Good afternoon were can I get the above shaft for my hilux was told it's worn out were the seal travels..regards minesh
Hilux side shaft 28 spline
- Town: Howick
- Vehicle: fortuner
- Real Name: minesh
Good morning it's a 1989 Hilux has the local.diff thanksSphinx_88 wrote:Good evening Minesh,
What model Hilux do you have? As I will be able to point you in the right direction.
Regards
- Town: Howick
- Vehicle: fortuner
- Real Name: minesh
Thanks Martin for your help..sorry for the late response regards mineshmcw wrote:you can get that shaft from Gearmax they will fit bearing for you as well
the local diff and diff locker is a Gearmax product
Martin
