Tyre repair kit
- Town: Springs
- Vehicle: Hilux 2700i
- Club VHF Licence: HC262
Tyre repair kit
I bought myself a tyre repair kit from a tyre place and was very excited to use it for the first time.So one day we had a vlat on the company bakkie and i tried my new repair kit.After about half an hour I had broke both the tools ,used three repair sticks,a puncture in my hand and still the puncture in the tyre.
So i made myself a new repair kit.
Re: Tyre repair kit
Johan, well done! Those cheapies from some of the Motor Spares shops are simply dangerous.
I bought my repair kit from Champion Tyres, figuring they would only stock a reputable make. This is something I have not yet tried, would like to but not on one of my own vehicles!
Re: Tyre repair kit
Johan.... nice gedoen daar.legend35 wrote:I bought myself a tyre repair kit from a tyre place and was very excited to use it for the first time.So one day we had a vlat on the company bakkie and i tried my new repair kit.After about half an hour I had broke both the tools ,used three repair sticks,a puncture in my hand and still the puncture in the tyre.
Raad wat ek kan gee is hoe harder die band gepomp is wat jy reg maak hoe makliker is dit. Ek het nou al seker so 10 punctures reg gemaak en ek het al my @$#@# af gesukkel maar toe kom ek die trick agter. Ek pomp die tyre at least so 2.5bar en sit dan die plug in..... baie makliker
- Town: Springs
Re: Tyre repair kit
Ek het dit met die eerstepuncture gedoen maar was onsuksesfol.nou het ek n reamer wat 7mm dik is en dit werk sommer op n pap band ook.Die ding is ook om die sulution maar dik aan te sit en dit dadelik in die gat in te druk dan lube dit die gat so bietjie.
Re: Tyre repair kit
Feite daai... jy moet nou net passop dat die gat nou nie te groot geream word nie want dan kan daai plug nie heeltemal sy job doen nielegend35 wrote:Ek het dit met die eerstepuncture gedoen maar was onsuksesfol.nou het ek n reamer wat 7mm dik is en dit werk sommer op n pap band ook.Die ding is ook om die sulution maar dik aan te sit en dit dadelik in die gat in te druk dan lube dit die gat so bietjie.
Re: Tyre repair kit
I'm not too sure how well the drill bits will work, the thing I always worry about is that the reamer follows the actual puncture tract and does'nt make a new one of it's own ... that's also a problem, had it once before and it leaked again after a while ... had to take the tyre off and fit a gator. I had totally mis judged the original hole angle and made a new one
Personally I prefer a pointed spike, but not sharp, on the reamer. Seems to work ok for me.
Re: Tyre repair kit
These plugs we use is only supposed to be used as a temporary measure and when able should replace with a mushroom plug from inside the tyre. I personally have never replaced a plug on a tyre with a descent patch because generaly the tyres were at end of life anywayMud Dog wrote:I'm not too sure how well the drill bits will work, the thing I always worry about is that the reamer follows the actual puncture tract and does'nt make a new one of it's own ... that's also a problem, had it once before and it leaked again after a while ... had to take the tyre off and fit a gator. I had totally mis judged the original hole angle and made a new one
Re: Tyre repair kit
NOW you phone me! ... after I've used them for years! I've had them last forever ... never thought of them as temporary.These plugs we use is only supposed to be used as a temporary measure
Re: Tyre repair kit
Believe it or not... I actually read the instructions Am I now just halve a man?Mud Dog wrote:NOW you phone me! ... after I've used them for years! I've had them last forever ... never thought of them as temporary.These plugs we use is only supposed to be used as a temporary measure
But according to the instruction booklet it is only supposed to temp fix :)
Re: Tyre repair kit
Cassie, the tyre shops here have not read the same book as you... they plug 'em, charge me R5 or so, then off we go! But maybe off-road tyres are to be treated with a bit more care and require a more permanent solution... (see: I can also be 'punny'!)
Re: Tyre repair kit
(I saw you sneak one in there :))Family_Dog wrote:Cassie, the tyre shops here have not read the same book as you... they plug 'em, charge me R5 or so, then off we go! But maybe off-road tyres are to be treated with a bit more care and require a more permanent solution... (see: I can also be 'punny'!)
I think the reason is they eventually dry out and start leaking. I had this happen on a tyre before. I think if it is a fix on a tyre that works everyday it should be fine because the tyre would be finished before the plug has dried out. But on a secondary vehicle that does very little km's, it will probably get a slow leak.
Re: Tyre repair kit
Ok I'm back ... F_D, I see you're also 'joining' the band wagon.
Cas, what you say makes sense, but I'm curious ... are there differing grades of plugs, maybe? I dinna see nuttin about 'temporary', but then again no instruction leaflet either.
- Bushwacker
- Town: Vryheid Natal
- Real Name: Piet
Re: Tyre repair kit
Spare valves, metal valve caps, yellow tyre chalk & ball inflate tools included
- Town: Springs
Re: Tyre repair kit
Piet,that is a nice set you got there.
Before making the hole bigger,I check the position of the piece of metal in the tyre and then ream according to that angle.
Re: Tyre repair kit
All fine and well if the metal is still there ... usually is, I know, but I've had it where no "culprit" can be found. :problem:Before making the hole bigger,I check the position of the piece of metal in the tyre and then ream according to that angle.
- Town: Springs
Re: Tyre repair kit
If you are just a little bit handy then you will know,it is not that easy to make a hole in a tyre and my reemers are not any sharper than the ones you buy in the shop.It only makes it easier to ream the hole.
Cassie jy is reg dat dit net tydelik is.My werkgewer het n tyre laat reg maak en het n hele ruk daarna weer n lek opgetel en ek het hom toe vir hom regemaak maar ook vir hom gese dit is net tydelik.
