3000D 4x4 - opinions and comments please
hi all,
I've just managed to find myself a 3000D 4x4 DC, 2000 model with 183k on the clock and FSH. I've also got a 2x4 DC 3000D (1999 model) which I've had for 4 years, and the reason I went for the 3000D is for reliability. My 2x4 has 325k on the clock and still goes strong, so I'm expecting good things from the 4x4.
What are your comments about the 4x4? Any weaknesses I should know about?
Regards
Dean
Regards
Dean
Re: 3000D 4x4 - opinions and comments please
Purportedly, the 3000D used to blow head gaskets at around 100,000km... but your vehicles seem to prove otherwise! Maybe you're just a better driver than others ;)
Hi Dean, welcome to the Forum
I do ot see a lot of 3000D on the road nowadays, not sure why?
- Hoppy
- Vehicle: Hilux SFA & IFS
- Real Name: Allan 0721291160
Good reliable vehicle, excelent for sightseeing, you won't miss a thing!
aev@iburst.co.za
When I tell people that the engine will last forever, this is a good thing, 'cos it takes an eternity to get anywhere!
Living at the coast the van is quite usable. However, when I go up to the Reef or the Free State I can def tell the drop in power.
Dean
Dean
- merwn
- Town: Kriel
- Vehicle: 1995 Hilux 4x4 DC
- Real Name: Nick
Hi
Ons het 'n d4d 3000d by die werk (doen rehab op die ou myne wat toe maak)
so ry so 95% in die veld hy het nou 199500 Km op die klok sonder enige probleeme het op sy 180000 Km service sy discs voor en sy dromme agter en sy propshaft gedoen dis al en hy trek nog soos 'n droom as my skip eendag inkom koop ek verseker vir my ook een
Hopps, jy het beslis vanoggend jou 'wize crispies' gehadHoppy wrote:Good reliable vehicle, excelent for sightseeing, you won't miss a thing!
- Spartan
- Town: Vanderbijlpark
- Real Name: Jaco
Personally I am not a diesel fan and a 3.0L four cylinder engine does not make sense, to me that is, If you want a 3.0L go 6 cylinder. M2CW
MOBILITATE VINCERE
Spartan
Spartan
- Bloues
- Town: Roodepoort
- Vehicle: Hilux 2.2 D/C
- Real Name: Solly
Die 3000D 4x4 was min van gemaak, daai tyd het Toyota 'n Turbo gaan bysit op die 3000D watnie baie suksesvol was....hulle het headgaskets gepop.......!!! Die 3000D 4x4 is bietjie lui maar redelik goud werd !!!! Al die is "word of mounth" soos ek by ander kenners gehoor het. Hoop kan jou tevrede stel !!!!
Punt is dis 'n Toyota !!!!!
Bloues
(Nie blou bul maar SHARKS ondersteuner)
Don't fence me in.....
'91 D/Cab 2.2(4y) AKA - Bloues. Lifted Suspension, Dual Battery, 80Liter Freezer, Bridgestone Dueler A/T, 29Mhz Radio, Mud Creeper Winch(Aus), EasyAwn Rooftop Tent, Roofrack, Garmin Nuvi, Long Range Fuel Tank, Jacks+straps for landi recovery.....
As part of my studies (engineering) I worked at Alpine Developments in Pinetown in 1995. I learnt a lot about turbo charging, and shortly thereafter a friend of mine worked there, during the talks with TSA about adding a turbo to the 3000D engine. They weren't very successful ito reliability, but in NA (normally aspirated) form they are apparently quite good. I've had great success with my 2x4 3000D (325k on the clock).
To my mind, if you want a blown engine, 1st prize for reliability is a supercharger (but so expensive). If you're going to go turbo, then intercool it, and do everything you can to get rid of the heat. Heat is the enemy for turbo'd vehicles.
I purposely stayed away from the 3000TD, and spent some time looking for a NA 3000D.
Engine aside, are there any issues/weaknesses with the 4x4 drivetrain?
PS: my 2x4 is still running the original clutch and brake discs!
- Spartan
- Real Name: Jaco
Just remove the water from the turbo too, that helps allot.deanm wrote:do everything you can to get rid of the heat. Heat is the enemy for turbo'd vehicles.
Not that I know off, dude it's Toyota, it is provendeanm wrote:are there any issues/weaknesses with the 4x4 drivetrain?
MOBILITATE VINCERE
Spartan
Spartan
- Town: parklands capetown
- Vehicle: hilux
- Real Name: ian
hi i am in the process of purchasing a 3000d hilux dual cab 4 x 4 99 model and owner told me originally before he purchased it , it had a after market fit tubo fitted by alpine and blew up at 100 000km and was rebuilt by toyota , then he bought it and took it to sac capetown and they told him turf the turbo and and skim the head and put a free flow exhaust on , and he has had it 140 000 km later and says it goes like a boeing , i drove it and i must admitt it pulls nicely better than some kzte models i,ve driven , personnely from my experience with turbos stay away , second hand you don,t know what life it has had ,and the slow speed there,s no better way to see africa doing 120 km and down
- Town: cape town these days..
