Pipe bull-bar made from roll-bar
Members' DIY projects
mosteran
Town: Springbok
Vehicle: Fortuner 4x4, 1994 Hilux dbl cab 4x4
Hi there,
I'm busy building a bull-bar made out of an old sfa roll-bar.
I would like to share it with you. But I cannot upload any photos.
Is there someone I can mail it to,to share on the forum?
You can mail to me ..... andy@hilux4x4.co.za
Also have a look at this topic for future use to upload pics.
mosteran
Town: Springbok
Thanks Andy,
The problem is that I only have my cellphone and its difficult to navigate a post with pictures.
When I'm finished I will mail you the pictures and short story.
Thanks in advance
Pleasure! Will watch out for your mail. ;-)
Froll
Town: Vioolsdrift
Real Name: Roger
Club VHF Licence: N/A
:subscribed:
MOFASA
Real Name: Johno
Club VHF Licence: X119
:subscribed:
ImageImageImage[rimg=206x128]
Still no mail.
Hilux 1
Real Name: Tertius
Club VHF Licence: HC137
:siffler: :stir: :alarmclock:
mosteran
Town: Springbok
Sorry guys, still busy with the bull-bar.
Will mail Andy as soon as I'm finished.
Now busy fitting the recovery, and lift points.
Still need to do a lot of grinding to make my welding lood good.
Then prime and paint.
Hopefully I'll be finished end of the week. :beg:
Huismoeles
Town: Bellville
Vehicle: V8 Disco 1
Real Name: Dirk
Sit solank fotos op van die begin tot nou
Hilux 1
Real Name: Tertius
ja komaan. die spanning van wag maak my mal :excited: :excited: :crazy2: :crazy2:
MOFASA
Real Name: Johno
:siffler: :subscribed: :cards: :focus:
mosteran
Town: Springbok
:surrender:
Sal more oggend gou vi andy paar fotos mail.
MOFASA
Real Name: Johno
:subscribed: :alarmclock:
Huismoeles
Town: Bellville
Vehicle: V8 Disco 1
Real Name: Dirk
:ttwwp:
mosteran
Town: Springbok
:thumbup:
Mailed some pics to Andy.
Just waiting for him to post them
:beg:
Hilux 1
Real Name: Tertius
:yahoo: :yahoo:
Received and resized ...............
(21.18 KiB) Downloaded 1787 times
(19.61 KiB) Downloaded 1787 times
(21.54 KiB) Downloaded 1787 times
Hilux 1
Real Name: Tertius
brilliant idea and looks great
MOFASA
Real Name: Johno
:think: Looks good
How are you mounting it?
I think your recovery points might be a bit flimsy.....
Looks like you will be pulling in line with the 2 bolts on each side.....
Look at placing a 8mm to 10mm plate running along or under the chassie and bolt through it into exsisting threaded holes in the chassie.
That will give you the sideways strenght of the HT bolt (bolt rating 8.8 no less)
Just a thought.... :thumbup:
mosteran
Town: Springbok
Thanks Andy, will send the rest as I go along.
I think for a sparky on his first try its not to bad.
Yes Johno, I don't have any experience with metal and welding strengh.
Will see what happens and if it fails, I will go back to the drawing board.
The recovery points is just there to get the brake down landdrovers out of my way
:mrgreen: :mrgreen: :mrgreen:
mosteran
Town: Springbok
the square tube at the bottom was part of the old bumper, so mounting it on the existing four threaded points on the chassis. Johno, are you talking about the force on the recovery point on a sideways pull?
swartvark
Town: Gordons Bay
Real Name: Tiaan
Ek laaikit. Goeie werk! :thumbup:
MUD........GLORIOUS MUD!!!!!
NEED A CAR?
talk2tiaan@gmail.com
0829294028
MOFASA
Real Name: Johno
The way up imounting now will only pull directly inline with the bolt so you relying on the thread alone....
Is you have bolts going through a plate vertical to the horizontal pulling line they are stronger......
