And so after a lot of reading and brain picking project the rock sliders has begun. steel bought and all cut up
And the brackets welded up
Well at least a start has been made on the brackets.
WISH ME LUCK AND ACCURATE MEASUREMENTS
Rules are there to make you think before you break them!!! God made man before
woman so as to give him time
to think of an answer
for her first question. COMMON SENCE IS NOT A GIFT, IT IS A PUNISHMENT!! BECAUSE YOU HAVE TO DEAL WITH EVERYONE WHO DOES NOT HAVE IT!!!
Good luck! Measure twice and cut once ...... (not like me, cut 3 times and find it's STILL too short! ). Post pics as you go along!
Life is like a jar of Jalapeño peppers ... what you do today, might burn your ass tomorrow. Don't take life too seriously ..... no-one gets out alive. It's not about waiting for storms to pass. It's about learning to dance in the rain. And be yourself ..... everyone else is taken!
posting as I go along is the idea so that if I stuff up hopefully someone will be able to point it out.
50x10mm flat bar for the brackets and 50x3mm thick square tubing as the slider and 50x3mm round tubing as a side step / secondary slider.
still trying to decide if I want to keep the secondary tubing slider at the same level as the square slider or to slightly raise the secondary slider / step.
comments on this idea welcome
janvg wrote:Are you going to bend the ends? Or leave it straight?
beveled (straight) with recovery points
janvg wrote:Im keeping an eye on this post. Must make for my fortuner....just nearly done with bellyplate...
Please share belly plate details as that and a bashplate are next on the list
Thunder02 wrote:So Obelix is getting sliders,what's Dogmatix getting
hopefully a repaired window washer nozzle pipe (remember post about rat in the kitchen)
and if she behaves maybe a service
and there was that issue with welds that contracted with the heat. So after much ado please refer to previous photographs for updates.
(and there is also the issue of the bedside tables that have to get finished for Dogmatix, ask no questions hear no lies )
Hilux 1 wrote:make sure you pics is the size we all can enjoy please.
hiding the bad welding!!! :evil: :evil:
Okay so you all thought that I let this one die a quite death!!!!!
NOT SO
So now it is the painting and final fitting which will hopefully be this Saturday.
And thanks to Alien that helped with the mounting of the secondary rail.
PRESENTLY DISADVANTAGED Custom built Rock Sliders, Bumpers, Belly protection.... Anything you can think of Cell: 076 122 3744 E-Mail: fpanaino@gmail.com Bear Grylls calls it "Ultimate Survival", overlanders call it"Camping"
Oupa Stig wrote:Lyk goed! Prime gou, anders mors die roes jou rond...
TE LAAT!! het al die rust remover gekoop
About ten welding burns
Hundreds of welding splatter burns
Lip from Dogmatix
Not sure how to price the above but that can be offset by the sense of accomplishment
The rands value will be About R1500.00 thats including consumables, paint etc.
