Next Generation Dual Battery controller.
- Gertc
- Vehicle: 3.0L Fortuner
- Real Name: Gert Combrink
- Club VHF Licence: Xray05
2 x 16 character LCD screen
2 Button control
It is time to upgrade the Dual Battery system to something that is more useful l.
When the vehicle is switched on it will have a welcome screen
WELCOME
MASTER
Then it must check your Dual battery system.
SYSTEM CHECK
After the system check is completed.
Main Batt 13.8V
Aux Batt 12.2V
OR
Main Batt 13.8V
Aux Batt N/C
As soon as you start the vehicle the timer will start counting backwards
Connect Aux Batt
90 sec
After timer finished the countdown it will connect the Aux Batt.
Connect Aux Batt
Connected
Screen will return to.
Main Batt 13.8V
Aux Batt 13.2V
As soon as you switch of the vehicle it will show
Connect Aux Batt
Disconnected
Followed by
GOODBYE
MASTER
If the lights are left on a buzzer will alarm and the screen will show
Turn
LIGHTS OFF
The 2 buttons will be used to adjust the time for connecting the Aux battery or to connect the Aux battery when you need to or disconnect it if you don`t need it.
Any comments or suggestions welcome Good or Bad.
Dimensions 85 x 56 x 30 mm2 x 16 character LCD screen
2 Button control
WELCOME
MASTER
SYSTEM CHECK
Main Batt 13.8V
Aux Batt 12.2V
OR
Main Batt 13.8V
Aux Batt N/C
Connect Aux Batt
90 sec
Connect Aux Batt
Connected
Main Batt 13.8V
Aux Batt 13.2V
Connect Aux Batt
Disconnected
Followed by
GOODBYE
MASTER
Turn
LIGHTS OFF
Re: Next Generation Dual Battery controller.
Jeesh Gert, I've just installed and started using the excellent version 1!
On v1 the aux battery connected after 5 minutes, with the v2 I see it's 90secs... why? (plz excuse my ignorance)...
v2... I like the fact that it's got a volts display... price?
- Gertc
The Idea is that you must be able to set your own time. 90 sec was just an example.
I will try and set it from 60 sec to 300 sec. The one I used in the Hilux was set at 60 sec. It worked well for me. When I go to town it took me about 6 minutes to get there and waiting 5 minutes was too long for me. So I set mine to 60 sec.
Price ????????!!!!!!!!!!!!!!!!!!!!!?????????????????
Well I hope to be able to sell them for +\- R450. It is still in the design phase and I struggle to get a good neat enclosure for it.
Brilliant Gert!!
Me also thinks 5 mins is too long
Nice work
Nice work
- bosjakkals
- Town: Harrismith
- Vehicle: 97 Hilux SFA ,31 BF's, Bullbar,Warn winch, Hunting frame, 2 spare wheels, Long range tank, High lift jack, Gearmax rear locker diff, Suspension unknown but very soft)
- Real Name: CJ
Ek kom oor 2 weke klerkdorp toe kan jy instaleer ook ?
Asseblief
Asseblief
03 - Cruiser 105 GX
97 - Hilux 2.4 D/C -
05 - Pajero 3.2 DID SWB ( Ma se kar)
01-Prado 3.0 d (Gesien -Geniet - GEROL))
Cool, on the enclosure side... is your plan to go split unit, control components in one and display in another, to keep the messy stuff out of eye view?? Will I be able to use all my present DB wiring, or will this unit require some sort of rewire?
- Gertc
The idea is to keep it as compact as possible, I will try to use only one box. Modify the wiring to use a plug in system. You will still need the old wiring. Maybe just extend the aux battery pickup to be as close as possible to the aux battery so that you get an accurate voltage reading.
- Gertc
Jy is so bietjie haastig. Ek soek nog na die regte boks om die ding in temount. Intalasie sal ek jou raad gee. die res sal jy maar self moet doen.bosjakkals wrote:Ek kom oor 2 weke klerkdorp toe kan jy instaleer ook ?
