Solar lighting at home
- WayneSchalk
- Town: Krugersdorp
- Real Name: Wayne
- Club VHF Licence: X117
Ek is opsoek na 'n day/night switch maar 12v....
weet iemand of daar so iets is en waar om the koop?
ek krap so paar dinge bymekaar om 'n paar 12v ligte in my erf te sit vir al die donker hoekies. ek het 'n klien solar panel en regulator, en het so paar 7ahr batterrye so kort net 'n d/n switch.
- Thunder02
- Town: East Rand
- Vehicle: IFS Hilux
- Real Name: Neil
- Club VHF Licence: HC105
Re: Solar lighting at home
Why not try a pool pump switch?or am i barking up the wrong tree.
Scout motto:be prepared....
www.4x4direct.co.za
www.4x4direct.co.za
- WayneSchalk
- Town: Krugersdorp
- Real Name: Wayne
Are you talking about the timer? but that is 220v but could be corrected.Thunder02 wrote:Why not try a pool pump switch?or am i barking up the wrong tree.
- Ali3n
- Town: Roodepoort
- Club VHF Licence: B338
Wayne, Try these guys.
http://www.kesa.co.za/12v%20dn.htm" onclick="window.open(this.href);return false;
PRESENTLY DISADVANTAGED
- Ali3n
- Town: Roodepoort
Or these guys.
http://www.led-lights.co.za/lumi-shop/l ... or-switch/" onclick="window.open(this.href);return false;
- Thunder02
- Town: East Rand
- Real Name: Neil
Was not sure myself.WayneSchalk wrote:Are you talking about the timer? but that is 220v but could be corrected.Thunder02 wrote:Why not try a pool pump switch?or am i barking up the wrong tree.
www.4x4direct.co.za
www.4x4direct.co.za
Pool timers have a live feed for the motor or digital clock and a neutral return (220V circuit). Then they have a live in and a switched live out (basically running through a contactor), this can be used for switching 220V or 12V, makes no difference but the contactor is rated .... normally about 16A which is more than adequate for some lighting. Only problem with timers is that they have to be reset after every power failure.
If you cannot get a 12V daylight switch you could get a 220V one and connect it to a small contactor (same as a relay) through which you can run your 12V feed. Another benefit of doing it this way is that you can run other 220v circuits off the daylight switch for any other application that you may want to (as long as you don't exceed the rating of the switch).
- louis fourie
- Club VHF Licence: X101
Wayne
Jy kan ook na 'n besproeings timer kyk. Jy kan dan relays gebruik om die ligte aan/af te sit.
- gavin
- Town: vredenburg western cape
- Vehicle: 2.7 Hilux
- Real Name: gavin
Wayne hoekom kry jy nie n transformer wat van 220v ac na 12 dc toe gaan nie dan kan jy nog die 220v day/night gebruik as jy wil nog planne he ek het baie dis my speelgoed daai
- WayneSchalk
- Town: Krugersdorp
- Real Name: Wayne
gavin wrote:Wayne hoekom kry jy nie n transformer wat van 220v ac na 12 dc toe gaan nie dan kan jy nog die 220v day/night gebruik as jy wil nog planne he ek het baie dis my speelgoed daai
Gavin die is maar om mee te speel, die doel is om van die grid af te wees.
Frisco daai day night 12v switch is als goed en wel, maar is nie IP65 of waterdig nie. bitjie van 'n challange.