MOFASA
Real Name: Johno
Look at basic drawing.....
Bolts can be added on the side or under the chassis......
Try use existing threaded holes on the chassis side or under it.... :thumbup: :thumbup: :thumbup:
(59.06 KiB) Downloaded 1749 times
mosteran
Town: Springbok
Thanks Johno, will modify it....
louis fourie
Club VHF Licence: X101
Andre
Dit lyk goed. Ek het met my bumper weggebly van enige welding op die mountings - alles is gebout.
MOFASA
Real Name: Johno
mosteran wrote:Thanks Johno, will modify it....
:thumbup: :thumbup:
Once you done with that you should not have any problems as long as you use the 8.8 rated HT bolts
Personally I don't think you need to go with bolts .... proper welding is stronger. That said, a lot depends on the wall thickness of the sq tubing and the quality of the welds. Perhaps I'm not seeing it so nicely without close-up pics but what concerns me is the places I've circled ..............
It would have been ideal if the recovery point steel went all the way through to the rear of the sq tube and welded there as well, but what it looks like to me is that you have made butt-joints. This means that the weld or material is able to tear more easily. That's why I mentioned material thickness of the sq tube .... if it's thick enough, 2.5mm or more, it will hold fine. That brings me to the actual welds. The top of the butt-joints (where I've marked them "A" and "B") is the weakest area and that's where they will allow a tear to start (once it starts it runs and rips the whole thing off). Here is where weld penetration / strength is important. I would double up on those welds at about 110amps with a 2.5mm electrode, and 'flow' that weld over a slightly larger area .... top and sides.
The other places I've encircled is the 'inner' corners .... the welds don't look complete ... looks like there's slag or something in there. As I said, I cannot see it clearly on the general pic, so I might be mistaken, but those welds should also be good and continuous with the underside welds along the lift point pipes. That will more than sufficiently reinforce the strength at the bottom.
Otherwise looking good!
mosteran
Town: Springbok
Andy the square tubing wall is 3mm thick and I think my welding is not to bad. Though of maybe putting a thick flat bar on top of recovery point that stretch over the square bar as well. Still deciding.
3mm wall is adequate. Just flow a 2nd weld over the sides like I said and the idea of a strap welded across the top is good, a bit overkill, but it'll make certain that it doesn't tear. :thumbup: (A 20 x 5mm flat-bar strap should do it).
Some more pics received from Andre' ......
(18.72 KiB) Downloaded 697 times
MOFASA
Real Name: Johno
Looks good so far.... :thumbup:
Looks like you have a little more gap under the drivers side light compared to the other side....
Froll
Town: Vioolsdrift
Real Name: Roger
Looks very good Andre'. I also ended up with a gap on the drivers side on the one I made. Will try and sort it out when I strip the truck to spray paint and rust removing. :thumbup:
Fix it with a shim plate on the passenger side. :D:
mosteran
Town: Springbok
:blushing: Dam, I thought you wouldn't pick up on that so quickly. I think the trouble started when I welded the first pipe. My garage floor isn't level. Will try something to sort it out. On another note, work has interfered with my hobby. So the bumper will not be finished today. Will try my best to finish this coming week.
mosteran
Town: Springbok
Finally, fitted the bumper yesterday. Wanted to paint it matt-black but I had the finishing black on my garage shelf. Pics will follow
:yahoo: :celebrate: :yahoo:
GeorgeJvR
Town: Louis Trichardt
Vehicle: 2008 Prado 4.0 V6, 1989 SFA S/C 2.2 1998 SFA LTD 22RE
Andre what engine are you running?
Kom wat wil ek bly 'n Bul!
MOFASA
Real Name: Johno
:subscribed:
mosteran
Town: Springbok
George, its fitted with the WL motor, used in the older ford/mazda bakkies. 2.5 turbo with intercooler.
