Metal Jerrycans for water?
- Town: Jeffreys Bay
- Vehicle: Hilux KZ-TE D/C 4x4
- Real Name: Grant
Does anybody have advice regarding the use of the normal metal jerrycans for water storage?
Re: Metal Jerrycans for water?
As far as I know one can only use the light blue can's to hold water.
- truckin
- Town: Durbanville
- Vehicle: 2006 2.7VVTI Hilux SRX Single Cab 4x4
- Real Name: Juan
the blue one is for water, you'll see the lid is different too, i normaly poor half a teespoon of "jik" into the water when i go on long trips, it helps take out that metal taste, and keeps the water fresher for longerCasKru wrote:As far as I know one can only use the light blue can's to hold water.
“The shinbone is a device for finding furniture in a dark room.”
“When I die, I want to die like my grandfather, who died peacefully in his sleep. - Not screaming like all the passengers in his car -
- 3RZ
- Real Name: Willem Grimsell
I have been using mine for about six years now and would not use anything else. It is coated with what looks like epoxy on the inside and have survived where plastic cans could not.
You are referring to the blue ones nê?3RZ wrote:I have been using mine for about six years now and would not use anything else. It is coated with what looks like epoxy on the inside and have survived where plastic cans could not.
The ones for fuel (green,red and yellow) does not have this epoxy on the inside.
- 3RZ
Correct, dem blue ones.
- Real Name: Grant
These are the metal jerrycans??
CorrectEyeman wrote:These are the metal jerrycans??
The blue ones are for water
![Image](http://www.expeditionexchange.com/wedco/DSC08417.jpg)
- Real Name: Grant
Thanks.
Any views on the plastic jerrycans?
Typically, the following NATO color coding is used:
Color - Use
Red - Gasoline(Lead-replacement)
Green - Gasoline (unleaded)
Yellow - Diesel
Blue - Kerosene
Light Blue - Water (usually labeled)
Color - Use
Yellow - Diesel
Blue - Kerosene
- krazy_kameleon
- Town: Fourways
- Real Name: Rick
I second that! I have 3 (total 60l)3RZ wrote:I have been using mine for about six years now and would not use anything else. It is coated with what looks like epoxy on the inside and have survived where plastic cans could not.
- krazy_kameleon
- Town: Fourways
- Real Name: Rick
better check for kerosene before I think its all water next time :razz:CasKru wrote:Typically, the following NATO color coding is used:
Color - Use
Yellow - Diesel
Blue - Kerosene
