Wiring to loadbin
Samurai
Vehicle: 2008 Hilux Raider 3.0 D-4D D/C 4X4
Real Name: Stuart
Club VHF Licence: X209
Wiring to loadbin
Post by Samurai »
Hi!
I want to run 16mm cable to the loadbin of my Vigo. It will have a BH plug at the end that I can attach a "power box" to, which I built.
Where is the best place for the wiring to "enter" the loadbin? I thought of the back left side, as it will be easily accessible...
Drilling 2 holes in the loadbin through to where the light (indicators etc) cluster is? My only concern is the clearance between the 16mm wires and the light cluster itself. I am not sure the light cluster will "fit" again?
Does anyone have another option for me or will it work behind the light cluster?
Many thanks!
"from this day to the ending of the world... we in it shall be remembered. We lucky few, we band of brothers.
For he who today shed his blood with me shall be my brother."
george
Town: Velddrif
Vehicle: Triton 3.5l V6
Club VHF Licence: HC107
Re: Wiring to loadbin
Post by george »
I did mine exactly like that ,but that was on a IFS.
Show us a pick of the inside of that box?
Samurai
Real Name: Stuart
Post by Samurai »
I also did one previously on an IFS (behind the cluster) and it fitted perfectly. I am just concerned as the Vigo's light cluster is bigger...
(71.3 KiB) Downloaded 631 times
(77.24 KiB) Downloaded 631 times
(75.78 KiB) Downloaded 631 times
(96.6 KiB) Downloaded 631 times
george
Town: Velddrif
Post by george »
Netjies :thumbup:
Umpalumpa
Town: Jacobsbay
Vehicle: Hilux 3.0 D-4D DC, 4x4=16
Real Name: Jacques
Club VHF Licence: HC305
Post by Umpalumpa »
Thanks Muis! It looks good.
No to follow the thread as you will be doing mine as well..... :siffler: :siffler:
Just a guy with a passion for 4x4.....
Samurai
Real Name: Stuart
Post by Samurai »
Umpalumpa wrote:Thanks Muis! It looks good.
Hahaha, this IS yours!! :lmao:
Umpalumpa
Town: Jacobsbay
Real Name: Jacques
Post by Umpalumpa »
Yikes..... :slap: :siffler:
koekies
Town: benoni
Vehicle: 4.0 4x4 Hilux
Real Name: corne
Post by koekies »
I ran mine inside the cab, behind the rear seat and I drilled a hole in the wheel arch. Works great. Ps. I only ran " +" and stole "-" on the chassie at the back. Is it wrong. I do have a fuse close to the battery in front.
Samurai
Real Name: Stuart
Post by Samurai »
koekies wrote:I ran mine inside the cab, behind the rear seat and I drilled a hole in the wheel arch. Works great. Ps. I only ran " +" and stole "-" on the chassie at the back. Is it wrong. I do have a fuse close to the battery in front.
I don't think grounding the "-" on the chassis is wrong at all, I did the same with my IFS, also worked great, no problems. As long as the "+" has a fuse as close to the battery as possible, like you say, that's the most important... unless I am missing something!! :lol:
I am also thinking of installing a "cut-off" switch in the engine compartment when the plug is not in use, just in case there is a rear impact on the vehicle, the last thing you want is a short, although there is a fuse :slap:
Hangover
Town: Deneysville
Real Name: Stef
Post by Hangover »
Jyt verskriklik baie geduld om soveel goed in daai klein boksie in te kry.
Hangover(A.K.A die speelding)
1976 FJ45 4x4
1UZ-FE 4.0vvti
2" OME Suspension lift
1.5" Shackle lift
35" Geo MT's
Custom Bullbar
Lockright Locked rear
York OBA
20" LED bar
Nighthawk 100W spots
Dakar
2013 3.0D-4D 4x4 Hilux Dakar
BenRich
Vehicle: Hilux 4.0 V6 4x4 BF Goodrich KM2 MT Old Man Emu Suspension, ONCA Rocksliders, Safari Snorkel, Stofpad Bashplate's National Luna Duel Battery System, Engel Fridge
Real Name: Bennie
Post by BenRich »
I have done my Vigo also. Wire comes out right rear in my case. You can earth on chassis but seeing you are going through all the effort pull negative through as well! Better that way!