- Vehicle: hilux
- Real Name: floris
Bought my 3000d d/c 4x4 at 250000 kms - everyone I know said those engines (without the turbo) will last forever....
I only did 6000kms before the engine started using oil, needed a complete rebuild....
I suspect, however, that odo may have been tampered with, since the rest of the body have worked hard....
Went the KZT-route, since that 3000d was SLOW, (it reminded me of my fleetline kombi I had years ago - owners manual reckoned under the 0-100 -spec: N/A - top speed was 96km/h... )
I enjoy it now , I'm also married to it...
- Town: Port Elizabeth
- Real Name: Jonathan
I have one of these...bought with 187 000kms on the clock, now has 252 000kms on it and no problems so far. That engine is great offroad, especially on very steep declines. The only place where it struggles is in the sand because of the lack of power and being a diesel it doesn't rev. It can also be a bit frustrating to drive long distances when loaded. Consumption is great though. They still make this engine (3.0DE) for use in the rest of Africa so it has obviously proven itself over time.
Hi Ozzie,ozzie wrote:hi i am in the process of purchasing a 3000d hilux dual cab 4 x 4 99 model and owner told me originally before he purchased it , it had a after market fit tubo fitted by alpine and blew up at 100 000km and was rebuilt by toyota , then he bought it and took it to sac capetown and they told him turf the turbo and and skim the head and put a free flow exhaust on , and he has had it 140 000 km later and says it goes like a boeing , i drove it and i must admitt it pulls nicely better than some kzte models i,ve driven , personnely from my experience with turbos stay away , second hand you don,t know what life it has had ,and the slow speed there,s no better way to see africa doing 120 km and down
I have 2 of these vehicles, one 4x4 and a 4x2. The 4x2 has 330 000km on the clock and still goes with no problems. I recently bought the 4x4 3000D on the strength of my 4x2 and having just come back on a trip across Lesotho, I'm very impressed with the 4x4. We went up Sani, across to Butha Buthe via Oxbow and then back to Sani via Katse. Average speed of about 30km/h (roads are that bad), and as the first major test of the 4x4 I'm very, very happy.
The low range is superb up to about 40km/h (faster than that and the engine revs too high), and even at those high altitudes, pulls just fine in the low range.
If you can find one with full service history (provable) don't let high mileage put you off. You have a normally aspirated 3litre engine rated at 67kw: it is so understressed! (Stay away from the turbo though!)
I have a joke abt the 3000D: the engine will last forever, which is a good thing 'cos it takes an eternity to get anywhere!
My 3000D 4x4 is my dream vehicle 'cos it goes where I want it to go; it runs at abt 10l/100km; it can be repaired easily and relatively cheaply; spares are freely available and I can enjoy 4x4'ing in remote places with peace of mind.
Dean
PS: I ran my 4x2 on biodiesel for abt 6 months, ranging in mixture from 15% to 100%, and I've had zero issues with the engine or fuel system.
One characteristic that I did notice with both vans: the rear main seals leak, leaivng a small pool of oil on the garage floor. Has anyone else had this problem?
- Vehicle: Toyota Hilux
- Real Name: Elton
Hi Guys
I am new to the forum.
I currently own a '95 solid axle hilux with this motor in it. Yes, the vehicle is very slow, but off road, especially on rough rocky terrain, the vehicle is a dream.
I think, this combination works very well.
- Vehicle: Hilux 3.0 DE D/C 4x4
- Real Name: Irne
Same here, 2001 3000D. A small oil leak - uses about 500ml every 4-6 months. Biggest gripe is the black smoke when the engine is cold. Not so much after it's run for about 10min. Have read somewhere it's due to injector settings. Some other small niggly bits like the interior light always blowing (but I think that's something all hiluxes in this model has). Fuel consumption's not bad either, about 13l/100km in town - 11 on long roads. From the specs this sounds higher than normal, maybe it needs a bit of tuning.
On that line, does anyone know of a good reputable mech who can do not just the servicing, but also fix up the injectors & tune the economy back? Preferably in or around Sandton - FourWays JHB? I've burnt my pocket book too many times (with other cars) using so-called "good" mechanics who did little else than stuff a car which was running fine to begin with, and this being a diesel I don't want just any spanner wielding monkey to touch it.
- Spartan
- Real Name: Jaco
Is the solid axle in the front or rear positionElton wrote:I currently own a '95 solid axle hilux
MOBILITATE VINCERE
Spartan
Spartan
3000D... the phrase 'Going nowhere slowly' comes to mind!
