Hulp - wie het 'n bead breaker...
- Gerrie
- Vehicle: 1998 Land Rover Disco 1
- Real Name: Gerrie
Hi ouens. Ons soek 'n bead breaker (daai tipe wat jy onder aan 'n Hi-lift jack se poot sit om die bead te breek) vir 'n paar foto's oor hoe om 'n band af te haal.
Wie in die Kaap kan my help? Asseblief!!
- Bushwacker
- Town: Vryheid Natal
- Real Name: Piet
Re: Hulp - wie het 'n bead breaker...
Jy kan die hi lift direk op die band sit en jack, miskien 2 of 3 keer langs mekaar tot dit mee gee
http://www.youtube.com/watch?v=6Ou6YaT5AJM
- george
- Town: Velddrif
- Vehicle: Triton 3.5l V6
- Club VHF Licence: HC107
Of ry/trap hom af met die bakkie Moet natuurlik net eers die spaar opsit
- Royco
- Town: Stellenbosch
- Real Name: Roy
- Club VHF Licence: X88
Personally, I would NOT use a HiLift jack.
Looking at these pictures makes me think....
viewtopic.php?f=14&t=18203" onclick="window.open(this.href);return false;
- Gunta
- Real Name: Mark
You can buy a bead breaker from 4x4 Megaworld. There is nothing wrong with a high lift jack. The problem is you get idiots that don't know how to use it properly. If you know how to use it , it is the most valuable piece of equipment with more uses than a swiss army knife.
- Royco
- Real Name: Roy
I would fall into the camp of "idiots that don't know how to use it properly", so I would not use it to de-bead.Gunta wrote:You can buy a bead breaker from 4x4 Megaworld. There is nothing wrong with a high lift jack. The problem is you get idiots that don't know how to use it properly. If you know how to use it , it is the most valuable piece of equipment with more uses than a swiss army knife.
Guess I need to learn...
- Gunta
- Real Name: Mark
Roy, don't feel bad, one just needs to go on a course to learn how to operate it properly when you buy one. It can be extremely dangerous in the wrong hands. Alot of the stuff is common knowledge, the problem is not everyone has common knowledge. You should ask Thys to do a course down there on how to use a high lift jack.
- Gerrie
- Real Name: Gerrie
Soos my Pa altyd sê: Common sense ain't common...
Ek sal dit ook nie self probeer as iemand my nog nie gewys het nie, maar dan kom die groot vangplek.
As dit jou enigste opsie is in die middel van die bos, dan kom die kennis dat dit wel werk tog handig te pas... Pasop net vir die handle wat terugswaai!
- Gunta
- Real Name: Mark
One thing to remember with a high lift jack is NEVER use one hand.
I beg to differ Mark... it cant peel a potato...Gunta wrote: it is the most valuable piece of equipment with more uses than a swiss army knife.
- Gerrie
- Real Name: Gerrie
I reckon if you strike a hi-lift with the right type of stone, you can get a spark to start a fire? Truly remarkable...
Ons het nou maar besluit om die foto's te neem sonder die tipe bead breaker. Dit is in elk geval nie iets wat jy algemeen kry nie.
- Gunta
- Real Name: Mark
No but you can make mash potato.ThysdJ wrote:I beg to differ Mark... it cant peel a potato...Gunta wrote: it is the most valuable piece of equipment with more uses than a swiss army knife.
- Gerrie
- Real Name: Gerrie
If you don't use the jack correctly, you can also make tenderised face (very much like tenderised steak!)Gunta wrote:No but you can make mash potato.ThysdJ wrote:I beg to differ Mark... it cant peel a potato...Gunta wrote: it is the most valuable piece of equipment with more uses than a swiss army knife.
- Theodorus
- Town: Honeydew Jhb
- Vehicle: HILUX
- Real Name: Theo
Ek is n man met n plan maar het myLUX seer gemaak omdat ek nie my hi lift jack geken het en na hom gekyk om hom uit te figure nie soos ek normaal maak nie ek stem saam vat n tyd en leer hom
I am here: http://maps.google.com/maps?ll=-26.013559,28.025077" onclick="window.open(this.href);return false;
- Gunta
- Real Name: Mark
You get tenderised face because people use one hand and when that handle slips you are in trouble. One should always keep some Q20 so you can spray the moving parts everytime you use it because they get sticky and will cause an accident if it jumps out.
you can also not use it as a toothpick, or a nail file...Gunta wrote:it is the most valuable piece of equipment with more uses than a swiss army knife.
- Gunta
- Real Name: Mark
You dont need it in Cape Town because you okes have no front teef.
you leave my teef out of it... we do have fingernails though...Gunta wrote:You dont need it in Cape Town because you okes have no front teef.
- Gunta
- Real Name: Mark
he he
