BlumTRD
Dadz Toy BFI
Mud Dog wrote:
Not true!.... They do on fact turn on their own individual radii, otherwise there would be some serious scrubbing and tyre wear when turning. The inner wheel, on a turn will have a tighter (smaller) radius than the outer one. It's refferred to as tow in / tow out on turns when this angle is out. It is usually not adjustable and is set in the design of the steering arms. It is achieved by the angle (off from 90º) that is formed between the line of the axle and the line between the stub axle pivot and end of the steering arm. This angle is calculated as a co-efficient between the wheel base length (distance between front and back axles) and the width of the front axle (distance between the pivot points). If the steering arm or axle are bent, this setting goes for a Burton.
U is reicht Chappie :shifty:
So........
If you fit wheel spacers......... what effect on the co-efficient.......:think:
BlumTRD
Town: South Africa
Real Name: David
Steering all sorted , No probs :D
Removed the 50mm bodylift
Got the Propshafts , Both front and rear Double Cardan (Used) but all in good nick
(Blikkies duur). Length to be sorted
Gearbox ready to be fitted , will start on 26/05/2009
Just need the knob for 4x4 . :think:
Currently the complete conversion with 4x4 gearbox cost
R 15850.25 :thumbup:
And Very happy so far . :mrgreen:
BlumTRD
Town: South Africa
Real Name: David
BlumTRD
Town: South Africa
Real Name: David
:thumbup:
Rich, sorry, I just saw this post now. In reply, yes it would have to have an effect (because the radii are altered) but it's usually not or hardly noticeable.
Currently the complete conversion with 4x4 gearbox cost R 15850.25
David, I think that's more than reasonable (actually it's a steal if it's including the box and shafts :wink: ) :thumbup:
cprinsloo
Town: Nelspruit
Vehicle: 1998 D/C 4x4
Club VHF Licence: X52
So........
Apparently Rudolph Ackerman patented this in 1818, it is called geometrically correct steering. As MD said, calculated according to the wheel-base and width. Wheel spacers will not really make a difference you can see or feel.
http://en.wikipedia.org/wiki/Ackermann_ ... g_geometry
1998 Hilux D/C Lexus VVTi
:D: I did'nt know that. As early as 1818 .... amazing! :P
Spartan
Town: Vanderbijlpark
Vehicle: 98 LTD Hilux 4x4 SFA, 2JZ GE L6 VVT-i 3.0i, Bilstein shox, OME and a Land Cruiser 79 series
Real Name: Jaco
BlumTRD wrote:R 15850.25
Dis nie te dronk nie :thumbup:
MOBILITATE VINCERE
Spartan
swifty
Town: Sutherland
Vehicle: Hilux 2.7 SC
Real Name: Martin
David,
Hoekom so stil? :?:
Is die 4x4 box en propshaft al in :?:
Indien wel, was jy al van die pavement af :?: :clap:
Martin
2003 HILUX 2.7i SRX S/C; Solid front axle conversion with Cruiser coil springs, 4.88:1 diff ratios, Iron Man rear suspension with extended greasable shackles, Gearmax diff lock, 150 liter feul tank, NudgeM bumper with recovery shackles, BF Goodridge Baja 33x10.5x15 tyres
Spartan
Real Name: Jaco
Blom
Watse box is daai , lyk amper soos die R150F of R151F :?:
MOBILITATE VINCERE
Spartan
Numbnut
Town: Vredenburg
Vehicle: '03 Colt 2.8TDI DC 4x4; Wilderness Offroad Camping Trailer
Real Name: Daniel
Hi David
I am also contemplating the SAS! Have you fully completed the swap by now with the 4x4 box?
How does she handle on-road & off-road? Also, the wheel hop scenario, any feedback on that?
Lastly, how much did the complete SAS cost you, exluding 4x4 box??
Thx
Daniel
BlumTRD
Town: South Africa
Real Name: David
Some Wheeling Pics And New Mods :thumbup:
En die rot wat saam terug gekom het (maar nie lank gehou het nie) :lol:
Numbnut
Town: Vredenburg
Real Name: Daniel
Feedback on the 2x4 -> 4x4 conversion please??
On the 4th to last pic, it looks as if the front driver side tyre got seperated from the rim, is this true?!
