WHINING NOISE FROM FRONT WHEELS
Alex2539
Town: Walvis Bay
Vehicle: HILUX LEGEND 45 V6 4.0 4X4
Real Name: Alex
Post by Alex2539 »
Hello there!
There is a whining noise from the front wheels(i assume) of my bakkie. (the sound is similar to that of a unlubricated fan belt ). It starts from 40km/h and increases with the vehicle speed. I am suspecting front wheel bearings or what can it be? . Vehicle 4.0 V6 4x4 2015 model
thanks for your help
Bonded to Yotas :cooldude:
Re: WHINING NOISE FROM FRONT WHEELS
I'm assuming that it's present irrespective of engine revs or what gear you're in. If so, then it's got to be drive-train related. A diff will whine from low through to high speeds, so it's not likely to be that. Wheel bearings will do pretty much the same and you would actually "feel" the fine vibration through the vehicle, so from your description I'm doubting that as well.
Of course I'm guessing by what you say, so the above should not be excluded as possibilities. It could still be a bearing in the diff. Maybe CV's. :think:
Another thought .... What tyres are you running and when were they last rotated?
Alex2539
Town: Walvis Bay
Real Name: Alex
Post by Alex2539 »
thanks for the response. BFG ko2 , recently rotated (500km ago), i jacked up the the real wheels put the car in drive till about 80km/h (no noise) . i booked in the vehicle with Toyota for Friday hopefully they will be able to find the fault.
r3aver
Town: jhb
Vehicle: hilux
Real Name: ebrahim
Post by r3aver »
Had a similar issue (but on a corolla!)
Ended up being aged tyres! Not worn.
Rubber was getting hard and caused whining at higher speeds
Alex2539
Town: Walvis Bay
Real Name: Alex
Post by Alex2539 »
After all mine was a worn centre bearing
Sent from my SM-N960F using Tapatalk
