to chip or not to chip
- Town: Paarl
- Real Name: Bester
I am not satisfied with the performance (both fuel consumption and responsiveness) of my 2013 3.0D4D. My previous one, a 2009 model was much better.
Anybody that has some experience with fitting a chip - it this worth it and what chip should I go for?
Hilux 3.0 D4D 4x4
Imagine Trailvan
Imagine Trailvan
Re: to chip or not to chip
I would love to hear what HOPPY says on this topic ....Bester wrote:I am not satisfied with the performance (both fuel consumption and responsiveness) of my 2013 3.0D4D. My previous one, a 2009 model was much better.
Hoppy will say go for it.. he cant wait to get his grubby little paws on my D4D... I am resisting profusely..
Seriously, we have a friend who had a chip fitted, and he is very happy with the results. It doens turn it into a racer, but much better accelleration for overtaking and an improvement in fuel consumption as well. I dont know exactly what chip, but Hoppy will be able to tell you.
- Vehicle: 2008 Toyota Hilux 3.0D4d 4x4
- Real Name: Dewald
My BIL recently chipped his 2012 Fortuner auto, he is very happy witht he chip in it. The one thing he was really impressed with was that whilst driving 120km/h and wanting to overtake, the auto did not kick back to 3rd, but just accelerated from 4th.
WIll try and find out what make.
- Tal
- Town: Kroonstad
- Vehicle: Fortuna
- Real Name: Tal
im running the new Dastek chip, its actually 2 chips
very satisfied
13km/l easy
lot of grunt, better overtaking and low ref power!!
very satisfied
13km/l easy
ONE LIFE.... DRIVE A TOYOTA
- boerbakkie
- Town: Strand
- Vehicle: Toyota 2.5 d4d/dc SRX 4x4
- Real Name: Wilko
- Club VHF Licence: leo
Wat my betref is daar net een ou wat die chip verstaan en dit is Kosie Swannepoel! Sy Nr is 021 949 4566. Het my 2.5D4D na hom toe gevat en die resultate is uitstekend.
- Modder Tekkies
- Town: Malmesbury
- Vehicle: 2.8 Gd6 Fortuner 4x4
- Real Name: Ferdinand
- Club VHF Licence: HC252
My 2007 D4D is deur Swanepoel Racing Developments gedoen. Hy rook nie onder heavy acceleration nie en ek kry op die oop pad by die 13km/l en in die stad 11km/l met al my ekstra gewig op.boerbakkie wrote:Wat my betref is daar net een ou wat die chip verstaan en dit is Kosie Swannepoel! Sy Nr is 021 949 4566. Het my 2.5D4D na hom toe gevat en die resultate is uitstekend.
Die dyno se 147 kw / 425 Nm, maar die manne sê die 2007 motor het oorspronklik bietjie meer uit gesit :shifty:
Ek is baie happy met myne en ken hele paar boere wat van nuut af al chips in hulle D4D's ry sonder enige kopsere.
- Town: cape town
- Vehicle: Hilux 2008 3.0 D4D 4X4
- Real Name: claude
My 2 cents
Ek ook chip by Kosie laat doen dit maak moviese groot verskil in trek krag. Het die naweek my chip uit geplug om net weer die toets of dit verskil maak. En jy kan die veskil voel. Sterker trek krag met chip.
Fuel wise? Nie verskil wat mens kan notice nie. Ek kry 8.5-9.00 km/l op die ooppad. Moet ook bevoeg het suspension lift en bumper, so weet nie hoe verskil dit maak nie
- Town: Midrand
- Real Name: Nishan
my 3.0 d4d was chipped about 5 years ago (before i got it)
on sunday it would not start. Just swings. but a healthy swing.
turns out the issue is the uniQ chip. we removed it and now the van is fine.
however till now it has been excellent. good consumption (better than stock), excellent power and no issues
i get 10 to 11km / L
Real drivers use three pedals
Slightly OT,
On my Kz I had the intercooler and chip done in November 2005. Today, almost 300 000km later, it is still puling like a steam train on meths!
In my case, fuel consumption has stayed the same, keeping in mind I do 90% city driving.
- Vehicle: Hilux V6
- Real Name: Andre
My "new" V6 came with a SAC's Unichip. Apparantly the vehicle was only chipped without doing the branches or decat.
Looking at the towbars fitted front and rear, it was probably done to make towing a boat easier. The Dyno papers was with the vehicle's documents.
What do you make of the results?
- Vigo00012.jpg (63.12 KiB) Viewed 3644 times
- Vigo00011.jpg (65.68 KiB) Viewed 3644 times
- Modder Tekkies
- Town: Malmesbury
You vehicle peak power output is 187 Kw @ 5000 rpm and the torque curve is peaking around 2000 to 3000 rpm and dropping of from 4000 rpm as you gain the numbers on the powerKykdaar wrote:My "new" V6 came with a SAC's Unichip. Apparantly the vehicle was only chipped without doing the branches or decat.
kw = speed/accelleration, Torque (Nm) = pulling power
weet jy of hulle al weer oop is vir besigheid na hul brand ?boerbakkie wrote:Wat my betref is daar net een ou wat die chip verstaan en dit is Kosie Swannepoel! Sy Nr is 021 949 4566. Het my 2.5D4D na hom toe gevat en die resultate is uitstekend.
- Town: Paarl
- Real Name: Bester
Dankie vir al die terugvoering - dit lyk my dit is dan die roete om te gaan. Wat kan mens verwag om te betaal?
Hilux 3.0 D4D 4x4
Imagine Trailvan
Imagine Trailvan
- truckin
- Town: Durbanville
- Vehicle: 2006 2.7VVTI Hilux SRX Single Cab 4x4
- Real Name: Juan
Hi Chris,ChrisF wrote:weet jy of hulle al weer oop is vir besigheid na hul brand ?boerbakkie wrote:Wat my betref is daar net een ou wat die chip verstaan en dit is Kosie Swannepoel! Sy Nr is 021 949 4566. Het my 2.5D4D na hom toe gevat en die resultate is uitstekend.
ek het laas week by kosie n draai gemaak, hulle gaan nog n maand of twee besig wees met die hestel van die gebou...
“The shinbone is a device for finding furniture in a dark room.”
“When I die, I want to die like my grandfather, who died peacefully in his sleep. - Not screaming like all the passengers in his car -
- Town: Paarl
- Real Name: Bester
Hulle kan my glo oor so twee weke help, klink of hulle besig is om iets op te stel in n tydelike perseel
Hilux 3.0 D4D 4x4
Imagine Trailvan
Imagine Trailvan
- JacoBredenkamp
- Vehicle: Hilux 3.0D4D 4x4
Hi Bester PM my as jy nog nie reg gekom het nie, ons doen die Racechip Pro2 en daar is Forum member afslag bertrokke !!!
