: Durbanville
- Vehicle: 2010 Toyota Fortuner 4x4
- Real Name: Richard
Thanks James, is this because the 30W supplies more amps and when the battery is very flat it needs the additional amps to kick start it?
- Real Name: James
Correct. A 15w PANEL works adequately if it is installed with a trickle charger. However, if no trickle charger, you will be pulling your hair out soon enough. You can always be safe on over spec of panel as the regulator will do its job. Most people go wrong here.
James Cameron
0834431879
0834431879
- Real Name: James
Sorry, but what are u using the battery for? 7ah is a normal gate motor batt?
James Cameron
0834431879
0834431879
- Town: Durbanville
Understood, thanks.
Yes, normal gate motor. Used to run LED lights, led strips.
- Town: Durbanville
ME again :)
Any suggestions on where one can by these items from in CPT?
- Real Name: James
yip, try The Green Shop in CT
miSolar / World Gaia
Debbie Lambrechs | Sales Representative
Tel: 021 791 0821 | Cell: 084 223 6168 | Fax: 086 512 8665
http://www.worldgaia.com" onclick="window.open(this.href);return false; | debbie@worldgaia.com
James Cameron
0834431879
0834431879
- Niel
- Real Name: Niel
Probeer Setsolar (http://www.setsolar.co.za/contact.htm" onclick="window.open(this.href);return false;) ek koop maar by hulle.
Dan is daar ook Tenesol (http://www.solarpanelsprices.co.za/cate ... ls-prices/" onclick="window.open(this.href);return false;)
en solair direct(http://www.solairedirect.co.za/" onclick="window.open(this.href);return false;)
- Town: Durbanville
Dankie manne!
