Hi folks and a happy Christmas to all!
I've a 2010 3.0 Hilux doublecab and have a pair of OME CS045R rear springs which I bought a couple of years ago anticipating carrying some heavy loads ( they're described as being for a constant load of +400kg). This never happened and it's either a case of flog them or fit them. I don't want to harden up the rear end too much so one thought was to remove the third leaf from the top to reduce the spring rate. Has anyone done this? What kind of ride do you end up with?
I have an ARB canopy fitted with rhino roof bars and internal tubular frame to support the rack - so about 70kg extra.
All the best
John
- Town: Yorkshire Dales
- Vehicle: Toyota Hilux Invincible 3.0 D4D Manual
- Real Name: John
Safari Snorkel
Asfir underbody protection
Inline Diesel filter
ARB hardtop
Africa Outback roofrack
BF Goodrich AT 265/75R16
Africa Outback twin jerry can holder
Africa Outback Hilift jack rack
Africa Outback spare tyre carrier
Heavy Duty OME front springs
Koni Raid Shocks all round
Bull bar
Rear chassis mounted jacking points
Canvas Seat covers
ARB hardtop
Bull bar
Canvas Seat covers
Re: OME CS045R rear springs
Hi John. How many blades are in each pack at the moment? It's common practise to add / remove blades to stiffen / soften the ride but I'm not sure which one it is that you should remove (I'm open to correction, but I think it's the second one from the bottom).
We have a couple of suspension specialists here on the forum who could hopefully give you a more definitive answer if they are still on-line over the holiday season, otherwise you might just have to be a little patient.
- Real Name: John
Hi Andy,
The stack is currently 7 leaves. My googling has revealed a single sentence in the OME catalogue that talks about removing the 3rd from top. No further info given on outcome of removal so input from a suspension fundi would be most gratefully received.
All the best
John
All the best
John
Safari Snorkel
ARB hardtop
Bull bar
Canvas Seat covers
ARB hardtop
Bull bar
Canvas Seat covers
Hmmm .... IIRC the OME rear pack had 6 blades on my old van. Now have Dobinson's (Would swap for OME in a heartbeat) that also has 7 blades on the rear. A bit too hard, but I can live with it for now ..... think it's because the vehicle was set up to accommodate extra weight for over-landing. When I look at the pack lengths, thickness and construction, I would have to remove 3rd from the bottom to soften it a bit.bfgjohno wrote:Hi Andy,
All the best
John
The front has only five blades but that's because ride comfort is 90% determined by the front suspension ..... it could actually even manage with six in my case because of the extra weight (winch / integrated bumper).
- Haboob
- Town: King Williams Town
- Real Name: Edge
- Club VHF Licence: HC129
I have read that to streangthen, add 2nd from top which I did on my previous vehicle with great sucess and no problems. To remove you would probably have to see the current make up of the springs as said by Andy...
HABOOB means "Dust Storm"
- LouisZ
That will be the 3rd one from the Top
That will soften the ride. :razz:
- Real Name: John
Thanks for all the help. Kurt Brunner at 4x4 Megaworld has also confirmed that they often remove this leaf which in effect creates the CS044R
Cheers
John
Cheers
John
Safari Snorkel
ARB hardtop
Bull bar
Canvas Seat covers
ARB hardtop
Bull bar
Canvas Seat covers
