HELP IDENTIFY THE CAUSE
- Alex2539
- Town: Walvis Bay
- Vehicle: HILUX LEGEND 45 V6 4.0 4X4
- Real Name: Alex
Hi there!
I am mechanically challenged... i have noticed that the pipes that goes to the heater is turning "whitish " ..does anybody knows what sign this is or the cause?
Bonded to Yotas
Re: HELP IDENTIFY THE CAUSE
It is a little strange and I cannot give you a definitive answer, but I can hazard a guess.
Both the heater and radiator hoses appear to be of similar construction and if one looks you can see that the radiator hose is starting to do the same thing on a lesser scale. The radiator hose is typically subjected to heating up & cooling down a lot more than the heater hose and my guess is that they are starting to perish. Much in the same way that if you leave a tyre without use, the rubber will perish quicker than one of the same age that is being used daily, I suspect that something similar is taking place between the two hoses.
Either way, I would look upon it as a warning that they are coming up for replacement. If either springs a leak you gonna have problems - diesels don't like overheating.
- Alex2539
- Town: Walvis Bay
- Real Name: Alex
Thanks Mud Dog. I will definitely have them replaced as soon as possibleMud Dog wrote:It is a little strange and I cannot give you a definitive answer, but I can hazard a guess.
Bonded to Yotas
- Dirka
- Town: Doornpoort Pretoria
- Real Name: Dirk
Seen that a couple of times.
Does it rub off? Like powdery stuff?
Could be many reasons for that.
Maybe normal oxidation of the hose, or release agent from the mold when they make the hose, or just the rubber properties going through all those hot/cold cycles. Maybe just normal dirt and grime drying up on your hoses or salt water deposits. Who knows..
Just as long it is not cracked, brittle or leaking..
I would not worry too much about that.
Hosing is cheap anyways.
If you'd like to put something on - I like to use silicon oil
on my rubber. Especially on the door rubbers.
It is inexpensive and does a good job.
- Alex2539
- Town: Walvis Bay
- Real Name: Alex
Re: RE: Re: HELP IDENTIFY THE CAUSE
Thanks Dirka. It rubs off yes , there is no leak or anything....my car doesn't overheat or anything.Dirka wrote:Seen that a couple of times.
Bonded to Yotas
Have done serious mud trails ?
I once struggled to get the mud off ... the "mud" came off quick enough but I struggled with a residue ...
Thats normal, sometimes even with new hoses you buy, some have that white powder on and others not. Must have something to do with either the manufacturing process or the composition of the rubber. If it wipes off I would not replace the pipe unless it gets hard or starts to crack. As I said I bought brand new pipes before with the white powdery stuff on it.
- Town: Midrand
- Real Name: Nishan
could it be that some chemical was used on it during a previous valet and that is now causing the residue?
I dont think its anything serious. As long as the hose isnt disintegrating
Real drivers use three pedals
- Alex2539
- Town: Walvis Bay
- Real Name: Alex
ChrisF wrote:Have done serious mud trails ?
No, i haven't
Bonded to Yotas
- Alex2539
- Town: Walvis Bay
- Real Name: Alex
The pipe feels normal. Thanks Piet.pietpetoors wrote:Thats normal, sometimes even with new hoses you buy, some have that white powder on and others not. Must have something to do with either the manufacturing process or the composition of the rubber. If it wipes off I would not replace the pipe unless it gets hard or starts to crack. As I said I bought brand new pipes before with the white powdery stuff on it.
Bonded to Yotas
- Alex2539
- Town: Walvis Bay
- Real Name: Alex
Thanks all for the responses. I will leave it on and keep a close eye
Bonded to Yotas
- Town: Reebok Kleinbrakrivier
- Vehicle: 2002 Hilux 2.7i 4x4 s/c + Canopy Caravan; Suzuki Brezza
- Real Name: Brian
Check that it's not deposit from your battery. There is normally a breather pipe on the battery which allows the battery to vent low down. Maybe this vent pipe is missing.
- Alex2539
- Town: Walvis Bay
- Real Name: Alex
Thanks, will checkbrianc wrote:Check that it's not deposit from your battery. There is normally a breather pipe on the battery which allows the battery to vent low down. Maybe this vent pipe is missing.
Bonded to Yotas
