Trying to make own compressor hose, need some help
- Vehicle: 2700i SRX Hilux
- Real Name: Malcolm
Hi All,
I bought a Hilux with a Arb compressor, but didn't come with the hose attachment used to pump up the tires. I wanted make my own hose, but was at Builders warehouse looking at the hoses available there. They had two different ones, with the same pressure ratings but different diameters.
What pressure rating hose should i get ? and what diameter ?
- Town: Port Elizabeth
- Vehicle: Hilex
Re: Trying to make own compressor hose, need some help
The ARB compressor cuts out at 7bar, so I'd say a hose with a 10 bar rating. We use Festo pipe with about the same rating in factories which usually has a plant pressure of 5-7bar.
An 8mm hose(ID) should be sufficient for your needs.
Barto de Koning
HI Greenhorn,
We discussed some compressor topics here:
viewtopic.php?f=3&t=289
It is important to ensure the hoses etc are also not affected by temperature, someone mentioned they had problems with heat affecting the hose directly after the compressor.
- Sifu-Lux
- Town: Mount Vernon Illinois
- Real Name: Andrew
I made a remote manifold mount with a pressure guage and a blow down valve (I fitted and extra 2.5l accumulator tank)
On this I then connected my quick coupler.
I used Festo pipe for the connections, and then bought Compressor pipe and fittings from the local Hardware store. 10 bar as Barto said.
Sifu-Lux....I will miss you
- Sifu-Lux
- Real Name: Andrew
This is the hose I use. I just cut it and added a valve and pressure gauge. I use it to inflate and deflate my tyres.
Hi Sifu-Lux
That looks great, could you post the items you used to build your compressor hose.
- Sifu-Lux
- Real Name: Andrew
Eish! would like to, but I can't find the invoice.
Just go to your local Hardware/Automotive paint supplier store. They usually sell all the spraypainting pneumatic fittings and pipe.
You need:
6 meters of 10 bar rated compressed air hose. (I think 8mm ID)
1 x Stop cock 1/4 inch valve (will have two female ends)
1 x 1/4 inch female T-piece
1 x 1/4 inch double ended nipple to join the T-piece to the valve
2 x 1/4 inch male connectors to connect to the hose on either side of the valve/T-piece
1 x Quick coupler kit (mail/female) CHECK the thread matches the ARB Compressor
1 x 0-6 bar pressure guage (can also get from your local instrumentation supplier) I used Rhomberg.
1 x tyre inflator valve fitting (Midas / Autozone should have)
1 x Roll of PTFE thread tape
Hope I didn't miss anything. Just look at the pic I posted to assemble.
Good luck.
You need:
Good luck.
- Sifu-Lux
- Real Name: Andrew
Oh, and some hose clamps now that I look at the picture
- Vehicle: Hilex
I also use a Rhomberg as well, but a 0-2bar guage, because I never inflate my tyres over 2bar. On the lux the 35" tyres are 1.5bar on the road and the 33's on the cruiser were at 1.8bar on the road. Great thing about a 2 bar guage is the accuracy you get within that range, especially if you run tyres at 0.4bar like I do on the lux.Sifu-Lux wrote:1 x 0-6 bar pressure guage (can also get from your local instrumentation supplier) I used Rhomberg.
Barto de Koning
- Vehicle: 2009 Suzuki Jimny
- Real Name: Dawid
Hi Sifu-Lux, looking at your photo of the hose...I would suggest you fill up your brake fluid reservoir!
2009 Suzuki Jimny (Mini Hilux)
Ex-Hilux SFA 3.0D
Ex-Hilux SFA 3.0D
- Sifu-Lux
- Real Name: Andrew
This is an old photo from 2005, so some may have digitally evaporated
SkerpSifu-Lux wrote:This is an old photo from 2005, so some may have digitally evaporated
