Mobile Tranceiver Mounting Place Inside Hilux D/C SRX.
- Uysster
- Town: Windhoek
- Vehicle: 2008 Toyota Hilux 2.5 TD 4x4 D/C
Good day.
I need some ideas and input, please.
I purchased a second hand mobile tranceiver. I want to design and build my own mobile mounting bracket.
The problem is not really the designing and mounting, but rather mounting place inside the vehicle.
I want to fit this unit into the 2008 Toyota Hilux D4D D/C 4x4 SRX. From what I can see, there's no practical space for mounting this tranceiver.
I want it to be in good reach from the driver side position and not too much in the way. No "seperation kit" available and no mobile mounting bracket. (Thus the designing of a new one.)
I prefer not to make any new holes in the vehicle.
Can some of you help me here, help with some ideas and photos for possible placement, please? :-[
Namboyz
Re: Mobile Tranceiver Mounting Place Inside Hilux D/C SRX.
Please explain what a "mobile tranceiver" is, then you might get answers
How about in the spot of the grab handle on the drivers side (obove your head) then you will be able to hear it nicely as well
ek dog ek is die enigste een wat nie weet wat dit is nie ... dankie tog ek is nie alleen nie ...Thabogrobler wrote:Please explain what a "mobile tranceiver" is, then you might get answers
- niclemaitre
- Town: Stellenbosch
- Vehicle: 99 IFS DC 4x4
- Real Name: Nic
Transceiver: TRANSmitter-reCEIVER, or a radio in plain speak.
Can't find the post now (searching off a phone sucks) but someone made an alu bracket that fastens on where the rear view mirror attaches and used that. They also make roof consoles that can take radios. Or you can mount it to the fittings used to hold the gear leaver boot.
Happy trails
Nic
SFA '87 DC "Rooies" - sold
IFS '99 DC "Benny"
Nic
IFS '99 DC "Benny"
- Bushwacker
- Town: Vryheid Natal
- Real Name: Piet
Google is your friend
- images1.jpg (9.6 KiB) Viewed 4131 times
okayyyy - so we are looking for a radio bracket - more precisely WHERE to fit it in a Vigo ....
viewtopic.php?f=136&t=11751&start=30" onclick="window.open(this.href);return false;
see top of page 2, couple of pages later I fitted another bracket as well.
- Uysster
- Town: Windhoek
Thanks for the responses thus far. It really is much appreciated!
I am still undecided.
Due to the many functions and functionalities of my tranceiver, I would really prefer mounting it horizontally. I would have to look at the display fairly often, therefore mounting it vertically would be very impractical for me. (B.t.w., it's the Yaesu FT-8100R.)
Though... options in a Hilux is just too limited therefore not leaving me with much choices.
I truly do not know what to do!!!
Namboyz
George, not sure if you are aware that this is an Amateur Band radio, licenced only for Radio Hams? It is not intended for Commercial frequencies. Apologies if you are a Radio Ham.
- Uysster
- Town: Windhoek
No need to apologise.
Licenced amateur. (V51GU)
Namboyz
- Vehicle: 1995 SFA
Not sure if this helps. Oom Eric did the rest of the installation.
- Radio 2.jpg (61.5 KiB) Viewed 4105 times
- Radio 1.jpg (50.09 KiB) Viewed 4105 times
- Uysster
- Town: Windhoek
Dan kom die kopseer van die antenna montering ook nog...
Dink dit behoort dalk makliker te gaan as die radio se montering. :alvarin:
Namboyz
- Uysster
- Town: Windhoek
Antenna - Bullbar of Rollbar?
Motiveer!
Motiveer!
Namboyz
- Uysster
- Town: Windhoek
Jaco, dit is die perfekste plek!
MAAR, ek het nie so "gat" in die dak nie. En ek dink nie ek is bereid om so gat te maak nie. Ek wil reeds nie gate maak nie.
Namboyz
- Uysster
- Town: Windhoek
B.t.w., ek like die idee van die "u-bolt" montering vir rollbar / bullbar!
http://www.4x4cb.com/images/jims/instal ... tall13.jpg" onclick="window.open(this.href);return false;
Namboyz
- Vehicle: 1995 SFA
Sit daar nie ñ liggie/bril houer in jou bakkie nie? Die fotos is van ñ 2006 Hilux.
- Uysster
- Town: Windhoek
Ongelukkig nie.
Myne 2008 model.
Net die 2 sonskerms. (Al gedink om tussen hul een of ander bracket te prakseer, maar wat dan weer gedoen met die drade...)
Myne 2008 model.
Namboyz
- Uysster
- Town: Windhoek
Myne die SRX model. (Stock standard, base model.)
Namboyz
- Vehicle: 1995 SFA
Dis ñ probleem! Ek hou ook nie van gate maak nie.
- Uysster
- Town: Windhoek
Gedink om dalk my eie seperation kabel te maak en in te "tap" op die tranceiver se pcb en die display.
Namboyz
- Pote
- Town: Hartbeespoort
- Vehicle: Fortuner D4d 4x4 & VW Passat
- Club VHF Licence: X228
Kyk agter die roof lining. Baie modelle het die drackets klaar in die voertuig maar dit is eers op die einde van die assembly lyn dat hulle die verskillende opsies begin opsit.dd6 wrote:Sit daar nie ñ liggie/bril houer in jou bakkie nie? Die fotos is van ñ 2006 Hilux.
Die brackets en nuts behoort agter die rooflining te wees vir die lig / bril houer.
Hoop dit help
Those are the pics I was looking for, thanks Jaco!dd6 wrote:Not sure if this helps. Oom Eric did the rest of the installation.
We do!!dd6 wrote:Dis ñ probleem! Ek hou ook nie van gate maak nie.
Only one correct way to mount the antenna - 20mm hole at the highest practical point of the vehicle.
- Uysster
- Town: Windhoek
So you'd advise to rather move away from the u-bolt bracket?
Sent from my GT-N7100 using Tapatalk
Namboyz
- Uysster
- Town: Windhoek
Thos would have to do for now. See if it works.
Soldered a cable between the tranceiver and display and works 100%.
Namboyz
- Uysster
- Town: Windhoek
Going to relocate the tranceiver behind the cubbyhole.
Namboyz
- Uysster
- Town: Windhoek
Namboyz
- Uysster
- Town: Windhoek
Namboyz
