D4D in SFA
- MonsterLux
- Town: Witbank
- Vehicle: 92 Toyota Hilux
D4D in SFA
So I know this topic has been discussed several times. So lately I searched for all the information on the forum about engine conversion I could get. So the conclusion I made was Horses for Courses. After coming across viewtopic.php?f=92&t=16090&p=178026#p178026" onclick="window.open(this.href);return false; I found my horse for my SFA.
After reading the whole thread I have a question. What will the reason be that he used a prado gearbox instead of a 4x4 D4D gearbox or making up a bellhouse to use the SFA gearbox on the D4D?
Johan
Johan
- TOYOTA 4YEFI
- Vehicle: Land Cruisr 80
- Real Name: Juan
Re: D4D in SFA
HI
The Prado box is a strait bolt on the block of the d4d and the kzte is the same so they fit on the same bellhousing and i think it is a bit stronger box
Hope it answers you question
- Hoppy
- Vehicle: Hilux SFA & IFS
- Real Name: Allan 0721291160
Re: D4D in SFA
Correct, but the front prop exits on the wrong side.
I'm building an adapter to fit my SFA transfer onto the Prado box
- MonsterLux
- Town: Witbank
Re: D4D in SFA
Thanks for the information. So if I understand correctly I am going to need an adaptor for either the prado or kz box to accommodate for the SFA transfercase.
- MonsterLux
- Town: Witbank
Re: D4D in SFA
Hoppy can you please upload a few pics off the adaptor you are bussy with. I would like to use the SFA transfercase because with time I want to install a dual crawler.
- Hoppy
Re: D4D in SFA
The KZTE front prop is on the same side as the SFA, but it's a chain drive transfer, no Crawler gears available, I have a 5-1 Marlin Crawler kit in mine and i want to retain it.
You can also get a D4D gearbox, same as Prado with passanger side exit front prop
- MonsterLux
- Town: Witbank
Re: D4D in SFA
Thank you for all the help Hoppy. I also want to retain my SFA transfercase with the plan to install future marlin crawler goodies. Wouldn't it be less mods if one can keep the current gearbox set up of the SFA and just make a belhouse to D4D?
Sorry for all the questions but I am a rookie in the whole conversions.
- george
- Town: Velddrif
- Vehicle: Triton 3.5l V6
- Club VHF Licence: HC107
Re: D4D in SFA
I am glad hopster is practicing. You are going to build my rig in 2 years time
- Town: Muscat and Midrand
- Vehicle: 2.7 Hilux 4x4
- Real Name: Roelof
Re: D4D in SFA
Hello Johan
The SFA uses the "G"series gearbox (I think).
Prado, D4D and KZTE all use the "R" series gearbox in various configurations, which are a lot bigger and stronger.
I have seen the G series destroyed behind a Ford V6. The D4D has a lot more torque and will make short work of it.
Your best bet will be to use a R series box that can bolt straight onto the D4D motor and then use an adaptor for the SFA transfer to accommodate the crawler gears.
I think Dr. Hoppy will concur.
- MonsterLux
- Town: Witbank
Re: D4D in SFA
Thank you Roelof
So then it would be a R series box with adaptor for SFA transfercase. You guys are the best.
Johan
Johan
Re: D4D in SFA
Die Kz se retkas is dieselfde as die D4D s;n, die transfer is waar die verskil le.
