Pyrometer
bullit
Town: Johannesberg
Vehicle: Toyota Hilux
Real Name: Ryan
Evening all.
I was thinking of fitting a pyrometer (EGT meter) on my lux to monitor the gas temps.
My question is where to source a gauge. I've been to autostle and they only have one sort of gauge available and it's not what I'm looking for.
Has anyone fitted theses gauges and can recommend a good well priced gauge.
FIRSTGEER
Town: King WilliamsTown
Real Name: Tony Geer
Club VHF Licence: HC 109
Hi there Ryan.I have also considered installing a gauge to my vehicle and have shopped around and found out that I can obtain an electronic thermometer and sensor ,which will be installed on the turbo for about R2000.I have also noted that an engine management system which indicates egt temp,water temp,oil pressure and other obtions etc, is available on the market by the name of MADDOG.I have heard good things about this system and I m also considering this obtion.I see it adverstized in one of the local offroad magazines.Happy hunting and keep the forum informed of your observations and experiences regarding this topic.
Knuppel
Town: White River
Vehicle: '87 SFA HILUX D/CAB
Real Name: Marius
Maddogs have rabies but MadMan has an engine management system.
http://www.madman.co.za/" onclick="window.open(this.href);return false;
I can vouch for their product quality and function.
FIRSTGEER
Apologies for calling the system MADDOG instead of MADMAN. I knew there was something mad about the product.
Town: inniedorp
Vehicle: Toy
I have one - will have to check the brand - only gripe is the excessive BLEEEEEEPPPPPP each time you start the vehicle.
Fitting it is also a bit of a discussion point ....
Mine was fitted AFTER the turbo. Common consensus is that it should be fitted between the top and the turbo. The danger with this is that metal filings from the drilling could stuff up the turbo .... some installers let the vehicle idle while drilling and tapping to blow out any filings.
even fitted after the turbo you quickly see the normal operating temeperature range and can easily adjust the alarm accordingly.
Knuppel
Town: White River
Real Name: Marius
Tony No worries, I had a good laugh :thumbup:
Knuppel
Town: White River
Real Name: Marius
@ Chris, the difference by fitting pre compared to post turbo is about 100deg C less on the post side.
bullit
Town: Johannesberg
Real Name: Ryan
thanks guys,
@chris, please let me know the brand.
Tsa
Town: Durbanville
Vehicle: 2010 Toyota Fortuner 4x4
Real Name: Richard
I had the TurboLogix installed on previous KZ and was very happy with it. Had a website and ordered from there, but doesn't seem to be up anymore.
Town: inniedorp
Vehicle: Toy
bullit wrote:thanks guys,
skuus, het vergeet om gister aand te kyk ....
moet iets knoop en die naweek kyk
Hennie2
Town: Krugersdorp - Featherbrooke Estate
Vehicle: 2013 Hilux D4D
Real Name: Hennie
Ek dink nie daai knoop was nie styf genoeg nie.
Knuppel
Town: White River
Real Name: Marius
Met ouderdom vergeet mens tot om n knoop te maak!
Stef
Vehicle: '98 LTD
Real Name: Stefan
Club VHF Licence: X107
Knuppel wrote:Met ouderdom vergeet mens tot om n knoop te maak!
Of jy vergeet waarvoor die knoop was...
Town: inniedorp
Vehicle: Toy
Grapgatte ... :crazy:
thanks for the gentle reminders :siffler:
The following is written on the faceplate:
- Autogauge
- Stepmaster/Swiss
bullit
Town: Johannesberg
Real Name: Ryan
Nice one.
Thanks Chris.
GMan
Vehicle: Toyota
Real Name: Gerrie
Ek is nuuskierig, het jy toe een gekry? Self al rondgekyk en die Madman lyk na die antwoord. Jy koop die guage en voeg dan die senders (sensors) by soos en wanneer nodig. Daar is bv sender units vir EGT, water vlak, water temp ens. Check madman.co.za en ek weet SAC doen al lank installasies.
RiyadhFortuner
Town: Lansdowne
Vehicle: 2015 Ford Ranger T6
Real Name: riyadh
does fitting these affect the vehicle warranty? Some of them need to be fitted between existing pipes, so one has to cut and fit.
Town: inniedorp
Vehicle: Toy
YES, it certainly could be used to void a warantee.
Same as fitting a second fuel filter ....
Strange how going above and beyond to protect your vehicle can be used to void a warantee ....
In fact bad fitment could result in filings going into the turbo and damaging the turbo !!
Fitment by a reputable company such a Dynotech in Brackenfell is certainly the way to go !!!!!!!!!!!!
BUT - why do want to fit this to a vehicle that is under warantee ? NEw vehicles come standard with EGT systems that put the vehicle into limp mode if needed.
You only need this when you chip your vehicle ... which WILL void the warantee (if the dealers see that you fitted a chip)
Tom
Town: Germiston
Vehicle: TOYOTA D/C 4X4 KZ-TE
Real Name: MAURO
Club VHF Licence: ZS6MA
Madman is the way to go.
Vlak vark
Town: Phalaborwa
Landy online is selling mad man egt. Bought mine a few years back from them.
Sent from my HUAWEI VNS-L31 using Tapatalk
Return to “General Mods”
