1uz to Toyota Gbox (G,W series)
BlumTRD
Town: South Africa
Real Name: David
Post by BlumTRD »
Made some adaptors
Laser cut
Cnc Drilled
Tapped
Twin plate (self centering )
because the other adaptors are single plate
incl gbox bolts and bell bolts
I use howe trowout bearings
but if you want to run std clutch fork etc
i can weld the stud on for your pivot pin
R590 each
NOTE 1U not 2U bellhousing
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Re: 1uz to Toyota Gbox (G,W series)
Post by Mr_B »
David, please excuse my ignorance... but is this adapter plate used for mating the lexus bellhousing to a non-standard(non-lexus) autobox??
BlumTRD
Town: South Africa
Real Name: David
Post by BlumTRD »
Hi Mr B
The adaptor are for the manual box(s)
Yn Hilux old shape
And
98-05 Hilux
But I can make the adaptor
For R154 (supra box) , R151 , R150
Kzte box
And new big box for D4D and 2.7
AM Racing
Real Name: Dylan
Post by AM Racing »
I have the D4D. How reliable is the throw out bearing vs the oem external clutch slave and what clutch would be used with this set up?
Post by Thabogrobler »
David, soos gewoonlik lyk jou goed baie netjies en dis billik geprys!
Vertel bietjie meer vir die dommer ouens(soos ek) wat is 'n throw out bearing en wat is daai braided pyp wat bo jou ratkas uitkom?
En watter ratkas gebruik jy nou op jou Hilux?
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Post by Mr_B »
Tx David, again another question for clarity(for me)... this adapter allow you to use the std 1UZ bellhousing and mate it to the SFA manual box??
I know the guys usually use a totally different bellhousing to match the 1UZ to the manual box. If I'm correct what are the benefits of going the adapter route over the whole bellhousing?
AM Racing
Real Name: Dylan
Post by AM Racing »
Mr_B wrote:Tx David, again another question for clarity(for me)... this adapter allow you to use the std 1UZ bellhousing and mate it to the SFA manual box??
My concern with the complete bellhousing is the quality. If its not made right it can be skew and cause damage and it can crack. Provisional pricing of the bellhousings is around R2500 depending who you get it from. So R590 is a great option. Flywheels around R2400. SO: That is almost the price of a motor :wth:
BlumTRD
Town: South Africa
Real Name: David
Post by BlumTRD »
AM Racing wrote:I have the D4D. How reliable is the throw out bearing vs the oem external clutch slave and what clutch would be used with this set up?
All parts on Howe Trow out can be replaced
o rings etc
But the guys in States and Aus doesn't have props with them
As to Clutch ... 2.7 Hilux or Old supra or 3 Ton Dyna Truck
all depends on the flywheel .
Mr B
my current box are a frankenstein (Old series) R154 with sfa R1fa case transfer (both top shift) running duals .
All Sfa Hilux can bolt up with these adaptor
The reason i'm prefering these adaptors are that the cast Belhousings
From suppliers around does have weak spots , crack , skew etc
Thats why i trust the factory auto belhousing
And its cheaper :laugh2:
Thabo
Dankie Ek sit maar bietjie elbow gries in :thumbup:
Gunta
Town: Johannesburg
Vehicle: 1996 80 series Land Cruiser VX 4500 EFI UK Import. Long range tank, Iron man suspension, ARB Bullbar, Front and rear diff locks, 33" BFG muds, Snorkel and attitude.
Real Name: Mark
Post by Gunta »
Very nice option :thumbup:
Mr_B
Vehicle: Honda Jazz
Real Name: Bretton
Post by Mr_B »
Makes serious sense! One day when I'm in a position to go the V8 route I'll get some from you David...
PERS KERS
Vehicle: HILUX,CRUISER,FORTUNER
Real Name: ALEX
Post by PERS KERS »
David kan ek daai thrust bearing met die pype by jou koop ek wil graag daai sisteem op my bakkie sit. en prys asb
Gunta
Town: Johannesburg
Real Name: Mark
Post by Gunta »
David, just a stupid question. By putting in an adaptor plate doesn't it prevent the the spigot from going in deep enough by the thickness of the plate?
Demon
Town: JHB
Vehicle: Hilux 3UZ vvt-i. Disco 3 V8 4.4 L. G Wagon 3UZ vvt-i . Polo 2.0 converted...Volvo S40 2.0
Real Name: Derrick
Post by Demon »
Nice way to go. Myself I would stick to the internal throw out thrust bearing instead of cutting a gap out the side of the bell to
get the fork thru. You say that you can mate it to a W range box ? My understanding is that the R range box has a longer spigot shaft
and enturn alows for the thickness of that plate. Myself I would not go for a W range box behind a V8, I think the gears will land up in the prop shaft in a few days time.
V8 SOLID
Evert Deyzel
Vehicle: 94 Hilux DC 2.2
Real Name: Evert
Post by Evert Deyzel »
Gunta wrote:David, just a stupid question. By putting in an adaptor plate doesn't it prevent the the spigot from going in deep enough by the thickness of the plate?
+1 :crazy: :thumbup:
92 Hilux dc 2.2
MikeM suspension with 50mm lift
BlumTRD
Town: South Africa
Real Name: David
Post by BlumTRD »
Just an example ,
my old 3rz belhousing are alot deeper
and the auto belhouseing 10.225 shallow
So the the plate 10mm ensures that the spigot still sits in the same
:thumbup:
Evert Deyzel
Real Name: Evert
So correct me if I'm wrong.
What you are saying is that the "total depth" of the lexus bellhousing + the adapterplate is the same as the "total depth" of the standard sfa bellhousing?
Evert
92 Hilux dc 2.2