Thx
Numbnut wrote:Feedback on the 2x4 -> 4x4 conversion please??
Thx
Huh? .... I don't see a de-beaded tyre .... are you looking at the pic of the climate control drum fan! :shock:
BlumTRD
Town: South Africa
Real Name: David
:shock: Nope . No de-beading :think:
Never had a prop with beads , even in mosam on .6 :thumbup:
Feeback on sas conversion :
Ifs = :crazy: :lol: :crazy:
SAS = :D: :twisted: :D:
Nico P - Are also busy with a SAS conversion
Numbnut - Some feedback : Its really worth it to do the swap .
Very Easy to do cheap and really reliable , Didn't have any breakdowns or
failures so far .
BlumTRD
Town: South Africa
Real Name: David
Small Update
Will Post pics as things happen
BlumTRD
Town: South Africa
Real Name: David
JJBotes
Town: Witbank
Vehicle: KZ-TE
Real Name: JJ
OOOOOOOOOOOOOOOO. . . .mamma dit lyk NICE !!!!
:thumbup:
NicoP
Vehicle: Hilux 2.7, SFA conversion, 33" Maxxis, 4.5 inch lift
Ja nee die mannietjie is taamlik beisg. Ek het dit gesien en die dinge lyk baie netjies. Kan nie wag vir myne nie,
henribrits
Town: KemptonPark
Real Name: Henri
Hi
This site have some examples of how not to do the steering on a SAS
http://128.83.80.200/taco/scarysteering.html" onclick="window.open(this.href);return false;
BlumTRD
Town: South Africa
Real Name: David
BlumTRD
Town: South Africa
Real Name: David
ON 18/11/2011
50mm Body Lift
Twin Lockers ( E lockers )
Crawl Box 2.28 and 4.70 ( Twin Stick )
1uz 4.0
D4D rear diff (60mm wider than STD ifs Diff)
3.58 Ratio all round
BlumTRD
Town: South Africa
Real Name: David
:excited: :excited: :excited: :excited: :excited:
Haha!! En daar gaan die 50mm lift weer in!!
Lyk my die afdak gaan so 100mm lift nodig he?
Very Nice!
RooiLux
Town: Pretoria-Mayville
Vehicle: 1992 2.2-EFI Hilux 4x4 with Maus conversion,freeflow,Rear Electric Locker'2005 BMW 320i, 2015 Hilux 3d4d dc 4x4
Real Name: Marius
Lekker bakkie die! :thumbup:
Pora
Town: Brakpan
Vehicle: Hilux 2.5 d4d
Real Name: Pora
yis dude disi fer ni
ek will ok sikke leke speelgoed maak
gr8 bakkie like dit moer baie
BlumTRD
Town: South Africa
Real Name: David
Jaco Versfeld
Town: Western Cape
Vehicle: Moms Taxi, 2001 Prado (The Barbie Cruiser)) Sold - Mufasa: '86 Hilux DC 4Y EFI
Real Name: Jaco
Club VHF Licence: X69
What calipers did you use? Are they handbrake compatible?
BlumTRD wrote:Small Update
LouisZ
Daai is jou std Hilux voor Caliper.
BlumTRD
Town: South Africa
Real Name: David
Tig welded stainless steel tank 140 liters with baffels inside . Used all original flages from std tank . Relocating tank to make space for 4 link
Triangulated 4 link setup .
Will be using coils from jeep with 16" air shocks
Front will be radius arms extended 200mm and running a panhard rod .
Coils with 16" air shocks .
Nice!
Waar gaan die tank nou staan?
BlumTRD
Town: South Africa
Real Name: David
Hi Thabo .
Die tank gaan agter op die bak . Net onder die rollbar .
:grin:
BlumTRD
Town: South Africa
Real Name: David
Big D
Vehicle: SFA Hilux 2.2 BFi
Real Name: Deon
Baie netjies David!
Toppie4x4
Vehicle: Hilux 4.0 V6 DC 4x4
Still very very tempting......................looks like a lot of work but I think it is a good upgrade :thumbup: :thumbup:
Toppie4x4
I know there is a guy in Vryheid who did this, anyone know who it is or where the thread is??
