I recently had a Frontrunner fuel tank installed...above the spare wheel..
Question...when I refuel the vehicle...which tank fills up first? Main or auxiliary?
Frontrunner 70 liter fuel tank
- Kaaskrul
- Town: Port Elizabeth
- Vehicle: 2018 Hilux X-Cab 4x4 Dakar
- Real Name: Pierre
Re: Frontrunner 70 liter fuel tank
Depends.
If they fill it up on fast setting, rear tank first.
If they put the pump on slow, standard tank first.
Its got a Y piece now in the filler pipe.
- Toppie4x4
- Town: Centurion
- Vehicle: Hilux 4.0 V6 DC 4x4
- Real Name: Andre
Agree and you auxiliary tank is a bit higher than your standard tank and connected via a small balancer unit. Your fuel gauge will stay on full for quite a while. The y piece (in my vehicle) is very close the tank filler hole and they both are connected to the breather pipe and fills quite quick. When I fill up at a new garage the tenant usually looks under the vehicle for any leaks as soon as he pass the normal 70 or 80 litre mark.
