Hi all.... I've got a hilux d4d double cab. Fitted Efs suspension last week and got 265/70/16 bf Goodrich Tyres.
Tyres are Good for another 30k kms . What tyre size could I go for when I do replace?
Any other brand to consider ? Need an AT tyre.
What size Tyres for 3.0 d4d with Efs suspension?
- Town: jhb lenasia
- Vehicle: hilux legend 40 4x4
- Real Name: riaan
Re: What size Tyres for 3.0 d4d with Efs suspension?
Auto or manual??
- Town: jhb lenasia
- Real Name: riaan
Auto. 4x4 legend 40 Nogal lol!
If Auto stick with more or less the std size. The Auto gearbox on the D4D doesnt handle the change in ratios with bigger tyres so lekker.. Legend 40 or not...
- Town: jhb lenasia
- Real Name: riaan
Thanks .. Will 285/75/16 not work?
They will probably work. At least they will "fit" but the gearbox will start hunting... Rather go for 265/75x16 in stead of the 265/70x16 you have as standard. That was the advice I got from the guys in the know... I also wanted to go bigger or go homer...
- AmadaXtreme
- Town: Centurion
- Vehicle: Fortuner d4d 4x4
- Real Name: Cobus
You need a 4" / 100mm lift to fit 285/75R16's in a Hilux - there is a huge difference between the 285 and the 265
I've got 265/75R16 Maxxis 764's on my Fortuner and the work great with a 75mm lift... but with the wider rims, they still touch at full lock
AmadaXtreme Cobus 071 641 7947 or Rory 072 759 2926
Suspensions
Suspensions
