2016 Hilux central locking geraas
- Frederick
- Town: Hendrina Mpumalanga
- Vehicle: 2011 Hilux. 2016 79 Land Cruiser
- Real Name: Frederick
- Club VHF Licence: X42
Goeiemore
Weet iemand dalk hoe mens die hilux se central locking toeter geskree kan bypass?
Dis die vreeslikste geraas
- du Toit
- Town: Mossel Bay
- Vehicle: Toyota Hilux D4-D 4x4 2014,Conquer Supra offroad trailer,Dual battery,Garmin Nuvi 2460LT,L/R Tank.
- Real Name: Deon
Re: 2016 Hilux
Gaan na jou handelaar toe hul sal dit gou vir jou afhaal.
Sent from my SM-G920F using Tapatalk
- Frederick
Re: 2016 Hilux
Watter tak het dit vir jou afgehaal want nie Godrich of Pongola of Monument kan dit doen nie?du Toit wrote:Gaan na jou handelaar toe hul sal dit gou vir jou afhaal.
- Town: Centurion Gauteng
- Vehicle: Mazda Rustler 16v
- Real Name: Jan
Re: 2016 Hilux central locking geraas
Kan nog nie gedoen word nie.
Is dit dieselfde "buzzer" eenheid wat gebruik word vir die Hilux se "hooter" ?
Op die ou model was die hooter voor by die grill, en die alarm se buzzer naby die firewall.
Vervang dit met n sagter elektroniese "buzzer".
RAAI - ek wonder of Toyota dit doen as n antwoord op die remote blocking ? Nou moet jy weet as iemand die remote block ...
- coetzer94
- Town: Pretoorsdorp
- Real Name: Vian
Van wat ek verstaan is daar iewers in die Manual n hele roetine wat jy moet volg om die geluid af the haal. n tjom van my het dit gedoen op die vigo om die sitplek gordel beeper still te maak. Sal bietjie gaan soek, want ek moet dit op my pa se bakkie ook doen.
- Town: pre
- Vehicle: toyota fortuner
- Real Name: ahmed
There is a way I was with a toyota technician a few weeks a go he switched it in on my 08 fortuner bit it was annoying so he switched it of again they use the key puts it's in the ignition the takes its out holds one of the buttons and it goes of its a confusing way
YES - on the previous generation Hilux, aka VIGO it was possible. And certainly must be possible on Frederic's 2012 model.
NOT sure if it can be done on the brand new 2016 REVO .... (why do I think Frederic mentioned the REVO in his original post..)
- Real Name: Jan
There is a way to switch it off. Go to your nearest dealer .
- Town: Standerton
- Vehicle: Hilux 2.8 GD-6 4x4
- Real Name: Gawie
Dis relatief maklik. Haal net die hoeter af (10mm boudtjie) en dan draai jy net die silver skroeffie aan die agterkant van die hooter heeltemal in, probleem opgelos.
hehehehe ...Gawie B wrote:Dis relatief maklik. Haal net die hoeter af (10mm boudtjie) en dan draai jy net die silver skroeffie aan die agterkant van die hooter heeltemal in, probleem opgelos.
dis sekerlik een manier.
Met die VIGO kan n hele paar goed geprogrameer word:
- drywer se deur ontsluit met een klik, twee kliks vir alle deure
- alternatiewelik ontsluit alle deure met een klik van die remote
- so kan die hooter gestel word om af te gaan wanneer die sentral locking gebruik word.
Die stappe word duidelik uiteengesit in die owners manual .... maar jy kan ook maar net met die volgende diens vra dat die handelaar dit stel soos jy dit wil hê.
sou wil glo dit is ook so met die nuwe REVO
- Frederick
2016 hilux manne. My 2012 hilux makeer niks. Dis die nuwe een wat my mal maak met sy toeter wat aankondig as jy by jou kar aankom. Of as jy iewers gestop het dan kyk al die mense vir jou.
En nee, die handelaars het nie n antw nie. As jy sê vat hom na n handelaar toe, sê net watter een asb.
- Real Name: Jan
Enige handelaar Toyota het die nodige prosedure na al die handelaars deurgegee
- Real Name: Jan
Gaan na McCarthy Centurion praat met JJ
- Frederick
Dankbaar. Met JJ gepraat, Sien hom Donderdag
- Frederick
Baie baie baie dankie Jan!! Ten minste is dit nou gewax. Wat n verligting!!
- Town: Cradock
- Vehicle: Toyota hilux 2.8 4x4 2016
- Real Name: Danie
nuwe hilux 1000 revs in low range.
Hi almal. Die nuwe hilux enkel kajuit se revs gaan op na n 1000 toe as hy in low range gesit word. Kan dit verander word sodat hy dit nie doen nie.
- Town: Christiana
- Real Name: Dawie
Dit is baie maklik: As jy voor die enjinkap staan, kyk links agter in die hoek is so 'n klein toetertjie (dis die ding wat so groot geraas maak). Trek net die "pluggie" uit by die toeterjie. Dit wat jou 5 sekondes!
- Town: Christiana
- Real Name: Dawie
Hier is 'n foto:
- Knuppel
- Town: Somewhere in Africa
- Real Name: Marius
Ja maar nou werk die alarm glad nie meer nie!
- Town: Christiana
- Real Name: Dawie
Smoor hom... plak "insulation tape" om die opening om hom stiller te maak?
- Town: Montagu
- Vehicle: Hilux Legend45 3.0 D4D 2015 4x4 D/CAB
- Real Name: Tian
Die alarm werk nog steeds want hy gebruik die gewone toeter - nie die ekstra enetjie wat die tjirp doen op die deure se oop en toemaak nie.Knuppel wrote:Ja maar nou werk die alarm glad nie meer nie!
- sneethling
- Town: Uitzicht
- Vehicle: Toyota Hilux 2.4 GD-6 4x4
- Real Name: Stephan
Dankie Dawie. Dit werk!!! Ek het die Alarm ook getoets en dit werk vir die Hilux 2016 2.4 GD-6 4x4. Die alarm werk op die hoof toeter voor.
My toetse was soos volg:
1. Druk rooi knop op die remote sleutel. Dit aktiveer die alarm. (Alarm deaktiveer met oopsluit knop.)
2. Sluit my seun in die kar toe en na 30 sekondes wanneer die alarm gekativeer word beweeg hy rond in die voertuig en gaan die alarm af. (Alarm deaktiveer met oopsluit knop.)
Let wel: Moenie sommer blindelings navraag by die handelaar doen nie!!!
Emperial Toyota Cape Gate het vandag vir my vertel : "Need to bypass wire R633.65" waarvan hulle nie nou voorraad het nie, maar hulle kan vir my hulle eie "wire" opmaak en dan slegs vir R800 se arbeid dit vir my doen. As of dit nou die winskoop vandag is. Ek het gelukkig "Nee" hierop geantwoord en op hierdie forum vanaand af gekom. Dit spaar my R800 of is dit nou R800+R633.65 = R1433.65 as hulle voorraad gehad het. Ek weet nie regtig wat hulle sou aanvang nie, want my versoek was baie duidelik "Cancel horn sound when locking/unlocking".