Asseblief
And I have seen the prototype! ;)
Ek weet van nog iemand wat dalk sal belang stel
- The Legend
- Real Name: Dawie
- Club VHF Licence: X93-
Miskien n stupid vraag.Sal dit ek dit kan gebruik op my NL portable dual battery system?
- Bushwacker
- Town: Vryheid Natal
- Real Name: Piet
Daai klink great Gert!!!
One more thought Gert... yes I know this may be a long shot... any possibly to backlight/illuminate the display... would be cool for low light conditions!
- krazy_kameleon
- Town: Fourways
- Real Name: Rick
Nice suggestion - that would be coolMr_B wrote:One more thought Gert... yes I know this may be a long shot... any possibly to backlight/illuminate the display... would be cool for low light conditions!
- witmamba
- Town: Sasolburg
- Vehicle: D4D 4x4 Lux + D4D 4x4 Tuna
- Real Name: Hans
Hi Gert, as jy die wiele aan die rol het, moet jy my asb kontak sodat ek van daai units kan toets en in my winkel kry.
Groete!
Groete!
Life only starts . . . . where comfortlevels end
- Donkey
- Club VHF Licence: X122
Brilliant concept Gert. When you're ready to manufacture please put me on the buyer's list, Master -
Tumelo Maketekete
- Royco
- Town: Stellenbosch
- Real Name: Roy
- Club VHF Licence: X88
What about setting a personal greeting too ... ?Gertc wrote:The Idea is that you must be able to set your own time. 90 sec was just an example.
WELCOME
ROY
- Gertc
Back light will be standard when any button is pressed. Or would you prefer back light work with the vehicle lights?
- Gertc
Lollie wrote:Miskien n stupid vraag.Sal dit ek dit kan gebruik op my NL portable dual battery system?
Sal moet kyk maar ek glo jy sal hom saam kan gebruik.
Dink opsie een want mens gaan heel waarskynlik wil sien wat op die display aangaan voor jy ry of na jy klaar geparkeer hetGertc wrote:Back light will be standard when any button is pressed. Or would you prefer back light work with the vehicle lights?
- krazy_kameleon
- Town: Fourways
- Real Name: Rick
on with vehicle lightsGertc wrote:Back light will be standard when any button is pressed. Or would you prefer back light work with the vehicle lights?
- swartvark
- Town: Gordons Bay
- Real Name: Tiaan
I'll get it just to greeted as....... MASTER!!!
MUD........GLORIOUS MUD!!!!!
NEED A CAR?
talk2tiaan@gmail.com
0829294028
So then at night you would need to switch on the cars lights just to check the voltage?krazy_kameleon wrote:on with vehicle lightsGertc wrote:Back light will be standard when any button is pressed. Or would you prefer back light work with the vehicle lights?
Gert, is both not an option, when vehicle lights are on, display's backlight is on... and if vehicle is off and button is pressed, then backlight comes on and unit shows voltage, with auto-off timer... say 10 secs... best of both worlds!
- Gertc
Can be doneMr_B wrote:Gert, is both not an option, when vehicle lights are on, display's backlight is on... and if vehicle is off and button is pressed, then backlight comes on and unit shows voltage, with auto-off timer... say 10 secs... best of both worlds!
Ok seen as we are pushing our luck... integrate a small coffee maker and heating element, with temp control... don't want to burn the brew you know! With auto dispense controller...
- Gertc
Get married!!!!!!!!!!!!!!!!!!!!!!!!
Problem is... I am!
- krazy_kameleon
- Town: Fourways
- Real Name: Rick
Gertc wrote:Get married!!!!!!!!!!!!!!!!!!!!!!!!
- truckin
- Town: Durbanville
- Vehicle: 2006 2.7VVTI Hilux SRX Single Cab 4x4
- Real Name: Juan
dis n bakgat idee, net n vraagie, sal n mens dit kan maak om 2 spaar baterye apart te charge?
“The shinbone is a device for finding furniture in a dark room.”
“When I die, I want to die like my grandfather, who died peacefully in his sleep. - Not screaming like all the passengers in his car -
- Gertc
op spasial order ja.truckin wrote:dis n bakgat idee, net n vraagie, sal n mens dit kan maak om 2 spaar baterye apart te charge?
