I am looking for a dual battery system, with good inverter, that is compatible with a solar panel for my 2020 Hilux
Do I go deep cycle or lithium battery?
Thanks in advance for your recommendations
dual battery system
Re: dual battery system
LiFePo battery is the best but expensive.
Will it be a permanent fixture or do you want to build something with removable box.
- Vehicle: Legend 50
- Real Name: Tim
Removable box
Removable box
- Club VHF Licence: X93-
Tim i have a National Luna portable dual battery system charger on which I add a CTEK D250S DUAL which also can be link to a solar panel. I can change any time from one charger to the other one and it works like a bomb.
Will add photos per separate link
Herewith photo of my National Luna dual battery system with CTEK 250S dual charger.
On the big red female plug above the the CTEK charger i connect the 16mm wires with male red plug from the battery. On the small red plug i connect my solar panel
When i want to use the National Luna battery charger i just disconnect the big male red plug and plug it into the National luna red female plug . The National Luna dual battery charger can not be link to a solar panel hence reason why i add a CTEK D250 DUAL battery charger
