SFA into KZTE
- Bushwacker
- Town: Vryheid Natal
- Real Name: Piet
SFA into KZTE
I stuffed up the front diff on my IFS, so instead or replacing it with the same thing, I want to go the better way, & change to a SFA. I got good advise from forum members, but I am still confused as to which spares to use.
I want to end up with 33" tyres & a Lexus V8 engin
I have heard that the 2.7 Hilux has the correct diff gear ratio (4.5.5) for this setup, so I use the inner part of the 2.7 (difflock standard) rear diff in both the diffs that I will use in my Hilux.
Will the 2.7's inner fit into my existing rear diff?
What diff must I use as a front diff in my Hilux to fit this 2.7's inner?
Where do I buy these spares at a reasonable price?
Any advice will be appreciated.
- blom
- Town: Landrovia
- Real Name: Blom
Re: SFA into KZTE
Pieta
gesels met ronald "diesel dog" hy het die joppie al gedoen en ek ken Ron al so paar jare hy doen dinge REG
hy sal kan help met die ifs se steering na die sfa toe maw cross over steering
SYNE werk bakgat !!!
Grensvegter van LANDROVIA
- Bushwacker
- Real Name: Piet
Re: SFA into KZTE
Dankie Grensvegter van LANDROVIA
Re: SFA into KZTE
Blom,
Jy weet "verbasend" baie van die Hilux'e, is dit uit pure belangstelling of is dit 'n geval van "ken jou vyand"?
Re: SFA into KZTE
BlumTRD het SFA in sy 2.7 gesit - en baie geleer in die proses. dink net hy is dalk nou in Mosambiek.
O ja, en jou ratkas as jy die Lexus insit? Ek sal dit gratis vir jou wegry...
- Bushwacker
- Real Name: Piet
Re: SFA into KZTE
Thabo, die ratkas gaan ongelukkig bly waar hy is
Re: SFA into KZTE
Ai ou Piet, jy speel nou nie mooi nie!
- Bushwacker
- Real Name: Piet
Re: SFA into KZTE
sorry..
BTW, waar kry ek diesel dog in die hande Blom
- Toybox
- Vehicle: Hilex
- Real Name: Jonathan
- Club VHF Licence: X100
Re: SFA into KZTE
Give Oom Ronald a call on his cell, zero ate too three seven six five three seven ate
- Bushwacker
- Real Name: Piet
Re: SFA into KZTE
Is he not on the forum Jonathan?
- Toybox
- Vehicle: Hilex
Re: SFA into KZTE
He is, or was, but he hasn't posted in a year or so...
- Bushwacker
- Real Name: Piet
Re: SFA into KZTE
I have to move my front axle forward by 60mm for the 35" tyres, so the shackles will be 30mm in front of the bodymounts.
I'm concerned that the shackles will bang against the bodymount. Will it be a problem if I move the shackles to the front mount?
- Town: pretoria
- Vehicle: 911 Carreara MB CL 500 MB 500SEC MB 450 SLC CHRYSLER CROSSFIRE CONVERTABLE SFA HILEX JEEP 5.2 V8 FORD RANGER LEXUS
- Real Name: Fana
Re: SFA into KZTE
Piet why not trailing arms with coils ?
- Bushwacker
- Real Name: Piet
Re: SFA into KZTE
Fana, dit sal so bietjie later kom
Re: SFA into KZTE
Most definitely Piet! That would be a mistake .... the leading end of a leaf pack is always hung and the trailing end is always shackled .... less stress on the mountings and smoother. With the normal set up the wheel actually moves backward a fraction as the spring is depressed, if you invert it the wheel will be forced forward into and against the shock of a bump.Bushwacker wrote:I have to move my front axle forward by 60mm for the 35" tyres, so the shackles will be 30mm in front of the bodymounts.
That "body mount" in the pic will definitely be in the way, so why not hang the shackles from underneath the chassis rail like it is on the rear axle, rather than through the chassis rail like the standard SFA front axle.
- Bushwacker
- Real Name: Piet
Re: SFA into KZTE
Wimpie also sugested this.Mud Dog wrote:why not hang the shackles from underneath the chassis rail like it is on the rear axle, rather than through the chassis rail like the standard SFA front axle.
Thanx for the info Andy, it makes sence
- Toybox
- Vehicle: Hilex
Re: SFA into KZTE
The danger is that you will cause the castor angle to be excessively positive.
- Vehicle: 2008 D4-d Fortuner
- Real Name: Uys
Re: SFA into KZTE
We just completed an SAS on a Ford Ranger. Hilux diff, with Defender trailing arms. Custom coils and Cruiser shocks. The biggest issue was to get the drag ling, tie rod and panhard rod into the vehicle.
- Bushwacker
- Real Name: Piet
Re: SFA into KZTE
I think all the big jobs are over, still a lot of small things to complete.the lexus engin will follow on tuesday. The underside of the door is 780mm from the floor, & the bottom of the rear rim to the wheel arch is 910mm with the 50mm bodylift, 70mm spacer under the leafsprings, extended shackles & 35" tyres I still dont have a powersteering box, but I am working on it...
Re: SFA into KZTE
All looking very, very nice so far Piet, but I really don't like that spacing of the rear axle .... you're going to get some serious axle tramp, especially with the V8 ..... I think even a 4Y will tramp with only a 50mm spacer. You should rather consider extended shackles or OME rear leaf packs to raise the back IMO.
- Bushwacker
- Real Name: Piet
Re: SFA into KZTE
Thanx Andy, I will keep my eye on it. As the funds are available, things will improve.
Re: SFA into KZTE
Try it first, but I'm sure you will still change it later.
- GeorgeJvR
- Town: Louis Trichardt
Re: SFA into KZTE
I've got a 2.2 / 4Y with such a spacer and all I'll say is as soon as I've got the Rands I'll replace the leaves with Mikem or OME...
Kom wat wil ek bly 'n Bul!
- george
- Town: Velddrif
- Vehicle: Triton 3.5l V6
- Club VHF Licence: HC107
Re: SFA into KZTE
Jisie Piet.Dit gaan nou 'n monster wees
- Numbnut
- Town: Vredenburg
- Vehicle: '03 Colt 2.8TDI DC 4x4; Wilderness Offroad Camping Trailer
- Real Name: Daniel
Re: SFA into KZTE
Remember to post all info with regards to what parts were used and costs involved when the project
is finished?????
is finished?????
Everything Works Better When It Is Properly Lubricated...!!!
