Fitting a snorkel
- Town: Springs
- Real Name: Heinrich
- Club VHF Licence: X81
Fitting a snorkel
Did this one 2 weekends ago. And it is traumatic to say the least. You have to drill your Hilux full of holes.
Got my hands on a snorkel kit and instead of paying R750 for fitment went the route of fitting it myself. Did some reading on Aussie forums and got to know that with this kit you need to move the template as far forward as possible with your indicator light as the reference point. The template is a bit on the short side and you need to make provision for that.
Those little allen screws that go into the snorkel I used loctite to keep in place as they are then bolted through the fender to keep it in place with lock nuts.
I used an 89mm hole saw to cut the hole where the snorkel has to go into the fender. After that I used a power file to smooth the edges.
I blackened the ends of the bolts that go through the fender to keep the snorkel in place and then pushed it against the body. The template is not perfect so it showed the correct places to drill and only one lined up with what the template showed.
After all the holes where drilled I painted it with white Duco. Then I applied a generous amount of automotive silicone to the holes and around the bolts and rivets. Then I could bolt and rivet everything down.
The bolts supplied to attach the top of the snorkel with top bracket on the A-Pillar had heads there where to thick and they caught on the door frame on opening and closing, so I had to change them for round head 6mm allen head bolts. Now the clearance is fine.
I must say I am rather satisfied with my own installation.
After fitting snorkel I've extracted another 3kw from the engine as it breathes MUCH easier.
Know what you don't know.
Re: Fitting a snorkel
Dankie Heinrich, ek sal dan sommer OOOODS se Tuna bring vir fitment as sy reg is....
Dan kan jy die gate boor en ek hoef nie sleg te voel nie
Lyk baie netjies
Lyk baie netjies
- Spartan
- Town: Vanderbijlpark
- Real Name: Jaco
Is daai voor rim van jou gebuig? of kyk ek maar net verkeerd?
MOBILITATE VINCERE
Spartan
Spartan
- Town: Springs
............... ons kan gesels ..... ek gebruik steeds valium om myself te kalmeer.
Ek het eers begin rustig raak nadat hy op was. Ek sou seker die hele job kon doen in 45minute, maar het amper twee ure gevat want ek het heeltyd met die boor in die hand gestaan en moed bymekaar skraap om te begin.
Ek dink jy kyk bietjie verkeerd Spartan. Rim is beslis nie gebuig nie.
- Town: Springs
Die foto lyk bietjie weird. Jy het my amper laat skrik. :wth:Spartan wrote:Oh ok
Job well done Heinrich. Hoop jy het die gate darem met ietsie behandel so dat die outjies nie roes nie.
- Town: Springs
Thanks Cassie, ja ek het hom met duco geverf, primer en wit. En die gate is goed gevul met auto silikon sodat water en ander gemors nie daar kan inkom nie.
Het niks minder van jou verwag nieTraveler wrote:Thanks Cassie, ja ek het hom met duco geverf, primer en wit. En die gate is goed gevul met auto silikon sodat water en ander gemors nie daar kan inkom nie.
- Town: Springs
Thanks.CasKru wrote:Het niks minder van jou verwag nieTraveler wrote:Thanks Cassie, ja ek het hom met duco geverf, primer en wit. En die gate is goed gevul met auto silikon sodat water en ander gemors nie daar kan inkom nie.
- FUDGES
- Vehicle: D4D 3.0l
- Real Name: A.J.
Baie Nice jyt baie guts
Kan ek myne ook maar bring my hart sal dit nie hou nie
Watse snorkel is dit daai?
Job well done, Heinrich! I feel your pain in regard to making a gaping big hole... at least we only cut 19mm ones and have nice little UV resistant rubber plugs to close them up with if we remove the antennas afterwards when the vehicle is sold ;)
- Town: Springs
AJ, daai ene is van 'n parteverskaffer wat hulle probeer invoer het van China af, maar Toyota handelaars het nie belanggestel nie, toe kry ek hom by hom.A.J. wrote:Baie Nice jyt baie guts
Daai snorkel is ek dink presies wat Duwayne probeer doen het, en ook presies wat jy nou Decleor 4x4 kan kry.
http://www.decleortrailers.co.za/" onclick="window.open(this.href);return false;
F_D, not so much fun to put the drill to the fender. Hurts plenty....
Heinrich MOOI gedoen.
Ek het my hele stelsel agterin self gebou .... maar toe maar betaal dat n ander man daai gate in Elders boor ......
- Town: Springs
Baie dankie Chris. Ek is bly ek het my tyd geneem.ChrisF wrote:Heinrich MOOI gedoen.
- Rieks
- Town: Outjo
- Vehicle: 3.0 D4D
- Real Name: Rian
Baie goei jobbie Henrich! Ek moet se jy't guts! Ek moes twee klein gaatjies in my enjib kap boor om 'n solenoid te installeer. Vra nog steeds askuus elke oggend as ek in haar klim.
Watse Rock Sliders het jy op? Dit lyk interesant
- andrevt
- Town: sasolburg
- Vehicle: raider d4d
- Real Name: andre
bAIE BAIE GOED GEDOEN EK SAL MAAR VERSEKER EERS N PAAR BRANDEWYNTJIES VAT VIR SO N DRASTIESE STAP
Toyota Hilux 3.0 D4D 4x4
Dink dis Uys se sliders daai.
- Tiger7
- Vehicle: TOYOTA HILUX 2.7VVT-I SRX 4X4
- Real Name: Jonathan
Dit lyk Baie nice.
