Water in the passenger foot well - Problem Solved!
Cleaner
Town: Johannesburg
Vehicle: Toyota Hilux 4l V6 4x4 Auto
Real Name: Ernst
Club VHF Licence: X31
Post by Cleaner »
Hi Guys
I need some advice from you - I have recently noticed that there is constantly water in the passenger side foot well in my 2006 Hilux Vigo.
Now the very first thought was condensation from the aircon - this I can also substantiate with the fact that I have stopped noticing the normal water under the truck when I have parked somewhere. Can it be anything else? Where else can water inside the CAB come from? And the water is there regardless if it rained or not!
Question - Where do I start searching for this, and what can be blocked that the water is now dripping on the inside of the vehicle? Have anybody stripped the aircon on a Vigo to see where the overflow channels would run? I have also noticed a noise like a fan scraping inside the CAB when the aircon is on and I take a corner to the right. Might be unrelated.
Would you advice a seek the service of an aircon shop or should I attempt to look for the fault myself?
Thanks!
"Every loaf of bread is tragic story of grains that could've become beer, but didn't. - Walter Thornburgh"
"The best cure for Sea Sickness, is to sit under a tree. - Spike Milligan"
Donkey
Town: Johannesburg
Club VHF Licence: X122
Re: 2006 Vigo - Water in the passenger foot well
Post by Donkey »
Ernst, I do not have such an experience myself, but as you say the water has stopped dripping from the underneath pipe when aircon is on, could be blocked with mud or something, my worry is if you leave it for too long some other internal part may start to rust, maybe someone has a clue. Good luck :thumbup:
Tumelo Maketekete
Die$eL
Town: Midrand
Real Name: Nishan
Post by Die$eL »
where is the heater core thingy? is it not leaking from there?
Real drivers use three pedals
Post by pietpetoors »
Start looking at the heater system. The heater radiator is inside and it have pipes running to it. Can be a pipe if you lucky.
JEEPIE
Vehicle: Official hilux 4x4 club recovery vehicle
Real Name: Shaun
Club VHF Licence: X 43
Post by JEEPIE »
is your luxie wetting itself already ?
Lappe
Town: Groot Marico posbus 02 2850
Vehicle: hilux v8 Lexus
Real Name: george
Post by Lappe »
Also check the filter.
Hiding doesn't stop evil, Return fire does
HennieJ2
Town: Witbank
Vehicle: Hilux D/C D4D 4x4, Hilux KZ-TE D/c 4x4
Real Name: Hennie Jackson
Post by HennieJ2 »
Hi,
Your aircon drain pipe leading from the heater box is blocked. Remove the pipe at the box and clean with a thin wire - inside the box. Follow the pipe from the engine bay and into the cab - underneath the carpet.
HJ
Cleaner
Town: Johannesburg
Real Name: Ernst
Post by Cleaner »
Thank you for all the responses! I thought it might be something like that! I will attempt to get to the filters and pipes and see if I can clean it, but I am much better at making my truck dirty than taking it apart and clean it! :twisted:
When I do attempt it, I will take pictures! Cause it might be helpful to someone else and it sure as hell is going to be funny!
JEEPIE wrote:is your luxie wetting itself already ?
No Jeepie, she's crying cause she had to be tied to your Jeep when I got scared she might fall over! Will you console her and bring her some twin savers when you see her next? :tongue:
Polarbear2008
Real Name: Theunis
Club VHF Licence: X49
Post by Polarbear2008 »
You should look at this with some urgency as water in and around the heater assembly that does not drain properly will cause damage to other electrickery like the fan blower.
Monroe Gas Magnum shocks
Dual loadbox slides
Wishlist:
Alu canopy
Warn Winch
JEEPIE
Real Name: Shaun
Post by JEEPIE »
Cleaner wrote:Thank you for all the responses! I thought it might be something like that! I will attempt to get to the filters and pipes and see if I can clean it, but I am much better at making my truck dirty than taking it apart and clean it! :twisted:
a whole box , just for you .
and wet wipes for you ?
Sebata
Town: Cosmo City
Vehicle: '06 Hilux 4.0l V6 auto 4x4, Iron-Man front bumper, Ali3n Rock-sliders, Old man Suspention, Snokel, 31" Pireli Scorpion Muds
Real Name: Tau
Club VHF Licence: X125
Post by Sebata »
i once experienced this, was a blocked pipe, which was sorted out when i took the truck in for service :thumbup: , good luck
Tau Sello
Cleaner
Town: Johannesburg
Real Name: Ernst
Water in the passenger foot well - Problem Sorted!
Post by Cleaner »
Okay - Update - It took me a total of 15 min to sort this issue out - after driving around with constant water in the passenger side foot well for 2 months!
Here is the deal -
In the passenger side foot well, on the right hand side, right in the far back, almost behind the center console, there is a drain pipe from the air-con condensation reservoir. it is underneath the carpet and you need to pull the corner of the carpet back to get to it.
This drain pipe goes through the firewall/floorboard and is fitted with a rubber grommet.
I pulled the pipe back through the grommet and pushed on it to feel for any blockages in the pipe. Found none. Next I stuck a cable tie all the way up the pipe to the point where it should go into the air-con condensation reservoir. still no blockage. Lastly I pulled the pipe out at the reservoir and at this stage a little water came seeping out the hole. I could also feel a blockage right at the mouth of the hole. The moment I touched it, it dislodged and water started coming out!
Bingo! Stuck the pipe back in and this very dirty filthy water came out - Notice at this point - Have something available to catch the water when you have found the blockage!
The water kept on seeping out. A short blow into the drainage pipe and I could hear it bubble in the reservoir tank. The water then came through strong and I managed to drain it all into a bucket (see picture). Right! Problem solved for now!
Blockage is cleared for the time being! I will when I have time, take the reservoir tank of and clean it properly!
A quick search on Google gave me the info I needed and more can be found here -
http://www.yarisworld.com/forums/showthread.php?t=6053
phpBB [video]
View Original
http://www.ehow.com/how_7949083_locatio ... ander.html
http://www.denlorstools.com/autoblog/20 ... ow-to-fix/
http://www2.pajeroclub.com.au/forum/sho ... hp?t=21182
http://www.4x4community.co.za/forum/sho ... hp?t=98231
phpBB [video]
View Original
http://www.exploroz.com/Forum/Topic/383 ... uiser.aspx
http://www.toyotaownersclub.com/forums/ ... pic=136381
It seems to be a common problem on Toyota's.
Drain Pipe
(133.44 KiB) Downloaded 1963 times
Crap that came out!
Crap that came out!
Crap that came out!.jpg (117.06 KiB) Viewed 31237 times
JEEPIE
Real Name: Shaun
Re: Water in the passenger foot well - Problem Solved!
Post by JEEPIE »
mooi so
HennieJ2
Town: Witbank
Post by HennieJ2 »
Vigio kwaal - ons het al 'n paar ge-fix :-)
HJ
Die$eL
Town: Midrand
Real Name: Nishan
Post by Die$eL »
glad to hear you got it sorted and thanks for posting the solution!!
