I Desperately need help please...
On the standard aisan carb on my 22R there are three wires. I need to know how to connect these wires please. There is two black wires, the one is the fuel cut off solenoid, the other I do not know, and then there is a red wire for the electronic choke. I would appreciate it if someone could guide me in the right direction on connecting the wires. I need to know where the switch in the picture is connected as well as the choke. The colour codes of the wires after the plug will work (Can trace it in the book from there).
![Image](http://www.outdoor-online.net/hilux/switch.jpg)
Also, on the intake manifold there is a valve of some sort, with two vacuum pipes that splits to three (See the yellow thingy in the bottom right hand corner of the pic). The split leads nowhere. Where should it go?
![Image](http://www.outdoor-online.net/hilux/vacuum.jpg)
Much appreciated!