Hoe lyk dit van die kant af met die aantena? Pic asb.
- Town: Springs
Ek sal foto"s bysit in die volgende dag of twee.
Ek was bekommerd gewees oor die boonste bracket, maar hy sit netjies weg van die antenna af. En die antenna druk ook nie teen die rivets nie.
- Blackadder
- Vehicle: Toyota Fortuner 3.0 D4D, Ironman Bumper, OME, Dual Battery, BFG'S, TJM Snorkel, Navstar 220 29mhz radio, LAS Pro Rear Bumper, Frontrunner Roofrack
- Real Name: Thinus
- Club VHF Licence: X82
Dit lyk baie smart. Ek persoonlik sal dalk eerder my eie kind se mangel operasie doen voor ek daai gate boor...
- Spartan
- Real Name: Jaco
Blackadder wrote:Dit lyk baie smart. Ek persoonlik sal dalk eerder my eie kind se mangel operasie doen voor ek daai gate boor...
MOBILITATE VINCERE
Spartan
Spartan
- Town: Springs
Dit is hoofsaaklik Uys se ontwerp op die rocksliders. Met so bietjie aanpassing waar ek gedink het ek kan dit so bietjie beter doen op my Hilux.ChrisF wrote:Dink dis Uys se sliders daai.
Ek het nog nie gedink aan die korrelasie tussen boor en mangels nie....
Ek het 'n Whiskey oorweeg voor die boor, maar toe is ek bang ek boor dalk die linker fender.
- Rieks
- Town: Outjo
- Vehicle: 3.0 D4D
- Real Name: Rian
Heinrich, het jy vir ons mooi prentjies van jou sliders?
- Town: Springs
- Rieks
- Town: Outjo
- Vehicle: 3.0 D4D
- Real Name: Rian
Baie Dankie Heinrich.
Terug na die snorkel!
- Town: Springs
Hier is daardie ekstra foto's wat die boonste bracket wys soos wat hy nou lyk. Verskoon maar die stof, die wind verwaai ons omtrent Maandag is Dreadnought gewas.
- Town: Bloemfontein
- Vehicle: `87 dc 4x4 Hilux (import)
- Real Name: Simon
Hi Heinrich,
Ek het `n voëltjie hoor fluit dat `n snorkel die engine bietjie kan versmoor en ook swakker brandstof verbruik gee.
Wat dink julle manne hier van?
- Town: Springs
Simon, ek dink daai storie is dalk as jy jou vinger in 'n snorkel druk terwyl iemand swem.....
Jy kry BAIE meer lug in die engine in, as jy jou hand voor die ram hou kan jy voel hoe hy suig, na die snorkel het daar nog so paar perde losgekom, en brandstofverbruik is VERSEKER beter.
Ek moes nooit so lank gewag het om 'n snorkel op te sit nie.
- Real Name: Simon
Dis wat ek ook gedink het, want die lug buite jou bonnet is baie koeler en skoner. Sal dan een van die dae vir my ook een moet aanskaf.
Jyt `n baie netjiese werk gedoen daar, pat yourself on the back!
- Town: Springs
Thanks man, ek is dankbaar ek het so lank gevat om alles te meet.
Jy sal nie spyt wees nie, ek reken mens maak die geld terug op die brandstof wat jy spaar.
- Town: Umhlanga Rocks
- Vehicle: 2008 Hilux D4D 4x4
- Real Name: Brent
Thanks for a good topic Heinrich. Still, I can't get it over my heart to take a drill to my Hilux! Does anybody know of someone who can fit a snorkel in the Durban area? I'm prepared to pay, just don't want to take a drill to my baby - who knows how it will affect my karma in my next life...
- Sebata
- Town: Cosmo City
- Vehicle: '06 Hilux 4.0l V6 auto 4x4, Iron-Man front bumper, Ali3n Rock-sliders, Old man Suspention, Snokel, 31" Pireli Scorpion Muds
- Real Name: Tau
- Club VHF Licence: X125
That's one heart breaking operation but the end results are awesomeBushpilot wrote:Thanks for a good topic Heinrich. Still, I can't get it over my heart to take a drill to my Hilux! Does anybody know of someone who can fit a snorkel in the Durban area? I'm prepared to pay, just don't want to take a drill to my baby - who knows how it will affect my karma in my next life...
Tau Sello
How does that old saying go? ..... No pain, no gain!
Baie netjiese joppie Heinrich. Nee ek sal self maar moeilik daardie boor aanskakel!!
- Opsmedic
- Town: Port Elizabeth
- Vehicle: 2001 Hilux KZ TE 4x4 D/C and Suzuki SJ413
- Real Name: David
- Club VHF Licence: HC 308
Ek het die naweek besluit om te kyk hoe lyk dit agter my Lux se snorkel. Daar kom ek toe af op 'n nes roeswurms. Ek alles skoon gemaak al die roes af geskuur en toe met rust converter behandel. Die modderskerm toe binne en buite met 'n lagie tectyl gespuit en toe ek die snorkel terugsit het ek twee stainless steel washers tussen die snorkel en modderskerm gesit sodat daar 'n gaping is vir water en stof om uit te spoel as ek die kar was. Hopelik is dit die einde van daai roeswurms.
- Town: Sterkrivier
- Vehicle: Hilux DC 3.0D-4D 4x4
- Real Name: Jo
Hi David, het jy self die oorspronklike instalasie gedoen?
