step one- pull out pins takes about 20 seconds to do both sides.
step two- enjoy the flex..
step three- replace pins before hitting the tar.
technical- one gains an extra 25mm upward lift and a huge 50mm-100mm huge downward flex. now when i go over axle twisters my rear does not lift sky high when my nose goes into a hole instead my fromt wheel travels far down into the hole leaving the rear wheels on the ground,more traction,more comfort,more extreme 4x4. they are easy to install"DIY" . A true IFS.
i think they are awesome
![Clapping :clap:](./images/smilies/icon_clap.gif)
