Good day gents
I'm currently thinking of buying myself a Vigo shape hilux but can't afford a 4x4 model. That's why I've thaught of buying a 2x4 an converting it to a 4x4 myself. If anyone has done this or thaught of doing it your views and opinions would be greatly appreciated. Info on the matter eg parts list and price will also be of great help.
DIY 4x4 Vigo
- TOYODA
- Real Name: Tiaan
Re: DIY 4x4 Vigo
Welcome Etienne
Give us an estimation on your budget... From there we can start to give you an opinion.
- Town: Paarl
- Real Name: Bester
Re: DIY 4x4 Vigo
Hi Etienne, it can be done but if you don't yet have the vehicle it may be worth the while just buying a 4x4 from the start. I'm not sure of the cost of the conversion, would mainly depend on at what price you can get the 2nd hand parts.
I would rather consider an older model 4x4, than buying a 4x2 and converting it.
Hilux 3.0 D4D 4x4
Imagine Trailvan
Imagine Trailvan
- Black Sam
- Town: Mtunzini
- Vehicle: Nissan Navara Pro 4x
- Real Name: Gerrie
Re: DIY 4x4 Vigo
Hi Ettienne, welcome to the forum.
a Friend of mine was considering the same and the quote he got was over the 60K really not worth it.
M2CW.
M2CW.
- Tarquin
- Town: Plettenberg Bay
- Real Name: Tarquin
Re: DIY 4x4 Vigo
its really not worth it, because if you buy a 4x4 you can try out the 4x4 and see if it works properly and if you buy the gearbox, front diff etc second hand you don't know whats inside till you drive it, parts could be damaged from previous owner. and it will cost you way more
- TOYODA
- Real Name: Tiaan
Re: DIY 4x4 Vigo
Here is M2CW.
Rather buy a 4.0 V6 4x4 Vigo. You have more power and it will use a little bit more fuel that the 2.7. The 1GR-FE engine is good for +400 000km.
The money you are going to save on the conversion, you can put a LR tank in, upgrade suspension, tyres and remove the front tupperware. It all depends on how much you want to spend on the vehicle in the first place... and the R60k is for the upgrades.
- Town: Centurion
- Vehicle: Nissan 1400
- Real Name: Etienne
Re: DIY 4x4 Vigo
Thanks for the inputs gentlemen, looks like I under estimated the costs involved. With regards to the V6 option, I work far from home and will need the bakkie to be a dayly driver and with petrol prices going through the roof I'd rather consider buying a diesel.
