Best place to take a sfa for repairs
NathanX4
Town: Meyerton
Vehicle: 1991 Toyota Hilux (4.3) 4X4
Real Name: Nathan
Post by NathanX4 »
Hi all
I have a sfa with a wl conversation in. The motor is great. The problem I am having is the clutch.
First time I installed a standard 2.7 clutch with the wl presure plate from the local midas. After about 8000km clutch shattered to pieces.
Second time round replaced with a special build clutch and presure plate from formula friction in edenvale. Had the flywheel skeemed aswell. After about 15000km clutch went again. After opening it up I noticed that the fork was to short and that it was pressing the thrust bearing skew which coused the bearing to seize which grinded thru the presure plate.
Third time in again got everything specially build and had them source me a better bearing. New fork installed which looked perfect. 500km later something went wrong again. On my way back from work the clutch peddle started vibrating with a knocking sound in sequence with the peddle thumping. Continued my journey home without pressing the clutch peddle.
Got home and noticed the peddle is extremely hard and now clutch at all.
Now I gave up and in need of a expert to help. Who can i contact to help. There must be something i keep on over looking as I need to find the problem.
Borntofish
Vehicle: Hilux 86
Real Name: Werner
Re: Best place to take a sfa for repairs
Post by Borntofish »
Have you checked your master and slave cylinders? Are they still in good nick?
NathanX4
Town: Meyerton
Real Name: Nathan
Post by NathanX4 »
With the last raplacement the master and slave was replaced. Replace the line between the two as well.
LouisZ
Post by LouisZ »
The pilot bearing ok in the crank?
Is the adaptor plate scew? If its out scew by 2mm the clutch wont last.
NathanX4
Town: Meyerton
Real Name: Nathan
Post by NathanX4 »
Not sure about the pilot bearing, but i had the bellhousing at an engineering shop to have it machine straight.
I'm not a expert and would like to have someone with the expertise to have a look what is wrong and fix it.
LouisZ
Post by LouisZ »
Nathan do you have photos of the Bellhousing, fork etc.?
NathanX4
Town: Meyerton
Real Name: Nathan
Post by NathanX4 »
Unfortunately not. I can take some photos from the outside tonight.
LouisZ
Post by LouisZ »
I like to help. Lets see the setup.
NathanX4
Town: Meyerton
Real Name: Nathan
Post by NathanX4 »
I'll load some photos tonight. Do you perhaps have a number i can contact you on?
NathanX4
Town: Meyerton
Real Name: Nathan
Post by NathanX4 »
Not like these photos do me any justice, but i tried.
LouisZ
Post by LouisZ »
By the looks of it the clutch slave cylinder sits screw on the bellhousing. This can break the fork over a long time.
Then the bellhousing have to be checked, I might be wrong but looks if it thicker at the top than at the bottom, might be the photo.
Let me show you on my pic. A is wider than B.
If above will be the case your clutch wont last, this breaks the pilot bearing in time and this shortly after that break the input shaft of the gearbox.
The fork is fine.
LouisZ
Post by LouisZ »
Bietjie agtergrond;
viewtopic.php?f=98&t=26418&p=315488&hil ... er#p315488" onclick="window.open(this.href);return false;
Rebel 4x4
Town: Port Elizabeth
Vehicle: 2020 Toyota Fortuner GD-6 4x4 Auto
Real Name: Thomas
Post by Rebel 4x4 »
Parralaksfout
Sent from my iPhone
Stef
Vehicle: '98 LTD
Real Name: Stefan
Club VHF Licence: X107
Post by Stef »
So van clutches gepraat...watter plekke in Pta het Sachs kits vir SFA in voorraad ? En die regte goed...Gwagen sukkel bietjie met die 96-98 modelle lyk dit my, moes 3 keer bestel net om die regte remskoene te kry..
LouisZ
Post by LouisZ »
Acmc - 012 327 0040.
LouisZ
Post by LouisZ »
Nathan did you manage?
LouisZ
Post by LouisZ »
Guys we looking for a Wl25 bellhousing to Hilux Sfa gearbox for Nathan. Phoned Gilo and they don't make those. Or is it another one they use.
Inputs please.
LouisZ
Post by LouisZ »
Die naweek goed ondersoek gedoen op die samestelling op die conversion. Ek mooi die bellhousing gemeet, die was mooi reguit maar het iets gehad wat gepla het.
Aan die linkerkant was daar 'n lang dun kraak. Sou nie die gesien het as ek dit nie skoongemaak het nie. Toe haal die boks uit. Wel toe die boks loskom van die crossmember is dit 'n kraak wat orals rondom die housing gaan. Ook was daar nie 'n pilot bearing in nie, of dit get gebreek sal nog die flywheel moet afkry. Die release bearing is gebreek ook die gearbox guide(bearing retainer).
Ek sal nog kyk na die vingers op die pressure plaat. Ai was nie lekker om die te kry nie. Klaar 'n Bellhousing gekry met die hulp van Nathan. :thumbup:
The Legend
Real Name: Dawie
Club VHF Licence: X93-
Post by The Legend »
Nathan,Jou Hi-Lux is nou in goeie hande :thumbup: . Wees verseker hy sal reg wees as Louis met hom klaar is.
LouisZ
Post by LouisZ »
We going to go replace the input shaft and seal too. Bearing cage broke too. :(
Scott
Vehicle: Hilux SFA
Real Name: Rodney
Post by Scott »
I had to replace parts due to faulty pilot bearing the gearbox guy says it is critical.
LouisZ
Post by LouisZ »
Replaced the broken parts in the Gearbox.
Input shaft from Toyota really expensive, so we decide to use and modify it a bit to re use it. Some parts were engineered to suit.
This will be Input shaft bearing, Some minor keys on 3rd gear Syncro. Snap rings and 5th gear Nut. The nut is the longest to get from Toyota, they did not know it excisted. :shh:
Some snags on getting the right pressure plate for the new bellhousing but Nathan helped with that one.
I expain a bit more when the Box go in over this weekend.
