Pipe bull-bar made from roll-bar
- mosteran
- Town: Springbok
- Vehicle: Fortuner 4x4, 1994 Hilux dbl cab 4x4
- Real Name: Andre
Hi there,
I'm busy building a bull-bar made out of an old sfa roll-bar.
I would like to share it with you. But I cannot upload any photos.
Is there someone I can mail it to,to share on the forum?
You can mail to me ..... andy@hilux4x4.co.za
Also have a look at this topic for future use to upload pics.
- mosteran
- Town: Springbok
- Real Name: Andre
Thanks Andy,
The problem is that I only have my cellphone and its difficult to navigate a post with pictures.
When I'm finished I will mail you the pictures and short story.
Thanks in advance
Thanks in advance
Pleasure! Will watch out for your mail.
- MOFASA
- Real Name: Johno
- Club VHF Licence: X119
IT'S A JEEP
..... You wouldn't understand....
[rimg=206x128]
IT'S A JEEP
Still no mail.
- mosteran
- Town: Springbok
- Real Name: Andre
Sorry guys, still busy with the bull-bar.
Will mail Andy as soon as I'm finished.
Now busy fitting the recovery, and lift points.
Still need to do a lot of grinding to make my welding lood good.
Then prime and paint.
Hopefully I'll be finished end of the week.
- Town: Bellville
- Vehicle: V8 Disco 1
- Real Name: Dirk
Sit solank fotos op van die begin tot nou
- MOFASA
- Real Name: Johno
IT'S A JEEP
[rimg=206x128]
IT'S A JEEP
- MOFASA
- Real Name: Johno
IT'S A JEEP
[rimg=206x128]
IT'S A JEEP
- Town: Bellville
- Real Name: Dirk
Received and resized ...............
- MOFASA
- Real Name: Johno
How are you mounting it?
I think your recovery points might be a bit flimsy.....
Looks like you will be pulling in line with the 2 bolts on each side.....
Look at placing a 8mm to 10mm plate running along or under the chassie and bolt through it into exsisting threaded holes in the chassie.
That will give you the sideways strenght of the HT bolt (bolt rating 8.8 no less)
Just a thought....
IT'S A JEEP
[rimg=206x128]
IT'S A JEEP
- mosteran
- Town: Springbok
- Real Name: Andre
Thanks Andy, will send the rest as I go along.
I think for a sparky on his first try its not to bad.
Yes Johno, I don't have any experience with metal and welding strengh.
Will see what happens and if it fails, I will go back to the drawing board.
The recovery points is just there to get the brake down landdrovers out of my way
- mosteran
- Town: Springbok
- Real Name: Andre
the square tube at the bottom was part of the old bumper, so mounting it on the existing four threaded points on the chassis. Johno, are you talking about the force on the recovery point on a sideways pull?
- swartvark
- Town: Gordons Bay
- Real Name: Tiaan
Ek laaikit. Goeie werk!
MUD........GLORIOUS MUD!!!!!
NEED A CAR?
talk2tiaan@gmail.com
0829294028
- MOFASA
- Real Name: Johno
The way up imounting now will only pull directly inline with the bolt so you relying on the thread alone....
Is you have bolts going through a plate vertical to the horizontal pulling line they are stronger......
IT'S A JEEP
[rimg=206x128]
IT'S A JEEP
- MOFASA
- Real Name: Johno
Look at basic drawing.....
Bolts can be added on the side or under the chassis......
Try use existing threaded holes on the chassis side or under it....
- (59.06 KiB) Downloaded 1749 times
IT'S A JEEP
[rimg=206x128]
IT'S A JEEP
- louis fourie
- Club VHF Licence: X101
Andre
Dit lyk goed. Ek het met my bumper weggebly van enige welding op die mountings - alles is gebout.
- MOFASA
- Real Name: Johno
mosteran wrote:Thanks Johno, will modify it....
Once you done with that you should not have any problems as long as you use the 8.8 rated HT bolts
IT'S A JEEP
[rimg=206x128]
IT'S A JEEP
Personally I don't think you need to go with bolts .... proper welding is stronger. That said, a lot depends on the wall thickness of the sq tubing and the quality of the welds. Perhaps I'm not seeing it so nicely without close-up pics but what concerns me is the places I've circled ..............
It would have been ideal if the recovery point steel went all the way through to the rear of the sq tube and welded there as well, but what it looks like to me is that you have made butt-joints. This means that the weld or material is able to tear more easily. That's why I mentioned material thickness of the sq tube .... if it's thick enough, 2.5mm or more, it will hold fine. That brings me to the actual welds. The top of the butt-joints (where I've marked them "A" and "B") is the weakest area and that's where they will allow a tear to start (once it starts it runs and rips the whole thing off). Here is where weld penetration / strength is important. I would double up on those welds at about 110amps with a 2.5mm electrode, and 'flow' that weld over a slightly larger area .... top and sides.
