not doing the v6 anymore
hilux went in alraedy busy taking out the 4y ( done )
4y efi conversion
- scout
- Town: White River
- Vehicle: 91 Hilux dc -pro comp , arb bb , winch , 33'' muds
- Real Name: Jonathan
4y efi conversion
" Yes I know we are lost , but we are making good time "
Re: 4y efi conversion
Ummmm... confusing Jonathan... so what aren't you doing, what are you doing and what's already been done?
- scout
- Town: White River
started this new thread seeing my other thread name was (v6) and im no longer doing the v6 conversion.
old 4y out - Done
collected gwm 4y efi - Done
old 4y out - Done
- scout
- Town: White River
need to fix the engine mounts
new motor will go in tomorrow
- Attachments
- new motor
- (106.68 KiB) Downloaded 455 times
- hungry for new motor
- (111.25 KiB) Downloaded 455 times
- 519franco
- Town: Richards bay
- Vehicle: 87 Hilux 3L v6 Ford
- Real Name: Franco
good like i guess you gona sell those 33s.
![Image](http://i971.photobucket.com/albums/ae192/519franco/23072010019-001-1-3.jpg)
FORD> Full Off Road Damnation
Sponser: MY DAD
- scout
- Town: White River
no keeping my 33's
had no problems with the normal 4y , so it will not be a problem with the efi motor
- JohanM
- Town: Meyerton
- Vehicle: Prado 120 4.0 V6
- Club VHF Licence: HC126
Johnathan, just a quick heads up on that GWM motor. The design is copied from the 4Y motor, but please do not think that Toyota parts will fit on it, as there is in certain parts a design change that will make it nessecary to get the OE part from GWM itself, but these might be few and far between.
Good luck with the project and enjoy the power. BTW the GWM 2.2 EFI motor produces the following specs:
Maximum Power (kW/rpm) 78kW @ 4600rpm
Maximum Torque (Nm/rpm) 190Nm @ 2400rpm
THE OE 4Y motor with Electronic ignition produced the following with a carb on:
Maximum Power (kW/rpm) 75kW @ 5200rpm
Maximum Torque (Nm/rpm) 182Nm @ 2400rpm
Also the GWM is redlined at 5000 rpm and cuts out on it, which is a lot shorter than the OE 4Y carb fed engines which had a redline @ 5600RPM but could be pushed above it should you had to.
Maybe you will be able to bypass that limiter with an aftermarket ECU, but the GWM motor itself doesn't like to be revved hard at all.
Just some info for you to use.
- scout
- Town: White River
johan thanks for the info -
the way i see it - if i had to redo my 4y R4500 - 5000. ( WAS DUE )
get tit efi'd 10 - 12k?
witch is alot more than what this gwm motor is gonna cost me.
if i get more $ i will TRY and get a toyota 4y - seeing i will already have the efi ?
