Land Cruiser 80GX 16" steel rims - width & offset
Maanskyn
Town: Oudtshoorn
Vehicle: 3.0 D4D 4x4 d/c 2009, 3" Lift, 33" BFG M/T's, 3" JWC Exhaust, EGT gauge, Unichip, Front Mount Intercooler, K&N Filter, Snorkel
Real Name: Manie
Post by Maanskyn »
Does any of you guys know what the width and offset is of the
standard Land Cruiser 80 series GX 16" 6 hole steel rims and if
these rims will fit on the new hilux?
Maanskyn
Town: Oudtshoorn
Real Name: Manie
Re: Land Cruiser 80GX 16" steel rims - width & offset
Post by Maanskyn »
Ok, so I found out that these rims are 8" wide with a +0 offset, which will clear the upper control arm by 17mm more, which will be fine. I just don"t know if it clears the brake caliper. Has anyone tried these steel rims on the hilux? Allan (Hoppy) het jy nogi so iets probeer ni? Of enigiemand anders wat weet of hulle pas??
chopper
Post by chopper »
Manie,
Ek hoop hulle pas op jou trokkie :thumbup:
Indien nie, laat weet my asb - ek is op soek na so 'n stel staal rims (6-gat) vir my GXL