The other places I've encircled is the 'inner' corners .... the welds don't look complete ... looks like there's slag or something in there. As I said, I cannot see it clearly on the general pic, so I might be mistaken, but those welds should also be good and continuous with the underside welds along the lift point pipes. That will more than sufficiently reinforce the strength at the bottom.
Otherwise looking good!
- mosteran
- Town: Springbok
- Real Name: Andre
Andy the square tubing wall is 3mm thick and I think my welding is not to bad. Though of maybe putting a thick flat bar on top of recovery point that stretch over the square bar as well. Still deciding.
3mm wall is adequate. Just flow a 2nd weld over the sides like I said and the idea of a strap welded across the top is good, a bit overkill, but it'll make certain that it doesn't tear.
(A 20 x 5mm flat-bar strap should do it).
Some more pics received from Andre' ......
- MOFASA
- Real Name: Johno
Looks good so far....
Looks like you have a little more gap under the drivers side light compared to the other side....
IT'S A JEEP
[rimg=206x128]
IT'S A JEEP
- Froll
- Town: Vioolsdrift
- Real Name: Roger
- Club VHF Licence: N/A
Looks very good Andre'. I also ended up with a gap on the drivers side on the one I made. Will try and sort it out when I strip the truck to spray paint and rust removing.
Fix it with a shim plate on the passenger side.
- mosteran
- Town: Springbok
- Real Name: Andre
- mosteran
- Town: Springbok
- Real Name: Andre
Finally, fitted the bumper yesterday. Wanted to paint it matt-black but I had the finishing black on my garage shelf. Pics will follow
- GeorgeJvR
- Town: Louis Trichardt
Andre what engine are you running?
Kom wat wil ek bly 'n Bul!
- MOFASA
- Real Name: Johno
IT'S A JEEP
[rimg=206x128]
IT'S A JEEP
- mosteran
- Town: Springbok
- Real Name: Andre
Interesting site. Help to work out the angles needed when working with pipe.
http://snip.awardspace.com" onclick="window.open(this.href);return false;
now that is handymosteran wrote:Interesting site. Help to work out the angles needed when working with pipe.
- smokintyres
- Town: Windhoek
- Real Name: Gernot
2nd that!CasKru wrote:now that is handymosteran wrote:Interesting site. Help to work out the angles needed when working with pipe.
Thanks for sharing
Here are the pics ...... Nice, Andre'!!
- Thunder02
- Town: East Rand
- Vehicle: IFS Hilux
- Real Name: Neil
- Club VHF Licence: HC105
Stunning job
Scout motto:be prepared....
www.4x4direct.co.za
www.4x4direct.co.za
- JEEPIE
- Town: Roodepoort
- Real Name: Shaun
- Club VHF Licence: X 43
not to shabby nig
thats now a custom looker
1 of a kind
1 of a kind
- george
- Vehicle: Prado 90 VX 3.4 V6
- Club VHF Licence: HC107
Still my favorite design for a bumper.
- Hi-Hilux
- Town: Tsumeb
- Real Name: Trevor
Andre, gaan jy omgee s ek jou idee gebruik?
- Hi-Hilux
- Town: Tsumeb
- Real Name: Trevor
Thanx Andre, ek het op my vorige hilux 'n ARB een gebou maar soek iets anders vir die "nuwe" hilux en hierdie een van jou trek my aandag BAIE!
- sir shrek
- Vehicle: '09 Hilux D/C 4.0 V6 AKA 'BULLET' Hilux D/C 7M-GE aka SIR SHREK(SOLD) Jetta MK5 2.0TFSI
- Real Name: Claude
Awesome.
Wat ek die meeste like is die goeie airflow. No restrictions at all.
Maak meer sin as die tipe wat heeltemal toe gemaak word met plaat.
Well done
Well done
3" suspension lift 31" bfg muds dual fuel tanks custom bushbar 7M-GE
Rear Diff Lock Custom made snorkel
UGLY LIKE SHREK,STRONG LIKE RUSSIA
- Donkey
- Club VHF Licence: X122
Must agree looking wicked and aggresive, also practical
Tumelo Maketekete
- Rider
- Town: Richards Bay
- Vehicle: 1987 Toyota Hilux 4x4 d/c 40mm body lift, KZ-TE Diff with Diff lock, Snorkel, 31" AT tyres , Powered by FORD 3.0 V6 uprated.
- Real Name: Luke
PROUD OWNER OF A TOYOTA HILUX AKA AMA-HIPZ
- Hi-Hilux
- Town: Tsumeb
- Real Name: Trevor
Andre, hier is my mail stkmetals@gmail.com
