Ek is amper klaar met my toy se agterste bamper nog net die verf en siedaar.
Dan wil ek begin met die rocksliders, daarna die rolbar en dan die voorste bamper.
Nou wil ek weet (ek het dit al gevra op iemand anders se blad) wat dink julle hoe gaan dit lyk as ek by die vierkant iefek van die agterste bamper hou ( die ronde pypbamper is afgegooi) en die rockslider en rollbar ook met vierkant en reghoek yster maak
Of werk die ronde yster beter vir die sliders
VIERKANT OF ROND
- Piesang
- Town: Grabouw
- Real Name: Pieter Pieterse
VIERKANT OF ROND
- Gertc
- Vehicle: 3.0L Fortuner
- Real Name: Gert Combrink
- Club VHF Licence: Xray05
Re: VIERKANT OF ROND
Pyp is sterker in konstruksie as vierkant yster.
- blom
- Town: Landrovia
- Real Name: Blom
PYP ou Piesang PYP!!!!
onthou die waldikte moet ten minste 2.5mm wees
Grensvegter van LANDROVIA
Spot on! ... don't even look at rectangular material, it won't be strong enough, .... just one heavy 'antie' climbing in stands on it and you will need to replace! Serious, you would need 3,2mm or more wall thickness to get similar strength and the extra weight would be substantially more.PYP ou Piesang PYP!!!!
Oh, another thing, if you have stress applied through a angular or sharp point to a pipe and a rec. tube, the rec. tube will cave in at the point of stress and buckle / bend whereas the pipe will handle much greater forces with ease. Think of it this way, the moment there is a kink it the pie or tube, that is a weak point where a bend can occur. To put a dent or kink in the curved surface of a pipe is a lot more difficult than in the flat surfaces of rec. tube.
Vierkant is baie Nissan...
- Piesang
- Town: Grabouw
Dis hoek om ek so bly is julle ouens is daar, om eers te vra voor 'n ou onnodig baie skool geld moet betaal.
Dankie
Dankie
Toemaar, hy sani vierkant gebruik nie :D