Just one thing, why all the fuses in the box. It can be a pain if one blows then you have to open the box every time. Just put one in line fuse in the main cable running into the box. Very easy to inspect and replace. I have blown a couple of fuses (re-inflating my tires as well as other vehicles) especially if you hook your compressor up to the box as I've done.
Samurai
Real Name: Stuart
Post by Samurai »
BenRich wrote:I have done my Vigo also. Wire comes out right rear in my case. You can earth on chassis but seeing you are going through all the effort pull negative through as well! Better that way!
The fuse at the battery will be a 50A or 100A fuse (National Lunar fuse holder).
I think it's better to have each circuit protected with it's own rating. I however do agree it'll be easier to check the fuses when they're not concealed, but hopefully the sockets will not exceed their ratings! :surrender:
BenRich
Real Name: Bennie
Post by BenRich »
As long as you are happy! I think it looks very neat!
Obelix and Dogmatix
Town: ROODEPOORT
Vehicle: HILUX 4.0 V6 4x4 named Obelix, donated to some clown, HILUX 4.0 V6 4x4 named Obelix II Onca front and rear Amade extreme Suspension and under water breathing apparatus
Real Name: Quentin
Post by Obelix and Dogmatix »
Any photo's yet on the completed project?
What pit falls did you encounter? and routing? and would you do anything differently?
Nice pro job on your connection box!! :smile:
God made man before
woman so as to give him time
to think of an answer
for her first question
Samurai
Real Name: Stuart
Post by Samurai »
WQN wrote:Any photo's yet on the completed project?
Hi Quentin, yes, the job is completed!
I will load some photos soon! Since doing the wiring on my Lux, I have done the same on Jacque's Lux (Umpalumpa), and I must say that his was a lot easier and quicker as I knew exactly what to do and where to run the wires etc. The connection box shown here is the one I made up for Jacques (thanks for the compliment!) :mrgreen: . The only thing I need to do is invest in a decent crimping tool! Other than that, no issues! :thumbup:
My connection box is slightly different (this is when I did the same thing for the IFS I used to have), seen here: viewtopic.php?f=41&t=30685 The wiring for the Vigo also runs behind the rear light cluster, the same as the IFS.
Obelix and Dogmatix
Town: ROODEPOORT
Real Name: Quentin
Thanks Samurai
Photo's of the routing (front to back) would be very useful. The link was/is very useful.
God made man before
Samurai
Real Name: Stuart
Post by Samurai »
These are the photos I have so far for the wiring done on my Lux. I will add photos of the wiring route, that runs under the vehicle, when I am back in SA.
This wire connects from the positive terminal of the battery to the fuse holder:
Wire running from the fuse holder to the loadbin. This wire runs under the vehicle next to the fuel line, past the fuel tank along the chassis (not in this photo, but all the wires are run in that black trunking/sheath/beading or whatever it's called)....
...it comes up behind the left rear light cluster.
(239.53 KiB) Downloaded 378 times
And through the hole
The negative wire is grounded on a bolt that holds the loadbin onto the chassis.
Last is the BH plug kept in place with 2 screws
(281.34 KiB) Downloaded 378 times
Hangover
Town: Deneysville
Real Name: Stef
Post by Hangover »
IMHO its not very good practice to use the body/chassis as a neutral wire that far. Especially for higher current applications.. but it does in fact work.
1976 FJ45 4x4
1UZ-FE 4.0vvti
1.5" Shackle lift
35" Geo MT's
Custom Bullbar
York OBA
20" LED bar
Dakar
