So when I wiggle my steering wheel I can see there is play on the drag link, no amount of adfjustment will sort it out, its poked. Now I have two options, replace relevant parts with one from Toyota or buy or steal from one of the kind forum members. Alternatively I could modify the steering system and fit the following similar part https://goo.gl/G51Ytm that can be adjusted and which might prove to be less of a hassle next time something needs to be replaced.
Any thoughts on this?
In Need Of Some Drag Link Advice
There are a couple of reasons why you have excessive play in the drag link. One will be the cups inside the link ends that are worn - these are replaceable. The second is the ball pin on the pitman and on the "J"-arm (RHS steering arm). I believe that they are replaceable in some cases but if not can be built up and re-machined. If you have it done, be sure to use a reputable engineering works - it's a critical safety issue ..... the last thing you want is the have a ball-pin shear off whilst driving.
So no need to replace the whole drag link (you would only be doing half the job anyway if the balls are worn).
On a side note, treat it with some urgency. You say there is no more adjustment left in the drag-link ends - that tells me that the cups are definitely worn and maybe the ball ends as well. When this is the case the ball-pins start riding on the shank itself, wearing it down and making it weaker, thus more likely to shear.
Best of luck.
Best of luck.
- Tim86
- Real Name: Tim
Those springs in the ends of the drag link and their 1&1/3 turn back from seated adjustment (as per manual) are there to remove small vibrations from the road reaching the steering wheel. I would think that this may also possibly aid in reducing wear on the steering box components. Implementing the tie rod end ball joint setup as in the pic will eliminate this feature and apparently the resultant vibrations in the wheel can get rather tiring, especially on dirt roads I would imagine. I would keep the drag link setup, it's a neat piece of engineering.
A mate of mine had precisely your problem - ends hadn't been greased and the ball-pins had worn away. He had the pins pressed out and new ones pressed in and welded for safety. Depending on what is worn you will only need the four cups and two pins max.
- niclemaitre
- Town: Harrismith
- Vehicle: 87 DC 2.8D
- Real Name: Nic
I got an entire replacement drag link from Gemini Spares, it wasn't very expensive from what I recall, around R300
Happy trails
Nic
SFA '87 DC "Rooies" - sold
IFS '99 DC "Benny"
Nic
IFS '99 DC "Benny"
- Town: Gordons Bay
- Real Name: Luke
niclemaitre wrote: ↑Thu Nov 01, 2018 8:09 am I got an entire replacement drag link from Gemini Spares, it wasn't very expensive from what I recall, around R300
- Vehicle: 1)1989 Toyota Hilux 2.2 4y EFI D/C 4X4 Full Mikem suspension ,extra long range tank,Duel battery system,31 Bridgestone Duelers 697 A\T FJ 75 front disc with KZTE calipers ,Kurisun PT 8100 two way mobile radio Hi-Lux call sign HC 121
- Club VHF Licence: X93-
Geleende foto,s . Ek gaan beslis vir daardie draglink met tirod conversion as die balls op my draglink uitgewerk is.Dit is vir my veiliger.Met tierod ends het jy nie balls wat kan afbreek nie.
Die manne wat erg deelneem aan 4x4 kompitisies het ook vir my gese hulle verander hulle draglinks met tierods. Is baie sterker as die draglinks met die balle op.
- Town: Gordons Bay
- Real Name: Luke
Now here's the million dollar question.... Do you feel a lot of kickback? How is the steering? Talking of the compo guys having issues with them, I know Swartvark has has issues with his draglink, check out https://www.youtube.com/watch?v=UQ16toEp1qo&t=8s at 7:34, In fact when I saw his bakkie recently I see he braised the ends up completely, hoping he might have something to say about that.The Legend wrote: ↑Thu Nov 01, 2018 8:05 pm Die manne wat erg deelneem aan 4x4 kompitisies het ook vir my gese hulle verander hulle draglinks met tierods. Is baie sterker as die draglinks met die balle op.
If you put the tierod at the back of the draglink op top of the G arm and not under it you will not have kickback or steering wheel vibrations.
- Town: Gordons Bay
- Real Name: Luke
Would it be possible to get the details of this arm that you made? What ball joints did you use? thread pitch? Hardened steel? I might even do a write up on it for someone who wants to do the same.The Legend wrote: ↑Thu Nov 01, 2018 7:55 pm Geleende foto,s . Ek gaan beslis vir daardie draglink met tirod conversion as die balls op my draglink uitgewerk is.Dit is vir my veiliger.Met tierod ends het jy nie balls wat kan afbreek nie.
