Your DIY tips on heatshields for cab and fuel line..Please.
Members' DIY projects
swartvark
Town: Gordons Bay
Real Name: Tiaan
Post by swartvark »
Howday
I've been wanting to put some reflective wrap around my fuel line. The hose is running about 50mm from my exhaust system all the way into the engine bay(apparently a couple of layers of heavy duty Tin Foil works 100%).
The heat actually causes vapour lock when driving long slow trails. At first I thought it was a Dirty Fuel Filter or Pump problem, but the Swartvark runs perfectly on open roads and on the dunes where it gets more air at faster speeds.
I also want to do something about the floor getting hot because of exhaust etc..........
ANY DIY tips from you guys???........or must I just go to Midas and buy something off the shelf?
MUD........GLORIOUS MUD!!!!!
NEED A CAR?
talk2tiaan@gmail.com
0829294028
Pote
Town: Hartbeespoort
Vehicle: Fortuner D4d 4x4 & VW Passat
Club VHF Licence: X228
Re: Your DIY tips on heatshields for cab and fuel line..Plea
Post by Pote »
Hi Tiaan
Kyk na so iets dalk??
http://www.gumtree.co.za/a-accessories- ... 0192789009" onclick="window.open(this.href);return false;
Hangover
Town: Deneysville
Real Name: Stef
Post by Hangover »
Ek het daai exaust wrap al getry... Dit werk nie... My kizaust het n boks onder my en die passasier voete en aand die een kant het nog die original aluminium plaat wat vas is met 2 spacers en dit is baaaaaiiiiieee beter an daai kant... Ek sal se die enigste roete om te gaan is n alu plaat met spacers bo die bokse...
Hangover(A.K.A die speelding)
1976 FJ45 4x4
1UZ-FE 4.0vvti
2" OME Suspension lift
1.5" Shackle lift
35" Geo MT's
Custom Bullbar
Lockright Locked rear
York OBA
20" LED bar
Nighthawk 100W spots
Dakar
2013 3.0D-4D 4x4 Hilux Dakar
swartvark
Town: Gordons Bay
Real Name: Tiaan
Post by swartvark »
Ek gaan so iets prober maak met alu plaat.........wish me luck. :laugh2:
NEED A CAR?
0829294028
ThysdJ
Club VHF Licence: HC102
Post by ThysdJ »
Tiaan gaan koop vir jou van daardie aluminium flashing wat hulle gebruik om dakplate mee te seel... Dis dun alu plaat wat maklik met'n bliksker gesky kan word en dit buig en vorm ook maklik. Rivet brackets daaraan om dit vas te skroef. Ek het so 'n heat shield op Kaspaas gesit destyds.. daar is erens fotos van op die forum.. Dit werk baie mooi.. :thumbup: :thumbup: :thumbup:
ThysdJ
Post by ThysdJ »
viewtopic.php?p=56032#p56032" onclick="window.open(this.href);return false;
Hieso...
LouisZ
Post by LouisZ »
Hoekom re route jy nie. Van so aard dat die fuel op 'n ander plek uitkom en dan op die teenoorgestelde kant loop van die chassis.
swartvark
Town: Gordons Bay
Real Name: Tiaan
Post by swartvark »
4x4megaworldpta wrote:Hoekom re route jy nie. Van so aard dat die fuel op 'n ander plek uitkom en dan op die teenoorgestelde kant loop van die chassis.
Ek probeer die Cab ook bietjie koeler hou.......so as ek twee vliee met een klap kan uitsort sallit "COOL" wees.... :thumbup:
NEED A CAR?
0829294028
swartvark
Town: Gordons Bay
Real Name: Tiaan
Post by swartvark »
ThysdJ wrote:viewtopic.php?p=56032#p56032
Hieso...
JAAAAAAAAA!!!!!!!!!!.................daai is wat ek gan doen.......maar ek gaan dit tussen my cab en exhaust mount.onder die Vark se pens. Ek sal maar kyk hoe die beste gan werk. Ek sal die plaat onner aan die Cab vassit met Spacers........of anders die plaat met Spacers en Brackets aan die exhaust self vas clamp?
As nog mense prentjies het van hulle s'n sallit nace wees. :blushing: :blushing:
NEED A CAR?
0829294028
Haboob
Town: King Williams Town
Real Name: Edge
Club VHF Licence: HC129
Post by Haboob »
Tiiaan, I used asbestos matting under my floor mats in my previous 2.4 petrol, 1994 D/V.
Yes I have read the previous thread about the dangers of asbestos poisoning, but the asbestos mat is completely covered by the vehicles floor mat. There is no chafing and the asbestos mat is not a open to release any asbestos mplecules. It worked for me without any visible after effects. I still have an asbestos car port roof which is covered with paint & gets a fresh coat everytime the rest ofthe house gets painted.
HABOOB means "Dust Storm"
swartvark
Town: Gordons Bay
Real Name: Tiaan
Post by swartvark »
Haboob wrote:Tiiaan, I used asbestos matting under my floor mats in my previous 2.4 petrol, 1994 D/V.
Thanks.....but where do you get the matting from?
NEED A CAR?
0829294028
ThysdJ
Post by ThysdJ »
Tiaan, jy kan ook daai cheap hondekomberse gebruik en dit onder die matte op die vloer vasplak. Of jy kan by builders warehouse vir jou van daardie dun spons gaan koop waarvan die hiker's matrassies gemaak word. Hulle sal ook lekker werk. Ek het daarvan wat ek wil gebruik om vir my yskas 'n jassie te maak... :thumbup: :thumbup:
swartvark
Town: Gordons Bay
Real Name: Tiaan
Post by swartvark »
ThysdJ wrote:Tiaan, jy kan ook daai cheap hondekomberse gebruik en dit onder die matte op die vloer vasplak. Of jy kan by builders warehouse vir jou van daardie dun spons gaan koop waarvan die hiker's matrassies gemaak word. Hulle sal ook lekker werk. Ek het daarvan wat ek wil gebruik om vir my yskas 'n jassie te maak... :thumbup: :thumbup:
Okay..Thanks..........Ek het asbesband om my Fuel Line gedraai en is besig om flashing plaat met U-Bolts aan die bokant van die exhaust vas te klamp..........daar's 'n gaping tussen exhaust en plaat, asook plaat en vloer......Dit lyk nie vreeslik profesioneel gedoen nie, maar sal help.....ek dink. :lol:
NEED A CAR?
0829294028
Return to “Build your own:”