GeorgeJvR
:thumbup:
mosteran
Town: Springbok
Interesting site. Help to work out the angles needed when working with pipe.
http://snip.awardspace.com" onclick="window.open(this.href);return false;
mosteran wrote:Interesting site. Help to work out the angles needed when working with pipe.
now that is handy
smokintyres
Town: Windhoek
Vehicle: Hilux 4.0 V6, relatively standard; for now...
Real Name: Gernot
now that is handy
2nd that! :thumbup:
Thanks for sharing :thumbup:
Here are the pics ...... Nice, Andre'!! :thumbup: :thumbup:
Thunder02
Town: East Rand
Vehicle: IFS Hilux
Real Name: Neil
Club VHF Licence: HC105
:clap: :clap: :clap:
:drool:
Stunning job :thumbup:
Scout motto:be prepared....
www.4x4direct.co.za
Haboob
Town: King Williams Town
Real Name: Edge
Club VHF Licence: HC129
Very Nice :thumbup: :clap: :clap: :clap:
HABOOB means "Dust Storm"
mcw
Town: krugersdorp
Vehicle: Prado 90 V6 3.4 Auto
Real Name: Martin
Club VHF Licence: X100
:clap: :clap: really good :thumbup: :thumbup:
JJBotes
Town: Witbank
Vehicle: KZ-TE
Real Name: JJ
WOW - Baie,baie nice !!! :thumbup: :thumbup: :thumbup:
:thumbup:
GeorgeJvR
:clap: :clap: :clap: :clap: :clap:
JEEPIE
Vehicle: Official hilux 4x4 club recovery vehicle
Real Name: Shaun
Club VHF Licence: X 43
not to shabby nig
thats now a custom looker
1 of a kind
george
Vehicle: Prado 90 VX 3.4 V6
Club VHF Licence: HC107
Still my favorite design for a bumper. :goodjob:
Hi-Hilux
Town: Tsumeb
Vehicle: 1991 Hilux2.2 ---1987 Hilux D/C Hella 1000, Rancho RS9000XL shocks, Good Year M/TR, Warn Winch, STK bullbar, Extended shacles, Kenwood VHF-SOLD
Real Name: Trevor
Andre, gaan jy omgee s ek jou idee gebruik?
mosteran
Town: Springbok
:thumbup: Hi Trevor, ja gaan mal. Ek kan vir jou fotos mail ook as jy wil. Onthou net dat ek jou hande werk wil sien.
Hi-Hilux
Town: Tsumeb
Real Name: Trevor
Thanx Andre, ek het op my vorige hilux 'n ARB een gebou maar soek iets anders vir die "nuwe" hilux en hierdie een van jou trek my aandag BAIE!
sir shrek
Vehicle: '09 Hilux D/C 4.0 V6 AKA 'BULLET' Hilux D/C 7M-GE aka SIR SHREK(SOLD) Jetta MK5 2.0TFSI
Real Name: Claude
Awesome.
Wat ek die meeste like is die goeie airflow. No restrictions at all.
Maak meer sin as die tipe wat heeltemal toe gemaak word met plaat.
Well done :clap: :clap: :clap:
3" suspension lift 31" bfg muds dual fuel tanks custom bushbar 7M-GE
Rear Diff Lock Custom made snorkel
UGLY LIKE SHREK,STRONG LIKE RUSSIA
Donkey
Town: Johannesburg
Club VHF Licence: X122
Must agree looking wicked and aggresive, also practical :thumbup:
Tumelo Maketekete
Rider
Town: Richards Bay
Vehicle: 1987 Toyota Hilux 4x4 d/c 40mm body lift, KZ-TE Diff with Diff lock, Snorkel, 31" AT tyres , Powered by FORD 3.0 V6 uprated.
Real Name: Luke
:boss: stunning
PROUD OWNER OF A TOYOTA HILUX AKA AMA-HIPZ
Hi-Hilux
Town: Tsumeb
Real Name: Trevor
Andre, hier is my mail stkmetals@gmail.com
mosteran
Town: Springbok
Hi Trevor, het vir jou al my fotos gestuur.
Return to “Build your own:”
