New fog lamps and old wiring?
Posted: Sat Apr 06, 2019 7:34 pm
by bullit
Hello all.
I have purchased a new set of LED fog lamps that I’m fitting into a custom bumper.
I want to use the current wiring and switch within the vehicle. Just makes sense.
My concern however is that the original wiring is a smaller gauge than what the new fog lights have.
I don’t know what the watts are on the new lights either.
Am I taking a chance using the existing wiring and switch?
Thanks.
Re: New fog lamps and old wiring?
Posted: Sat Apr 06, 2019 8:20 pm
I think the LED's will draw less than the original incandescent lamps so you should be fine with the old wiring. If you're really concerned, use the original wiring to operate a relay and wire the lamps direct to the battery with an in-line fuse and heavier gauge wiring. That's the route I would go anyway because there is no significant voltage drop and the lamps will be a little brighter.
Posted: Sat Apr 06, 2019 9:26 pm
by bullit
Thanks.
I didn’t think of that actually.
Il have to figure the wiring out.
Posted: Tue Apr 09, 2019 10:16 am
by Mars
What are the specs on the new spots?
Posted: Tue Apr 09, 2019 12:39 pm
by bullit
I don’t know what the specs are for the new fog lights. That’s one of my issues.
Posted: Tue Apr 09, 2019 1:40 pm
Do they give the wattage?
Posted: Tue Apr 09, 2019 3:53 pm
by bullit
no nothing on the spotlight or the box they came in.
Posted: Tue Apr 09, 2019 6:37 pm
Try doing a search on the product and see what comes up. They would normally list specs and give either the wattage or the power consumption / draw.
Posted: Tue Apr 09, 2019 7:06 pm
by bullit
If I put my multimeter on 20A setting I read 0,71
VxA=W
Would these spots not be give or take 80 watts
I may be way off though I’m not an electrician.
